Weird Squeaking coming from my Tundra
Discussion in '2nd Gen Tundras (2007-2013)' started by LilFeller, Jan 3, 2021.
  1. Jan 3, 2021 at 3:08 PM
    LilFeller
    LilFeller [OP] New Member
    Johnny
    2008 White Tundra SR5 5.7L V8 2WD
    Vehicle was purchased with lift kit already installed.
    Hi guys! So I am a bit new to this whole Tundra forums so I made an account to specifically see if anyone knew what was up with the loud squeaking coming from my Toyota Tundra (2008 SR5 Double Cab at 173k miles). At first I automatically assumed it needed new brakes but checked both front and rear brakes and are still good. It only makes the squeaking noise when I'm driving about 10-20 MPH while accelerating and also braking and it's very loud. I will attach youtube links so you can hear what it sounds like specifically.
    https://youtu.be/VS1Onp06WGA
    https://youtu.be/VlxtJSBSHAg
  2. Jan 3, 2021 at 3:11 PM
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    Sounds like a dry bushing
  3. Jan 3, 2021 at 3:25 PM
    LilFeller
    Johnny
    Oh okay. I did a little google search and I'm guessing that to take care of the issue I just need to clean and lubircate these bushings? Apologies, but I'm also not the most knowledgeable person when it comes to cars but I'm definitely willing to learn :)
    I'm also very thankful for the quick response and help!
  4. Jan 3, 2021 at 4:32 PM
    xtyfighterx
    Ty
    North Idaho
    Ya defiantly
    Lubricate everything, grease everything up and go from there.
  5. Jan 3, 2021 at 4:33 PM
    skylinekin
    skylinekin New Member
    Michigan
    2021 Tundra DC TRD PRO (Current), 2014 Tundra SR5 DC TRD OR (Sold)
    Lots of options for what the noise is. Could be bushing, ball joint, brake related etc.. Do you have a local repair shop that you could call and ask for the cost to do a diagnosis? Then at least you know what needs to be done and can decide what to do. You won’t get something like this fixed on the Internet...
  6. Jan 3, 2021 at 4:34 PM
    skylinekin
    Michigan
    what specifically are you saying needs grease or to be lubricated? There’s no grease fittings on the factory suspension bushings/ball joints.
  7. Jan 3, 2021 at 4:39 PM
    xtyfighterx
    Ty
    North Idaho
    Could also be the shock. The video of you driving sounds like my buddies Tacoma did and his driver side shock was bad. But the second video reversing and pulling forward I heard more of a dry bushing sound.
  8. Jan 3, 2021 at 4:44 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Jack up one wheel at a time and spin it by hand. When you do the rear, the transmission will need to be in neutral so chock all three of the other wheels to be on the safe side.
  9. Jan 3, 2021 at 5:21 PM
    LilFeller
    Johnny
    I appreciate all the amazing feedback! Thank you!
  10. Jan 3, 2021 at 8:09 PM
    audiowize
    audiowize New Member
    Paul B.
    2008 Tundra SR-5 4x4 5.7
    I agree with the suggestion to jack up one wheel at a time and give it a spin. That sounds like something happening at about the same period as your wheel is rotating, so you could have something rubbing on one wheel.
  11. Jan 9, 2021 at 3:44 AM
    LilFeller
    Johnny
    Just an update for those that were probably curious as to what it was causing the weird squeaking on my truck. My front driver's wheel was holding on for dear life and was missing a wheel stud and lug nut. As we unscrewed another lug nut a second wheel stud broke off leaving me with 2 broken studs and my tire was only being supported by 3 working studs and lug nuts. Ended up replacing the whole wheel bearing because replacing just the studs didn't fix the issue. After swapping the whole wheel bearing it stopped the whole squeaking noise and drives like a beaut! Thank you for everyone's advice!
  12. Jan 9, 2021 at 5:53 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Thanks for getting back to us to share what the ultimate problem and solution were. That helps everyone.
    LilFeller[QUOTED][OP] likes this.
  13. Jan 9, 2021 at 6:12 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    Excellent to hear. There is probability that the stud failure was in part, or whole, due to insane torque on the wheel lugs (by a ham fisted gorilla "mechanic"). I hope it was put back together with lug torque more in the 80lb-ft to 90lb-ft range.
