Weird problem... need advice
Discussion in 'General Tundra Discussion' started by aoddo, Jan 27, 2020.
  1. Jan 27, 2020 at 6:39 PM
    aoddo
    aoddo [OP] New Member
    Andrea
  2. Jan 27, 2020 at 7:03 PM
    Jrharvey02
    Jrharvey02 New Member
    2010 Tundra CM 5.7 Platinum Dark Black
  3. Jan 27, 2020 at 7:12 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    I suspect a bad battery cable, clamp, or terminal. If DIY repair is the goal, go on youtube and search “voltage drop testing”. Test the voltage drops on the ground circuit as well as the positive circuit. Make sure all connections are clean, bright metal and tight.
    A shop that specializes in automotive electrical repair would be the best option if you’re not intending on DIY.
    joonbug likes this.
  4. Jan 27, 2020 at 7:13 PM
    aoddo
    Andrea
    Alternator is brand new, battery is brand new... had both retested and they show they’re fine. Last time this happened we hooked the battery up to the charger and it showed it had a 90% charge on it. When it does this there is no clicking, nothing completely dead. Baffles me that taking the battery out, waiting a min the reconnecting is the only thing that will get it running again
  5. Jan 27, 2020 at 7:13 PM
    duece292
    duece292 Appalachian American
    Greg
    Green Bay, WI
    Welcome from WI. I had a similar problem but it was a one time thing. Got to work and shut the truck off, went to start it a couple hours later and nothing. No radio, immobilizer light, gauges, absolutely nothing. I disconnected the battery for 30+ minutes, reconnected it and it hasn't done it since. Make sure your cables are free of corrosion as well as the battery posts and make sure they're tight. Check the condition of the cables from end to end too. Even though it tested fine, my bet is that your battery is failing. One bad cell can do funny things.
    Trunk Monkey likes this.
  6. Jan 27, 2020 at 7:17 PM
    aoddo
    Andrea
    What are the odds that we replaced the battery because of this and it’s still doing it with the new battery, old battery tested fine too. I’m not saying it’s not the battery but that would be pretty coincidental.
    no corrosion that I can see. Nothing seems to be standing out as the problem visually anyway.
    Thank you for all the advice everyone. Really don’t need an expensive car repair right now!
  7. Jan 27, 2020 at 7:28 PM
    CPdaddy
    CPdaddy Why am I so tired
    Tom
    Denver
    16 Tundra CrewMax Limited
    Boss 3" Lift, TRD Dual Exhaust, S&B Intake, TRD Rear Sway, 285/75r18 Nitto Ridge Grapplers on Fuel Beast Wheels, SPC upper control arm, Rough Country front bumper with LED bar and dual lights on each side, Rear bumper blackout covers, Go Rhino running boards, Morimoto XB Headlights, HIRev LED Tail Lights
    Hello from Colorado. Quick question. When you’re trying to start it, does everything else work ie lights, stereo, etc? Only it’s not turning over? Might check the connection on the starter.
  8. Jan 27, 2020 at 7:28 PM
    duece292
    Greg
    Green Bay, WI
    I've had new batteries delivered to my shop that were bad right off the bat. Poor production, got dropped somewhere along the line. If the last time it happened, your battery was at 90% charge, I'd say you have a bad cell. A new battery shouldn't be low like that. Tundras are also very finicky about voltage and a low charge will cause the symptoms you're experiencing.
    CPdaddy likes this.
  9. Jan 27, 2020 at 8:18 PM
    Hopefully you can figure this out.
    Welcome from NY.
  10. Jan 27, 2020 at 8:45 PM
    Tdog408
    Tdog408 New Member
    T
    2020 Cement Tundra Limited TRD Off Road/ 2017 BMW M4
    More than likely your starter is on its way out. My 07 did the same thing. It ended up being the starter
  11. Jan 27, 2020 at 8:58 PM
    Kn4x2
    Kn4x2 Common sense is not so common!
    3rd rock from the sun
    2010 DC 2WD
    Afe Pro Dry filter Tinted windows Coverking seat covers Traxion tailgate ladder Auto vox M1 backup camera
    I had a similar problem with a Toyota Echo.
    The armature in starter was going bad, if it would not start I would hit the starter a couple of times with wrench and it start. I had to replace the starter.
    As stated above a bad battery is likely the issue.
    Good luck, hopefully its a quick and easy fix.
  12. Jan 27, 2020 at 9:09 PM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    Test the battery cable. I had a gmc do this sort of thing and the battery cable was rotting on the inside.
    aoddo[OP] likes this.
  13. Jan 28, 2020 at 3:43 AM
    aoddo
    Andrea
    No nothing, completely dead.
  14. Jan 28, 2020 at 4:12 AM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    I would have the wires checked, could be the alternator is not keeping the battery charge.
  15. Jan 28, 2020 at 4:20 AM
    MOTORHEAD
    MOTORHEAD New Member
    DAVID
    LOS ANGELES CA
    2002 Toyota Tundra SR5 V-8 4.7L WHITE
    RCD 6" SUSPENSION LIFT,ICON EXTENDED FRONT COILOVERS,3" BODY LIFT,CAMBURG UPPER CONTROL ARMS.REAR DISK BRAKE CONVERSION,BIG BRAKE FRONT CONVERSION, AND MANY MORE
    I would check for loose/bad ground wire,starter relay/fuse, ignition relay,many things it could be.start with one thing at a time to isolate what is not the problem and then check something else
    Pinay likes this.
  16. Jan 28, 2020 at 4:28 AM
    MOTORHEAD
    DAVID
    LOS ANGELES CA
    I would first check all the fuses and relays in the main fuse box in the engine bay.,then check ignition relays and switch
  17. Jan 29, 2020 at 9:20 PM
    smokey0810
    smokey0810 New Member
    '03 Tundra SR5 AC 4WD
    Throwing this out there...Any chance of an unknown security system installed on the truck?
    ZappBrannigan likes this.
  18. Jan 31, 2020 at 9:53 AM
    Nothing but Black
    Nothing but Black 2019 black Trd tundra
    Paul
    Fitchburg, Massachusetts
    2019 black toyota tundra trd offroad
    Exterior mods hood deflector, predator steps. Black chrome exhaust tip. Increased payload capacity with new trinions. Trd air filter. Weather tech interior mats. Gator tonneau cover.
    Years ago I had a similar issue with a dodge Dakota. The truck was new. Dealer stated the problem was in the wiring harness. It had many rides on the flat bed. :)
