Weird noise opening closing drivers door
Discussion in '3rd Gen Tundras (2022+)' started by Tb2, Nov 28, 2023.
  1. Nov 28, 2023 at 10:26 AM
    Tb2
    Tb2 [OP] New Member
    James
    I have noticed this weird sound coming from door hinge area , it occurs upon opening and closing door drives me nuts . I have lubricated all moving parts I could see no improvement.
    I took it by service dept and they were not sure but thought it was a bushing in the door ?
    They said it would take all day to get to source and they may not have the part ? So I could be out of truck for a few days
    I will try and attach a video with the sound
    https://www.dropbox.com/scl/fi/bsuehzi5t82q9ipwbhx3r/toyota?rlkey=wadbkbzunrxtz0vj2oo2vciph&dl=0
    I can't video to load with the sound , how do i get video to download it says need an extension?
  2. Nov 28, 2023 at 11:55 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    maybe the door check needs to have the nuts tightened? It gets loose sometimes on the 2.5 gen
  3. Nov 28, 2023 at 12:06 PM
    Tb2
    Tb2 [OP] New Member
    James
    It’s inside the door
  4. Nov 28, 2023 at 12:37 PM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Where is this? My 2.5 gen makes noise opening and closing.
  5. Nov 28, 2023 at 2:18 PM
    MadMaxCanon
    When you open the door its the hinge in the middle of the door with the 2 nuts on each side. Google door check you will see exactly what it is. same on most cars.
  6. Nov 28, 2023 at 7:18 PM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Thanks.:thumbsup:
    MadMaxCanon[QUOTED] likes this.
  7. Nov 29, 2023 at 3:28 AM
    Jim2023
    Jim2023 New Member
    2023 Limited Crew Max
    Retrax bed cover
    My 23 limited does the same thing, door check makes a noise. I can feel the vibrations coming right thru it. Tried all kinds of lubricants, nothing stops it. Dealer thinks it’s the door seal rubbing on the body, he lubed with silicone, no change. Ordered a new seal but has not come in yet. Seems to be worse in warm weather.
    Yoquiez951 likes this.
  8. Sep 15, 2025 at 3:04 PM
    Yoquiez951
    Yoquiez951 New Member
    So weird mine just started doing this today. Have you guys found a fix?
  9. Sep 15, 2025 at 6:39 PM
    ElectricMan
    ElectricMan New Member
    Same problem on my 23 limited. Mine happens with the rear driver side door however. Dealer said they couldn't duplicate the gripe. Im like, you cant miss it. listen... LOL
  10. Sep 16, 2025 at 3:47 AM
    Yoquiez951
    Mine just started today. It was a pretty hot day when the sun went down and no longer made the noise something to do with the heat. It definitely sounds like rubber and something gripping like a bushing.
