Weird sound
Discussion in '2.5 Gen Tundras (2014-2021)' started by Meis, Jun 11, 2019.
  1. Jun 11, 2019 at 6:57 PM
    Meis
    Meis [OP] New Member
    Brandon
    2018 SR5 gray
    I recently purchased a 2018 trd sport 4x4 crewmax. I just noticed the other day, when I turn the vehicle on and put it in drive and accelerate it makes a noticeable click noise. This only happens when the vehicle has been turned off and then put in drive. It almost sounds like it’s coming from the drive shaft but am not sure. Has anyone experienced this with their Tundra?
  2. Jun 11, 2019 at 7:47 PM
    tAcomaPueblo
    tAcomaPueblo New Member
    Tampa Bay
    2014 SR5 TRD OR CM 4x4
    Does this only happen the first time you do it or every time you stop and go?
    Do you use four wheel drive or is it typically in 2WD?
  3. Jun 11, 2019 at 7:52 PM
    Max Power
    Max Power Groovy Member
    2018 SR5 TRD Off Road
    TRD Dual Exhaust TRD Rear Sway Bar
    Is it a "click" that happens repeatedly after startup, or is it a "clunk" which happens once about 10-15 seconds after startup? If it's the latter, it's normal. According to the forum, it's the ABS self check. My Tundra does it as well. If it's the former, I have no idea how to help.
  4. Jun 11, 2019 at 8:08 PM
    Sounds like ABS self check
    TacoWuzzaTurd and Ajkkane like this.
  5. Jun 11, 2019 at 8:23 PM
    Hammy68
    Hammy68 Peak Bagger
    New Hampshire
    2018 Silver Tundra TRD Off Road Crewmax
    RC 1.75” Front, 1” Rear, TRD Dual Exhaust, Nitto RGs 275/70/18, TRD Center Caps, Rugged Cover Hard Tonneau, Rhino Liner, LED interior/exterior upgrade
  6. Jun 12, 2019 at 8:25 AM
    Meis
    Brandon
    2018 SR5 gray
    I greatly appreciate everyone’s timely responses! Based on everyone’s response, it sounds like it is in fact the ABS self check. I was unaware that the tundra had this as I have not heard of other vehicles doing this. I wish there was a notifying light or something that tells you this is happing. When I first heard this sound, I thought my new tundra had a defect. Scary! Thank god for this forum!
    Ajkkane and T-Rex266 like this.
  7. Jun 18, 2019 at 6:18 PM
    Belated welcome from NY.
    Meis[OP] likes this.
  8. Jun 18, 2019 at 6:23 PM
    AZTundra
    Paul
    Phoenix, AZ
    Welcome from AZ.
