Welded?
Discussion in 'Towing & Hauling' started by Tay2610, Aug 5, 2018.
  1. Aug 5, 2018 at 1:14 PM
    Tay2610
    Tay2610 [OP] New Member
    I have a 1998 Ford E250 cargo van that I just bought for work. I regularly tow 3000lbs, frequently over rough terrain, but the van hitch was welded onto the bumper. I’m used to factory bolt on hitches as most trucks I’ve towed with have. Is this weld hitch just as safe? Should I be concerned with the attachment being the bumper?E7A070D6-B857-4209-91F9-AA4D49C08AC8.jpg13F56A83-82C8-4F8C-8F2E-20A11B943508.jpg
  2. Aug 5, 2018 at 1:35 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Judging by the “pigeon shit” weld across the front edge of that plate, I wouldn’t use that for anything, not even a bicycle rack.
    Cut it off, and install a proper hitch to the frame rails.
    Towing a trailer isn’t something you want to go off without a hitch...
  3. Aug 5, 2018 at 1:41 PM
    Tay2610
    Thanks! Is the problem just quality of weld? What are the disadvantages in the bumper being the attachment point vs frame?
  4. Aug 5, 2018 at 1:46 PM
    koditten
    Kirk
    Midland of the Mitten
    That is a poor hitch. Have it cut off and install a decent, frame bolted class II or class III. That's not even a class I in my opinion. That is maybe strong enough to haul a bicycle rack.
    Tay2610[OP] likes this.
  5. Aug 5, 2018 at 2:16 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Both are an issue in my opinion. Attatching to the bumper, your hitch is limited by the towing capacity of the bumper (assuming it’s a hitch style bumper you could install a hitch ball directly into) at best, depending on how it is attached. Most bumpers are rated for around 3000 lbs or so (owners manual should say, bumper probably stamped) and since you mention frequent towing and rough terrain, I’ll strongly recommend a class III (5000lb) or class IV hitch that bolts to your frame.
    Some are pretty cheap.
    https://www.etrailer.com/p-75703.html?hhyear=1998&hhmake=Ford&hhmodel=Van
  6. Aug 6, 2018 at 8:36 AM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    @landphil that's what we call your typical YouTube welder. I've seen worse, but you get the idea. :cool:
    Tay2610[OP] and landphil[QUOTED] like this.
  7. Aug 6, 2018 at 9:48 PM
    TFT
    TFT New Member
    Troy
    2017 Tundra Limited
    Looks like the bumper is also missing a bolt..
    Not a good idea to tow with that.
  8. Aug 6, 2018 at 10:03 PM
    Baja Mike
    Baja Mike Baja Aficionado
    South Bay, Ca.
    2016 Tundra TRD 4x4 SR5 white
    LED interior lights, Baja Designs foglights, Baja Designs S8 hood bulge light bar, LED bed lights, Baja Designs S8 amber bar in bumper on Rago Fab mounts, AMP Research bedstep, Switch Pros sp-9100, tinted door windows
    The bumper is there for collisions and impact absorption. The frame is structural and much, much stronger.
    That hitch is some tree shade/mickey mouse mechanic crap. Cut it off and have a proper one installed.
    Tay2610[QUOTED][OP] likes this.
