Weird stalling issue: Hitting bumps BUT only when cold
Discussion in '2.5 Gen Tundras (2014-2021)' started by Snowboard Tundra, Dec 17, 2023.
  1. Dec 17, 2023 at 7:54 PM
    Snowboard Tundra
    Snowboard Tundra [OP] New Member
    I live here in Colorado and believe I have an electronics gremlin in my truck, somehow, somewhere, who knows. I have 2+ miles of very rutted out dirt roads that I have to travel to leave my home to get to the pavement, and if I simply start my truck and go....it will stall on some of these bumps. It's stalled once, or even 5-6 times until it gets to the pavement whereas it's then good to go. Never an issue. I can hit all of these bumps with the most intensity coming home when the truck is warm, never a stall. Never.
    Today I warmed the truck up for 20 minutes prior to leaving, never stalled. I've also:
    - jiggled wires in the engine bay while running, trying to re-create it. Didn't work
    - Cleaned the MAF, ensured battery was tight and clean
    - Tapped the Fuel delivery module thingy inside the frame while running, nothing
    - Jiggled wires under the dash, nothing
    - Checked the ground cables inside the engine bay and behind the kick panels, nothing
    What's weird to me is that it ONLY does it from a cold start. If I run it, it's good. If the truck is warm and I hit bumps, it's good. Driving on pavement anywhere, it's good.
    Otherwise if I start it up and go for it, I get about 1/2 mile in and hit a major rut....check engine light on, battery light, dead. Put it in park and fires back up.
    Maybe I have to take it to Toyota....
    Truck has 185k on it, never had this issue before.
  2. Dec 17, 2023 at 8:07 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Loose negative battery terminal will do it.
    HulkSmurf14 likes this.
  3. Dec 17, 2023 at 8:12 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    That's definitely a weird one for sure, any codes after getting the check engine light?
  4. Dec 17, 2023 at 8:17 PM
    Snowboard Tundra
    So I took it to a local shop about a month back, hooked it up, it's throwing Code P1604 (Startability Malfunction).
    That's all I got
  5. Dec 17, 2023 at 8:29 PM
    Snowboard Tundra
    Terminals are so tight you couldn't squeeze a ___ hair in there. And it's only when the truck is cold, which is strange
  6. Dec 17, 2023 at 8:35 PM
    TILLY
    Massachusetts
    That code is very vague at best. Here's a link that might help to send you in the right direction.
    https://www.obdadvisor.com/codes/p1604-toyota/
  7. Dec 17, 2023 at 8:35 PM
    Almost like some fluid isn’t warm enough to transfer through or something. This is an odd one
  8. Dec 17, 2023 at 8:38 PM
    Is an idle air controller the same as maf? Wonder if it went bad?
  9. Dec 17, 2023 at 8:47 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    What are we talking about here? A 5.7L? Flex fuel or no?
  10. Dec 17, 2023 at 9:12 PM
    Snowboard Tundra
    It’s a 5.7, not flex fuel (i think?)
    you know I do wonder if it’s the battery with some weird parasitic draw or something. I have a WARN winch and two pro comp LEDs hooked into it….
  11. Dec 17, 2023 at 9:12 PM
    Snowboard Tundra
  12. Dec 17, 2023 at 9:22 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    I’d do a battery load test to begin with, and if it has removable caps I’d check the electrolyte level too.
    Snowboard Tundra[OP] likes this.
  13. Dec 24, 2023 at 6:18 AM
    Snowboard Tundra
    So I took it to the dealership. No codes, nothing wrong with the truck…of course.
    They then do a battery load test and tell me the battery I bought this summer is bad.
    replace battery.
    I guess I’m glad it wasn’t more but am annoyed as well. I still don’t know how this impacted the staling issue, voltage wise, but just wanted to follow up.
    Black Wolf and T-Rex266 like this.
  14. Dec 24, 2023 at 6:27 AM
    Glad it was something simple
  15. Dec 24, 2023 at 6:33 AM
    FWIW, could have simply been a bad battery but.....some batteries don't like an overdose of vibrations or jostling around.
