Weird alignment question. Steering wheel not straight
Discussion in 'Suspension' started by Jwood562, Aug 21, 2020.
  1. Aug 21, 2020 at 10:31 PM
    Jwood562
    Jwood562 [OP] New Member
    2013 Tundra 4x4
    3" Suspension lift 18" method roost 35x12.5x18 ridge grapplers 2020 sequoia LED headlights
    So I got my new SPC UCAs installed today.
    truck was aligned at the same shop.
    shop is well know local shop that does everything from hot rods to off road.
    After the work I noticed the steering wheel is a couple degrees off tracking down then road.
    The alignment sheet shows everything good and in spec. Truck drives straight and brakes straight.
    It’s just when I am driving straight the steering wheel is a couple degrees off to the right, just slightly.
    any reason for concern?
  2. Aug 21, 2020 at 10:38 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Take it back, that would drive me nuts
    ForceV4 likes this.
  3. Aug 21, 2020 at 10:41 PM
    Jwood562
    2013 Tundra 4x4
    yeah it’s weird, it’s really only a couple degrees but it feels weird. My OCD was kicking in big time.
    It’s just weird to me that a UCA install could cause this. But I also know very little about alignments
  4. Aug 21, 2020 at 11:03 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    The alignment is probably fine, they just have to set the steering wheel indexed a little further to one side to make it even
  5. Aug 21, 2020 at 11:32 PM
    Jwood562
    2013 Tundra 4x4
    thank you so much.
    I didn’t know that they could easily fix this with another alignment and clock then steering wheel. Again, I know nothing about alignments
  6. Aug 22, 2020 at 12:04 AM
    Lyuluck
    Lyuluck New Member
    luck
    Don't worry, Look at the front, it’s okay if the car heading is correct, the steering wheel is not important
