weird electrical shtuff
Discussion in '2.5 Gen Tundras (2014-2021)' started by hannum007, Nov 8, 2017.
  1. Nov 8, 2017 at 9:50 PM
    hannum007
    hannum007 [OP] New Member
    2015 platinum crew max Tundra
    K&N intake, toytech leveling kit, flowmax exhaust system,22"rims and fuel tires, tonou cover
    I have a 2015 platinum crew max w/31000 miles that until now has been awesome. Went hunting with the daughter and when we returned all electrical was dead. fob wouldn't work to unlock. i used the key and tried the unlock button not a thing imidiately I'm thinking did I leave the lights on but remembered they automatically turn off.
    Magically a minute later the dome lights came on and all electrical returned. I started it and ran to idle up like 5 sec and died. started it again and it ran.
    A week went by without issue and it reared its head again today as my wife got fuel. same thing all electrical dead completely. she called me and i came down tester in hand. sure enough truck was dead but when i tested the battery it had 13.1 volts. its in great shape.opened up fuse box and hadn't done a thing when the dome lights came on line. told her to start it and again quick run idle up/die, and dead system again no lights anywhere dash, mirrors and dead ignition. pushed on all the fuses to see if the were loose from all dirt road driving during hunting and it all came on line again.. told her to hurry up and start it and she did. it started and idled really low at around 600 RPM instead of its usual 1,100 . she drove it home and now it sits..... being all mysterious, unreliable and beautiful like a bad girl friend. Any one have some advice??
    4x4_Angel and GNTundra like this.
  2. Nov 8, 2017 at 9:52 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Rats eating your wire harness causing intermittent shorts?
  3. Nov 8, 2017 at 10:04 PM
    hannum007
    naaaaaah we have a force of cats . I've never even seen a mouse in the garage.. but .... maybe i have A short rubbed through the sheaving of a wire . I've looked and everything looks clean and protected. the truck hardly has that many miles on it :(
  4. Nov 8, 2017 at 10:09 PM
    hannum007
    GNT Tundra..hmmm I'll give it a try tomorrow after work and get back to ya . Thanks
    GNTundra likes this.
  5. Nov 9, 2017 at 7:45 AM
    Randy Morton
    Randy
    Deepinahearta, Texas
    2012 Tundra Double Cab (I call it my Land Yacht)
    I'd suspect a bad ground, or a bad battery. I've had a couple of batteries develop internal open circuits. They'll read the proper voltage with a meter, but they get flaky the minute the load hits. You could have a cell randomly opening and closing. For the ground, check all of the cables for corrosion and rust. The cable itself will corrode, but the connection to the body and frame could have rust. Good Luck, intermittent problems are the ones the mechanics hate the most.
    NewImprovedRon likes this.
  6. Nov 14, 2017 at 7:26 PM
    hannum007
    Hello everyone! I found the problem, although I'm a little embarrassed on how easy it was to remedy. I started with the ground bolt to the fender and the negative post(both were clean). I then moved to the positive terminal and found it was clean also, but the leads that bolt down to it had rattled the nut loose on all the dirt road driving I had been doing. They were loose and arcing causing the intermittent problem. I had cleaned and re-oiled the K&N and i think that was the culprit of the low idle. cleaned the MAS on the intake and she purrs once again. Thanks for the advice you guys!
    4x4_Angel, T-Rex266 and MotoTundra like this.
  7. Nov 14, 2017 at 7:28 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    Glad you are good to go, thanks for the update!
  8. Nov 14, 2017 at 7:56 PM
    Awesome Sauce
