Weird idle feeling and sounds
Discussion in '1st Gen Tundras (2000-2006)' started by Jayloud03, Mar 29, 2025.
  1. Mar 29, 2025 at 5:08 PM
    Jayloud03
    Jayloud03 [OP] New Member
    04 4.7 crew cab
    Hey all, I have noticed an odd sound and vibration whenever I have my truck (04 DC 4.7) in drive and stopped at a light or something. It happens with the AC on and off, it’s also sitting at 550-600 rpm when it happens but in neutral it’s not there same with park it’s lighter in reverse. Any tips or recommendations are appreciated!
    Thank you
  2. Mar 29, 2025 at 5:33 PM
    ATBAV8
    ATBAV8 New Member
    Tempe, AZ
    2003 V8 SR5, Access Cab, 4x4, White
    Have you checked your transmission fluid level and appearance/smell? I would start here. The next suspect would be the torque converter flex plate, but let's start with the easy stuff first. You didn't mention mileage or what, if any, maintenance has been done. Need a little bit of history...
  3. Mar 29, 2025 at 5:46 PM
    Jayloud03
    04 4.7 crew cab
    2004 DC 172k miles, new denso coil packs newer plugs, timing belt done 2000 miles ago, lbj done last week. Shifts fine but has recently started idling funny in drive it’s also 4wd
  4. Mar 29, 2025 at 5:58 PM
    ATBAV8
    ATBAV8 New Member
    Tempe, AZ
    No CEL? Have you checked?
    Jayloud03[QUOTED][OP] likes this.
  5. Mar 29, 2025 at 6:04 PM
    Jayloud03
    04 4.7 crew cab
    It occasionally pops a minor evap leak code which could be the issue but I suspect that would affect idle at all times. I’m just too lazy to put a smoke machine on it
  6. Mar 29, 2025 at 8:03 PM
    2WD or 4WD? Kinda important bit to share.
    ATBAV8 likes this.
