Weird Noise
Discussion in '1st Gen Tundras (2000-2006)' started by arlail76, Oct 27, 2020.
  1. Oct 27, 2020 at 8:53 AM
    arlail76
    arlail76 [OP] New Member
    Andrew
    Stock 2004 Toyota Tundra Double Cab 2WD
    So I have a question...
    I’ve noticed that when I’m on the highway and I get over 70...I’ll hear a noise...almost like a brief, high pitch wail like air has found its way through into the cabin of the truck. It’s very strange. It only does it over 70, and I was able to get it to continue to make the noise while going 80.
    I don’t have any loss of power, loss of oil pressure, or anything like that, it’s just an annoying noise...and sometimes it doesn’t happen at all.
  2. Oct 27, 2020 at 10:49 AM
    shifty` In South Dakota Trouble ain't hard to find
    Deteriorated steering shaft seal maybe allowing noises in from the engine bay? Have you checked the seal?
  3. Oct 27, 2020 at 10:55 AM
    Professional Hand Model
    Hand Protectors
    Yeah. Could be those deteriorated rubber flaps vibrating with the air passing over them like a reed on a flute.
  4. Oct 27, 2020 at 11:08 AM
    Windshield seal is another possible culprit
  5. Oct 27, 2020 at 1:05 PM
    arlail76
    Andrew
    I’ll check it out and let everyone know
    thank you for the suggestions
  6. Nov 7, 2020 at 9:20 AM
    arlail76
    Andrew
    Well, I’ve sealed every place I could see on the top side that could be air coming in making the noise. Still got the noise. Guess I need to check underneath and get out that fine toothed comb.
