WeBoost Mounting?
Discussion in '3rd Gen Tundras (2022+)' started by loeky, Jun 1, 2022.
  1. Jun 1, 2022 at 7:40 AM
    loeky
    loeky [OP] New Member
    Haven't seen any chatter or posts about WeBoost antenna mounting options. Maybe too soon, but am interested for what anyone's been doing with this.
  2. Jun 1, 2022 at 8:01 AM
    What the!?
    What the!? New Member
    2017 Pro
  3. Jun 1, 2022 at 8:08 AM
    loeky
    Thanks. While the expo options abound w/ racks and RAM mounts, was curious for Gen3 specific approaches and wiring folks have done.
    I had mine mounted previously on the roof of my 100 series Landcruiser and routed to the rear power outlet, as example.
  4. Jun 1, 2022 at 9:18 AM
    KroppDuster
    KroppDuster A normal guy trying to survive this crazy world
    Here. There. Everywhere.
    2021 SR5 TRD Off Road - Cavalry Blue
    Bilstein 5100s
    Honestly...unless you're open to drilling into the cab to mount a roof rack...the only practical mounting solution that I can think of is a door-placement antenna mount. I would think you would put it on one of the back doors. If I did it, I'd likely do the rear passenger door that I use the least and then run the cabling along the inner door trim to a power source.
    I've used the Comet RS-840 on my 4Runner's rear hatch to mount my radio antenna for the longest time before I put on a roof rack. It was there for about 3 years before I relocated the antenna to the roof rack. If you mount it right, it doesn't damage the paint. Mine was on for about 3-4 years with no damage after I removed it. Diamond also makes a similar style with their K-400 series mounts.
    Here are some pics for reference. Top pic of the RS-840 and the bottom two are of the Diamond. Either way, doing a door mount like this is probably the only way to get the antenna above the roof line without a roof rack or a destructive option.
  5. Aug 1, 2022 at 4:38 PM
    MadMonk1967
    MadMonk1967 New Member
    2022 Tundra 1794
    I’d be interested in this too. There appears to be some grommets lower rear cab exterior. There are a lot of write-ups on cab entry, but not for the new Tundra that I can find.
  6. Aug 1, 2022 at 6:32 PM
    brobert225
    brobert225 Firm grasp of the obvious
    I am needing the same thing. Needs to mount behind cab between cad and bed. I have a folding mount so it can be lowered for wash etc. I have an idea for a cantilevered mount which will mount in bed and roll over under the tonneau and turn up 90 degrees for the mount. I’ll work on it when I get some time…..
  7. Aug 4, 2022 at 6:36 AM
    MadMonk1967
    2022 Tundra 1794
    I wound up going through the grommet near the front of my drivers side running board. Worked out great!
  8. Aug 4, 2022 at 6:40 AM
    MadMonk1967
    2022 Tundra 1794
  9. Aug 4, 2022 at 7:00 AM
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    I'm a fan of biting the bullet and drilling an NMO in the roof. If done right, it'll last practically forever.
  10. Aug 4, 2022 at 8:14 AM
    loeky
    Now we're talking! @MadMonk1967 - where did you end up plugging in the device itself? Also, what mount for good measure? I've the same retrax and love all things t-bolt now.
  11. Aug 4, 2022 at 8:28 AM
    MadMonk1967
    2022 Tundra 1794
    I hard wired it to the fuse box. The door sill/kick plates remove really easily and there is plenty of room for the wires. Mounted the booster under drivers seat. I have not decided where to put the interior antenna, right now I have it loose and want to experiment with a few locations. (Not really a fan of the suggested mount to side of seat).
    The mount is Rhino rack, pricey, but appears to be really well made.
    https://www.amazon.com/dp/B07B66Q59S?ref=ppx_yo2ov_dt_b_product_details
    Yes, I agree about loving all things t-bolt!
  12. Aug 5, 2022 at 7:44 AM
    loeky
    Mind sharing your wiring as well? Haven't dove into the Tundra yet but have done a bunch w/ my 100 series Landcruiser. Curious if you just did a buddy fuse tap.
  13. Aug 5, 2022 at 7:37 PM
    brobert225
    FWIW I have an NMO on the roof of my FJ. Great for 2m, but I think the WeBoost is a bit much for that mount.
