Weird light problem
Discussion in '2.5 Gen Tundras (2014-2021)' started by Rugerpooch, Jul 24, 2021.
  1. Jul 24, 2021 at 4:00 PM
    Rugerpooch
    Rugerpooch [OP] New Member
    Dean
    2019 tundra trd
    Hi all. New to site . I have a 2019 trd off road, after pluging in a rental trailer, immediately had signal problems . Unplugged and left for home . Now front lights signal and all work fine. Rear lights I only have brake . Also when I plug my trailer in ( good wiring ) , the lites all work on the trailer ( not rear of truck) except right signal is solid on . Totaly at a loss for this one . Checked all fuses and tested rear signal bulbs ..any help would be great before I take it in . Thanks in advance .
  2. Jul 24, 2021 at 9:38 PM
    Barrett50
    Barrett50 New Member
    Barrett
    Wisco
    2015 DC silver
    Did you try disconnecting the battery for 15 min or so?
  3. Jul 24, 2021 at 9:54 PM
    Rugerpooch
    Dean
    2019 tundra trd
    I did. Even checked all light bulbs. Really stumped. I have an appointment on Tuesday. Either way I'll post solution. Mabey there is a control module or something. Couldn't find a wiring diagram on line to check .
  4. Jul 24, 2021 at 9:56 PM
    Rugerpooch
    Dean
    2019 tundra trd
    Also ...to make things even more complicated....I have brake lights , but no hazards ????
  5. Jul 24, 2021 at 10:04 PM
    Barrett50
    Barrett
    Wisco
    2015 DC silver
    Pretty sure there’s a wiring diagram on here somewhere. That is strange. Hopefully someone will chime in with suggestions and you can solve before appt.
  6. Jul 25, 2021 at 6:20 AM
    Welcome from NY.
    Hopefully it's a simple fix.:fingerscrossed:
  7. Jul 25, 2021 at 7:47 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    I know stated you checked all the fuses.
    Make sure you checked the 30A TOW TAIL fuse and it's relay..
    Not saying that is what the issue is, but it's worth checking..
    Barrett50 likes this.
  8. Aug 1, 2021 at 7:46 PM
    BlancaLaGordita
    BlancaLaGordita New Member
    Blanca
    2021 Tundra TRD Sport
    would you be able to tell me where that relay is?
    I have no hazards either... all lights wok fine, all fuses check. didnt think about checking the relay but i can look tomorrow, would be nice if you can point me to it directly and minimize the looking.
    thank you ahead of time.
