Weight capability vs ride quality
Discussion in 'Suspension' started by 4xFourCorners, Oct 22, 2021.
  1. Oct 22, 2021 at 2:57 PM
    4xFourCorners
    4xFourCorners [OP] New Member
    2017 Tundra SR5
    I'm looking to put a 3" suspension lift on my 2017 SR5. I have a camper shell ordered, and will be adding a Warn semi-hidden winch setup with a 12k lb winch (~120lbs total) as well as an aftermarket rear bumper (85lbs) and rock sliders. I mainly use my truck for my remodeling business so it hauls materials and a 5x10 tool trailer that's pretty loaded down. For the next two years it's also going to be my family's only vehicle, used mostly for short commutes but also for some off road camping adventures. I have 4 and 7 year old kids so we have to take a lot of crap (my days of carrying everything I needed in a backpack are long gone). We're looking at adding a 2-3 person RTT to the top of the camper shell. I'm not trying to do any rock crawling, but we do like to get out away from the weekend warriors.
    So, long story short, I'm adding a bit more weight that I'll be daily driving with, and occasionally towing or carrying a lot more weight, sometimes off road. I'm looking for the suspension system that hits that sweet spot between reasonably comfortable unloaded and still capable when loaded. I'm really interested in what people with similar needs and setups are running and how well they like it or what they would do differently.
  2. Oct 22, 2021 at 3:00 PM
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    Official welcome
    4xFourCorners[OP] likes this.
  3. Oct 22, 2021 at 3:05 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    With what you are planning to add (accessories, mods weight) and hauling and towing, suggest you look at OME suspensions. They are designed for overlanding and hauling gear and loads. 3 different spring rates available- depending on load and if you will be using heavy bumper, winch, etc. You are going to need something heavy duty and reliable, OME is both.
    B.Ross and toyofan87 like this.
  4. Oct 22, 2021 at 4:14 PM
    4xFourCorners
    2017 Tundra SR5
    I've been looking at the OME kits, I guess my question would be that since most of the weight I'll be adding is in the rear would the 614 springs give me what I need performance-wise up front with a little smoother ride (vs. the 613s)? I expect to just see how the rear handles and add some weight in the back if it feels too stiff for daily driving.
  5. Oct 22, 2021 at 4:31 PM
    2mchfun
    With current shortages I dunno bro. Gonna likely be a fight to get anything. I would go wirh Dobinson's all around. Their HD leaf packs are great!!
    wexttxco likes this.
  6. Oct 23, 2021 at 6:06 AM
    frichco228
    Search this site (upper right) for OME suspension, there are some good threads and info. Also, give Toytec a call (link I posted), they can explain the different spring loads available. I have run OME on a few different vehicles, stout components, install and forget it and their stuff is great for load carrying. Had OME on my 4runner for the past several years and 70k miles, no issues ever and it still drives great- unlike some suspensions where the shocks lose dampening and need to be replaced or rebuilt every 40-50k miles.
  7. Oct 23, 2021 at 6:08 AM
    2mchfun
    OME leaf packs frequently squeak.
  8. Oct 23, 2021 at 8:44 AM
    4xFourCorners
    2017 Tundra SR5
    Would something like Icon's add a leaf work with the weight and towing requirements I have or am I going to need to swap in heavier duty leaf packs?
  9. Oct 23, 2021 at 9:30 AM
    2mchfun
    Dobinson's don't squeak.
  10. Oct 23, 2021 at 9:34 AM
    2mchfun
    There are band aids, and then there are stitches. When a wound requires stitches, band aids prove to be useless and a waste of money.
  11. Oct 23, 2021 at 9:35 AM
    CoffeeAddict
    CoffeeAddict New Member
    2016 Tundra CrewMax
    Ditto
    2mchfun[QUOTED] likes this.
