Weboost antenna mount ideas
Discussion in '2.5 Gen Tundras (2014-2021)' started by What the!?, Mar 24, 2022.
  1. Mar 24, 2022 at 8:46 AM
    What the!?
    What the!? [OP] New Member
    2017 Pro
    tweetlessfeags and HulkSmurf14 like this.
  2. May 11, 2022 at 10:58 AM
    YotaBro
    Calvin
    FL
    Lots of shenanigans.
  3. May 11, 2022 at 9:13 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Had pops snap some pics of his weboost mount. Used a couple mounts then directly to the GFC.
  4. May 12, 2022 at 8:49 AM
    YotaBro
    Calvin
    FL
    Is that a new antenna or something?
  5. May 12, 2022 at 9:14 AM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Yep thats correct. Weboost single booster antenna for remote locations.
  6. May 12, 2022 at 9:40 AM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    I went with a RAM mount and it works great. Poor pic but this is what it is like folded down - let me know if you want more.
  7. May 12, 2022 at 2:39 PM
    mountainpete
    I’m a fan of the RAM because it’s super easy to adjust, strong and I can pick any angle. My interior antenna is on the top of the windshield pointing down so I sometimes get reduced performance with the antenna pointing straight up.
    upload_2022-5-12_15-36-22.jpg upload_2022-5-12_15-36-37.jpg upload_2022-5-12_15-36-49.jpg
    2point5seconds and bulldog93 like this.
  8. May 12, 2022 at 3:08 PM
    pdiddy
    pdiddy New Member
    2017 platinum
    Icon 17 rebounds, total chaos UCA's, general grapplers 35's, corsa exhaust chopped, fox 2.5 DSC coilovers, DAP, white knuckle sliders, voodoo bed rack, baja lights everywhere, VLEDS, bedslide, C4 front bumper, warn winch, victory high hitch with dual swing out rear bumper
    I am using the rago mount for my weboost
  9. May 17, 2022 at 10:04 AM
    tweetlessfeags
    tweetlessfeags New Member
    2016 Platinum Tundra
    OME Nitrocharger Dakar Leaf pack+Add a leaf RCI Engine/transmission/differential/gas skid Bash Fabrication Weld-On Sliders Method 703-17" 0 offset ARB Dual compressor Victory 4x4 Engine bay compressor mount Cooper STT PRO 315/70/r17 Decked Drawers Cali Raised Led Ditch Lights WeBoost Reach OTR w/ Rhino Rack Aerial Mount Piaa SuperWhite Headlight bulbs Meso Customs Interior Light Kit Dometic CFX3 55IM Dobinsons Snorkel SnorkelUpgrade Precleaner GFC V1 AluCab Shadow Awn All the Tint
  10. Jun 12, 2022 at 10:19 AM
    Damie Street
    Damie Street New Member
    Edsel
    South Carolina
    2016 MGM CrewMax SR5 TRD OffRoad
    Thats actual a Marine antenna.
    Mater likes this.
  11. Jun 15, 2022 at 8:42 AM
    saleen079
    saleen079 New Member
    22 Tundra Limited TRD
    Lots of DIY stuff
    Where did you get that threaded adaptor? Amazon? I've been looking for a solution like this for the weboost on my travel trailer.
  12. Jun 15, 2022 at 9:59 AM
    mountainpete
    Pretty sure I got it from https://www.gpscity.com/
  13. Jun 15, 2022 at 12:56 PM
    saleen079
    Lots of DIY stuff
    Thanks man! This was just what I needed.
    mountainpete[QUOTED] likes this.
  14. Jul 31, 2022 at 7:05 AM
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    @mountainpete @pdiddy @tweetlessfeags how did you route your antenna cable into the can and where is your located. My antenna cable seems pretty short. Not sure I’ll make it to the center console like I’m hoping. TIA!
  15. Jul 31, 2022 at 8:02 AM
    saleen079
    Lots of DIY stuff
    I'm using a small magnetic antenna for the truck and the big torch lookin one on the camper. Mounted mine just above the B-pilar on the divers side. Then mounted the inside antenna on the lower left side of the console. In ad to add a 12v socket inside the console for the power source. Just tapped into the USB power for that one. Ill load pictures shortly.
    Mater[QUOTED] likes this.
  16. Jul 31, 2022 at 8:49 AM
    mountainpete
    I have the Weboost unit installed under the passenger seat. The antenna goes through the floor drain plug, along the frame (zip tied) and then up the front of the box and canopy. It’s a little ghetto, but it’s held in place as it goes up the canopy with Gorilla tape as I did not want to drill into the canopy. It used most of the stock cable.
    I ran the interior antenna from the booster under the passenger seat up the passenger A-pillar, along the windshield and attached it to the glass on the drivers side of the mirror.
