Well I am, off for 3 days and by myslef, sooooo whats a guy to do....
Discussion in 'Food Talk' started by RLHULK, Jul 2, 2016.
  1. Jul 2, 2016 at 10:00 AM
    RLHULK
    RLHULK [OP] Too many gamma rays in all that BBQ smoke.
    Rich
    2022 Silverado LT.
    Still rolling stock baby....
    But fire up the Weber performer this morning and throw on a side of st louis cut ribs...
    Mmmmmm Mmmmmmm sooooooo good...
    Enjoy, I did, well half the rack, saving the rest for later...
    julyribs.jpg julyribs1.jpg julyribs2.jpg julyribs3.jpg julyribs4.jpg julyribs5.jpg
    Wvmoonshiner, Viper3G, Law323 and 2 others like this.
  2. Jul 2, 2016 at 10:41 AM
    Yotalover88
    Yotalover88 "If it ain't broke don't fix it"
    James
    2013 white tundra
    Rhino liner, bed mounted tool box "no stripper pole" paracord wrapped oh shit handles, Lowes stair tread door seal protectors, handgun holder for my dedicated truck gun. My list of wants is much longer!
    Looks good just gotta wash it down with some cold beer!
    dandailey and zcarpenter92 like this.
  3. Jul 2, 2016 at 11:02 AM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    Great! Now I have to drag out the BBQ.
    Yotalover88 likes this.
  4. Jul 2, 2016 at 3:20 PM
    RLHULK
    Rich
    2022 Silverado LT.
    3-2-1- method, times adjusted some but that's a good base to start.
    Indirect heat on a weber charcoal performer
    target temp is 250
    wash the rack of ribs then pat dry
    remove the membrane from the back of the ribs
    rub ribs with some yellow mustard, you can use olive oil if you want
    coat ribs evenly with your favorite rub, I used webers bbq dry rub.
    After you have your grill/smoker going and target temp is reached place ribs on grill, close lid and walk away for at least 2-1/2 hours.
    At the 2-1/2 hour mark, open smoker and check ribs the rack should have firmed up some and the tips of the bones should start to be exposed.
    place two sheets of foil on a work surface, my grill has a table attached, you want two pieces of foil in case a bone pokes thru the first layer
    turn the ribs meat side up on the foil, sprinkle with brown sugar and some honey, flip ribs over meat side down, do the same for bone side of the ribs. Wrap up the foil forming a tight packet
    place back on smoker/grill for at least 2 hours.
    After 2 hours, open foil, the bones should be exposed by about half an inch remove the rack from the foil and place back onto the grill meat side up
    Coat the meat side of ribs with your sauce, you can thin it down, I use a little water or apple cider vinegar to thin the sauce so it coats the back of a spoon. Spread the sauce evenly as you can onto the ribs and cover the grill, leave to finish for another 30 minutes to an hour
    Remove from heat, let rest a few minutes, slice and enjoy
  5. Jul 4, 2016 at 2:05 PM
    RLHULK
    Rich
    2022 Silverado LT.
    Awesome glad you liked them.
