Welds showing through on silver 2024 Tundra
Discussion in '3rd Gen Tundras (2022+)' started by ExFordGuy, Jan 31, 2024.
  1. Jan 31, 2024 at 6:24 AM
    ExFordGuy
    ExFordGuy [OP] New Member
    2024 Silver 1794 Tundra
    Has anyone else noticed welds around the rear fender well showing through? This is a silver 2024 1794 edition that I have only had for 3 days. Do you think this is acceptable? Of course this is something that’s hard to get a picture of, but I have attached one for reference. Thank you for any input.
  2. Jan 31, 2024 at 6:29 AM
    Welcome from NY.
    Go back to the dealership and look at some other Tundra's then go inside and have your issue documented and hopefully the address the problem. You paid good money for that truck and you should be happy with your Tundra.
    ExFordGuy[OP] and cmiles97 like this.
  3. Jan 31, 2024 at 6:30 AM
    Tundraaa3
    Tundraaa3 New Member
    Those marks are where the plastic clips are holding the fender flair down. Mine are more visible when it gets cold and the plastic shrinks, when it gets warmer and the plastic expands it's not as noticeable.
    Buildn and ZappBrannigan like this.
  4. Jan 31, 2024 at 6:41 AM
    ExFordGuy
    Are you okay with that?
  5. Jan 31, 2024 at 6:41 AM
    TundraTT
    TundraTT Full Send
    23 Taco Trail 97 FZJ80 68 Goat
    There are no welds near that area. The flare is plastic and the bed is stamped aluminum
  6. Jan 31, 2024 at 6:46 AM
    TundraTT
    TundraTT Full Send
    You’re most likely experiencing from the typical sub-par Toyota paint. If you’re not happy with it, take it to the dealer and let them know
  7. Jan 31, 2024 at 6:48 AM
    cmiles97
    cmiles97 New Member
    2018 Toytota Tundra SR5 4x4 XP
    XP package
    That is not acceptable on any new vehicle. Add in how much you paid for it.
    The higher the price the better the quality should be.
    ExFordGuy[OP] likes this.
  8. Jan 31, 2024 at 6:48 AM
    Northern Toyota
    Northern Toyota New Member
    2023 Tundra TRD Off Road, 2022 Tacoma TRD off road premium
    Tires and bilstein
    Don’t look down the side of your truck around the door handles, the stamping process has the metal all distorted. What you are seeing is normal on a modern vehicle. Thin is in as they say
  9. Jan 31, 2024 at 6:49 AM
    Tundraaa3
    It sucks, but I know the dealer probably can't/won't fix it. The plastic is just too thin and flimsy on the painted fender flairs.
    ExFordGuy[QUOTED][OP] likes this.
  10. Jan 31, 2024 at 7:58 AM
    Racer57
    Racer57 New Member
    Only way to fix that is to hide it. You want body putty ?
  11. Jan 31, 2024 at 8:04 AM
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    This sounds like a good opportunity to put some TRD Pro flares on and get that camo look!
    The plastic flares are quite flimsy like many have said. Take it to your dealership and see what they suggest and go from there. It may be that they can use a bit of body filler and repaint but I think that would just make it worse. Keep in mind that these are not an expensive item and can be swapped out in minutes so the dealership shouldn't balk about swapping it out to keep you happy.
    I would just be concerned about a slight difference in the color.
  12. Jan 31, 2024 at 11:03 AM
    cmiles97
    cmiles97 New Member
    XP package
    Throw a lift and 37s on it then beat it up a bit in the woods and rock climbing, no one will notice then.
    ExFordGuy[OP] and KuehnMK like this.
  13. Jan 31, 2024 at 1:48 PM
    KuehnMK
    KuehnMK New Member
    2023 Tundra Crewmax 4X4 Platinum
    My Platinum has the same "issue"...It is normal and because the flares on our models are painted a dark color and is shiny.... Models with white painted flares, not as noticeable... Models with the black/dark grey texturized plastic, it is not noticeable at all... Slightly surprising and disappointing?? Yes....BUT there are worse things to worry about....Just be happy you don't have a new F-150....rattles and strange noises, GALORE!
    Tundrastruck91 and ExFordGuy[OP] like this.