    After using the unit for some time, I would not place the interior antenna on the windshield again (although cosmetically it’s a great install point). At times I get some attenuation between the two antennas, especially if the exterior antenna is pointing straight up. I can tell when that is happening because the performance degrades and I get flashing on the Weboost when I power it on.
  17. Jul 31, 2022 at 10:10 AM
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
  18. Aug 1, 2022 at 6:01 AM
    tweetlessfeags
    Drilled a hole in the back of the cab, silicone and a rubber grommet. Ran the cable along the door jamb(pulled up the small plastic piece at the edge of the door). Then mounted the weboost module under the driver seat on the carpet. I had way more cable from the booster to the switch than the antenna to the booster.
    I'll try to get some other pictures later.
  19. Aug 1, 2022 at 8:52 AM
    pdiddy
    pdiddy New Member
    2017 platinum
    Mine is also wired to under the passenger seat. Don't think my cable would have gone from the rear tail lig
    Mater likes this.
  20. Aug 1, 2022 at 9:10 AM
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    Thank you all for your ideas. I’m doing to try to run the antenna wire and make it to the passenger seat going through the grommet under the rear passenger seat floor board. Probably just plug it into the center console and put the internal antenna on a dash mount
    pdiddy likes this.
  21. Dec 8, 2022 at 6:25 AM
    2point5seconds
    2point5seconds Wish I didn't have so much money
    Sensei
    Nor Cal
    2019 Tundra SR5 TRD 4WD Double Cab
    Icon Stage 9 lift, 700 pound rated Eibach spring, Sumo Springs (rear), RCI engine skid plate. RCI Lower Control Arm Skid Plates, RCI Transmission Skid Plate, RCI Cat Guards, Rago dash plate. RAM phone holder. Bed rails. Tint. 17x8 Icon Rebound wheels. 315/70/r17 Falken Wildpeaks. AAC Trigger 6 Shooter, midland MTX-115 radio, Chassis Unlimited front bumper, OLB Bar light and ditch lights, Baja Fog lights, Smittybilt winch, Husky floor liners, bed rail, Cali Raised Bed Stiffeners, driver's side grab handle, Wheeler's Offroad front bump stops, Decked Tool Box
    I went with a RAM Mount too for my Weboost antenna. I have it connected to my bed rails on the drivers side since I do not have a bed rack or camper. Do you use your Weboost while driving? If so, how do you keep the antenna up? The RAM Mount doesn't stay up due to wind. I have it leaning against my Decked Toolbox. I'm thinking of talking to a fabrication shop to see if they can build a Mount that folds down when I'm not using it.
  22. Dec 8, 2022 at 6:49 AM
    mountainpete
    Yes, I use the antenna up while driving. I have had no issues with it staying upright. You need to crank the Ram mounts pretty hard until they settle in.
  23. Dec 8, 2022 at 6:57 AM
    2point5seconds
    Sensei
    Nor Cal
    I must be weak. I thought I had it cranked down pretty hard. LOL. I'll try again and see if I can get it tighter. I just thought that ball near the base made it slippery and it would never stay upright while driving. When I initially try it, the antenna fell down eventually. Had to pull over and bungee it so it would stay up while leaning on the Toolbox
  24. Dec 8, 2022 at 2:19 PM
    2point5seconds
    Sensei
    Nor Cal
    Are you using the full antenna or did you choose to use the shorter arm? There's different options when putting it together. I think i used the longer arm.
  25. Sep 27, 2024 at 3:33 PM
    Hammertimerrrr
    Hammertimerrrr New Member
    2024 MGM Limited OR
    Trying to figure out how to get my WeBoost Overland properly mounted to my truck... I had a Prinsu on my Taco so it was easy and while ghetto, I just had it mounted to a roof rack bar and ran the cable through the door trim. It wasn't super clean, but IT WORKED very well. Now I've got this Tundra with the pano sunroof - which I won't be covering up with a rack, and don't want to create a mess of wires... Seems the best option is for me to mount to my bed rack, work hard to conceal the cable, run under the truck and up through the drivers seat drain plug? Any other solutions folks have found that are clean but unobtrusive?
    I'd rather have the power run to the battery but all I have for the WeBoost is the cigarette lighter power adapter. Is there layperson's solution to avoid having more wires running all over?
  26. Sep 27, 2024 at 6:20 PM
    ConcordCarlos
    ConcordCarlos New Member
    Carlos
    2021 Tundra SR5
    @Hammertimerrrr if you have ditch lights , you could make a bracket to mount it to one of those. Could run the wire into the engine bay , and then internally from there.
    Hammertimerrrr likes this.
  27. Sep 27, 2024 at 6:37 PM
    What the!?
    2017 Pro
    You could use of the RagoFab antenna mounts:
