Well I screwed up big time
Discussion in 'General Tundra Discussion' started by Jacksongp69, Feb 27, 2020.
  1. Feb 27, 2020 at 6:35 PM
    Jacksongp69
    Jacksongp69 [OP] New Member
    TN
    2015 SR5 MGM 4x4 Double Cab
    Hey all, hoping this is the right place for this. So long story short, I am trying to replace my carrier bearing on my '15 Tundra. I am to the point where I have the big 30 MM bolt off and was attempting to remove the yoke. Its stuck on there of course so I tried holding the yoke in a vice and putting a socket over top the threads where the bolt was. I tried tapping with a hammer but unfortunately put a flat spot on the threads from the socket. (Hope all this is making sense.) Now I cant get the bolt threaded back on. Is a new driveshaft my only option at this point?
  2. Feb 27, 2020 at 6:37 PM
    AZTundra
    Paul
    Phoenix, AZ
    Any pictures?
  3. Feb 27, 2020 at 6:39 PM
    SprinterAE86
    SprinterAE86 New Member
    Ian
    Charlottetown, PE, Canada
    2012 Toyota Sequoia Platinum
    Share some photos. I have not done any center carrier bearing replacement in 2nd/3rd, but it should be as simple as the 1st gen and other Toyotas.
    I do not use vise, just block of wood.
  4. Feb 27, 2020 at 6:47 PM
    Jacksongp69
    TN
    Here's a pic of the threads
  5. Feb 27, 2020 at 6:59 PM
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    Get a female thread die and run it over the threads
  6. Feb 27, 2020 at 7:00 PM
    Kerch71
    Kerch71 Surgical Precision
    Mechanicsville VA
    I would try recutting the threads if you can find the right sized cutting die. Tons of sets online.
  7. Feb 27, 2020 at 7:00 PM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Nailed it!!
    ZappBrannigan likes this.
  8. Feb 27, 2020 at 7:00 PM
    ZPMAN
    Minnesota
    You can get a thread file, I will see if I can find one on line.
  9. Feb 27, 2020 at 7:02 PM
    Kerch71
    Mechanicsville VA
    Yeah, you beat me to the punch!:thumbsup:
  10. Feb 27, 2020 at 7:02 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    That will probably be the best option, but finding one that big, anytime soon might be a task.
    You could also try some jewelry files, and very slowly get the threads back in shape.
    Twinky, Hoff, BENWALES and 1 other person like this.
  11. Feb 27, 2020 at 7:06 PM
    55kcement
    55kcement New Member
    Troy
    Sonora ca
    2020 TRD Off Road limited Double cab
    Currently none
    Did ever get the yolk off ?
    Mountun Goat likes this.
  12. Feb 27, 2020 at 7:07 PM
    Jacksongp69
    TN
    Thanks for the responses guy. I did consider trying to lightly file them but didnt know if that would work. I will give it a try.
  13. Feb 27, 2020 at 7:08 PM
    ZPMAN
    Minnesota
  14. Feb 27, 2020 at 7:09 PM
    55kcement
    Troy
    Sonora ca
    Currently none
    You need to use a thread file ! If your not understanding it a file designed just for that purpose. Maybe you knew that ?
  15. Feb 27, 2020 at 7:11 PM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Absolutely. Plus if it fits between the yolk also.
  16. Feb 27, 2020 at 7:11 PM
    55kcement
    Troy
    Sonora ca
    Currently none
    Did you get the yolk removed ?
  17. Feb 27, 2020 at 7:14 PM
    55kcement
    Troy
    Sonora ca
    Currently none
    I took a closer look and zoomed in on it it pretty boogerd up ! Not sure a thread file will do it but if your patient it’s a possibility, I’d chase it with a die the correct size and pitch .
  18. Feb 27, 2020 at 7:14 PM
    Jacksongp69
    TN
    No i havent been able to get the yolk off. Not sure if some sort of puller would work?
  19. Feb 27, 2020 at 7:15 PM
    ZPMAN
    Minnesota
    If you can't find a thread file at ace hardware you might be able to bring it to a machine shop and they should have one and maybe get your yoke off also.
  20. Feb 27, 2020 at 7:16 PM
    55kcement
    Troy
    Sonora ca
    Currently none
    Yeah I have a steering wheel puller that would work ! Got any mechanic friends you could barrow one from ?
  21. Feb 27, 2020 at 7:16 PM
    Jacksongp69
    TN
    Yea it's pretty bad, i wish i was more careful with it but i've been fighting this all day so my impatience got the best of me.
  22. Feb 27, 2020 at 7:18 PM
    55kcement
    Troy
    Sonora ca
    Currently none
  23. Feb 27, 2020 at 7:19 PM
    Jacksongp69
    TN
    I'm going ask around at work tomorrow and see. Hopefully someone either has one or knows someone who does.
  24. Feb 27, 2020 at 7:20 PM
    55kcement
    Troy
    Sonora ca
    Currently none
    There some things I would try but it takes some finesse.
  25. Feb 27, 2020 at 7:23 PM
    Jacksongp69
    TN
    Yea i may just have to experiment a little more, just trying not to make it worse. If it comes down to it i may take it to a shop like some have to suggested and let them do it.
  26. Feb 27, 2020 at 8:10 PM
    Viking
    Viking New Member
    Jerry
    2007 metalic brown double cab Tundra
    Over the years I just used a fine cut tri-angle file, it looks like the threads are pretty good toward the bottom of the threads where it's important. Carefully apply a bit of heat to the splined area and spray liquid wrench or something like it, too much heat could take the hardening out of the metals. Definitely have a good puller, rental places sometimes have those. Taking it to a good shop is not a bad idea either.
  27. Feb 27, 2020 at 8:50 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    If all else fails, any good machinist can put that in a lathe and make those threads good as new, but a die should suffice
    A 2-jaw puller is your best bet for pulling the yoke. Make sure to mark the yoke and the shaft to they are assembled exactly the same on the splines.
  28. Feb 27, 2020 at 9:11 PM
    Tundra_361
    Tundra_361 New Member
    Victor
    2019 Black 1794 4x4
    Love this forum! Very helpful peeps on here :)
  29. Feb 28, 2020 at 1:52 AM
    rockmup
    rockmup New Member
    Todd
    Greenwell Springs LA.
  30. Feb 28, 2020 at 3:16 AM
    Omohundro
    Omohundro 2018 Not a Pro
    Jody
    McMinnville TN
    2018 Tundra Platinum
    Hope you get it all sorted out.
