WELL THAT’S INTERESTING, MAN!
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by BigCoogi, Feb 2, 2021.
  1. Feb 2, 2021 at 2:12 PM
    BigCoogi
    BigCoogi [OP] New Member
    Zac
    2019 White TRD Pro
    096CFE57-7F75-4985-BB70-94DB5BC1F96A.jpg 326C244B-E5FF-4E57-8766-21810D98D0E6.jpg :anonymous:Crawled underneath the truck today for a full on undercarriage power wash orgy. Anyone got some insight on what might have happened with this? Looks like someone torched or cut a section of the LCA? Looks like the shock was interfering. Knew I shouldn’t of bought a truck with a leveling kit lmao. Oh well fool me once. Wish I’d seen it before a 1600 mile round trip I just did, but made it back in one piece
    pic’s of everyone else’s LCA at the shock anchor point would be helpful.
    looking like I’ll need to buy some new LCA’s when I remove this god forsaken leveling kit. What do you all think about the ball joints and tie rods? Should I replace em all same time? I’m thinking might as well since I’ll have it all torn apart, and keep these ones in the garage.
    thanks boys!
    Darkness likes this.
  2. Feb 2, 2021 at 2:13 PM
    YotaBro
    Calvin
    FL
    Lots of shenanigans.
    Woof. That sucks man
  3. Feb 2, 2021 at 2:17 PM
    timsp8
    NY
    Is it road salt rusting the metal? LCAs usually come with ball joints already pressed in them. You have a leveling kit with pro suspension?
  4. Feb 2, 2021 at 2:23 PM
    Kanobi13
    Kanobi13 New Member
    Those are trd pro shocks and should slip right in.are the in correctly right/left
  5. Feb 2, 2021 at 2:37 PM
    BigCoogi
    Zac
    2019 White TRD Pro
    This is a TRD Pro- 2019- forgot to add. It didn’t have the fox shocks installed aftermarket. It does have a strut spacer on it, but it’s only 2”. That’s where I’m getting confused. 2” plus the fox sitting higher (what, 2”??) from what I’ve read, the OEM control arms should work. No idea what really was done to it before I bought it- but I bought it planning on removing the lift when I had time. Just noticing this today.
  6. Feb 2, 2021 at 2:39 PM
    BigCoogi
    Zac
    2019 White TRD Pro
    It’s from Ohio and it’s now in Michigan- so it’s whole like has been in salt- but it’s clear that something in the control arm was notched or cut out, but to for sure know, a picture of someone’s 2019+ at the same angle would be helpful to compare.
  7. Feb 2, 2021 at 2:43 PM
    Kanobi13
    Kanobi13 New Member
    Warranty
  8. Feb 2, 2021 at 2:49 PM
    BigCoogi
    Zac
    2019 White TRD Pro
    nah, it’s got a leveling kit on it- that’s the first thing they’d hop on. Stealerships man
  9. Feb 2, 2021 at 3:19 PM
    Kanobi13
    Kanobi13 New Member
    Take it off
  10. Feb 2, 2021 at 4:18 PM
    lonedrake
    lonedrake New Member
    Minnesota
    2020 TRD sport
    I always thought the pros came leveled. So from the sounds of it there is a two inch spacer. The guy just wanted to lift it a little. So you are going to remove the spacers and replace the control arms and that should get you back to stock? Seems like a good plan. As far are the tie rod ends and ball joints ...I see no reason to replace them. The rubber looks good and they are only a couple of years old.
  11. Feb 2, 2021 at 5:06 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    Looks like its definitely been nibbled a bit with a torch, also burning the paint off in the process, hence the rust in that area. Here's some of my 19 without the Pro shocks. Hope this helps.
    lonedrake likes this.
  12. Feb 2, 2021 at 5:07 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    You seem to have stumbled into a bit of a bad deal.
    I would definitely replace all of the associated components and the arms when you remove the crappy lift. The previous owner had his head in his ask.
    Good luck!
  13. Feb 2, 2021 at 5:11 PM
    Sitting Sideways
    Sitting Sideways Probably stuck somewhere
    Beaverton, Oregon
    2021 White CM Tundra TRD Off Road
    Icon IR Coilovers, Icon Delta Joint tubular upper control arms, Icon PB CDC rear shocks, Icon Expansion Pack, Icon Hydraulic Bump Stops, Durobumps front bump stops, TRD dual exhaust black tips, TRD pro skid plate, TRD cold air intake system, TRD pro shift knob, TRD Pro Wheels, Falken Wildpeak AT3W tires, TRD radiator cap, ESP under seat storage, spray in bed liner, bed rail system, SDHQ abs guards, black tundra letter inserts, center console wireless charger, center console organizer/tray, charcoal filter removal, whistle screen removed, RCI Transmission/Transfer case skid plate, and ICON neoprene shock wraps
    Dang dude that's sketch! I would think new lower control arms would be a good insurance policy and while you're under there, changing the balljoints might not be a half bad idea.
  14. Feb 2, 2021 at 5:12 PM
    timsp8
    NY
    Maybe with the level kit when at full drop the shock is rubbing that part of the control arm. Enough rubbing with the rust and it started to wear away.
  15. Feb 2, 2021 at 5:48 PM
    BigCoogi
    Zac
    2019 White TRD Pro
    Was thinking down
    Exactly what I was looking for. Great pictures. Thank you so much for crawling underneath the beast!!!!!!!! Next time ur in Michigan- Beer’s on me!!!!
    gosolo likes this.
  16. Feb 2, 2021 at 5:59 PM
    TILLY
    Massachusetts
    Anytime. :cheers:
  17. Feb 3, 2021 at 8:23 AM
    Bad Cow
    Bad Cow GOD Bless The USA
    Georgia USA
    2019 TRD PRO - SUPER WHITE
    Leather Steering Wheel, +1.5" Shackles
    Here are pics from my 2019 PRO. Hope this helps you. The 2019 TRD PRO does come with FOX Shocks from the factory. Your CV joints look VERY unhappy, way to much angle on them. Poor geometry will destroy those CV's. Looks like they cut the LCA's to allow room for the shock angle after the shade tree lift job. Bad choice. Good luck buddy.
    Terndrerrr likes this.
  18. Feb 3, 2021 at 8:31 AM
    BigCoogi
    Zac
    2019 White TRD Pro
    thanks bad cow- appreciate you crawling under the rig for some pics. Seeing a 2019 pro stock would be very helpful, though your pictures haven’t came thru yet- will keep an eye on it
    Bad Cow[QUOTED] likes this.
  19. Feb 3, 2021 at 8:33 AM
    Bad Cow
    Georgia USA
    They should be there now. It was only 30 degrees out there just now, burr. Hope the pics help you see what they did wrong.
