Weathertechs with tundra badge
Discussion in '2.5 Gen Tundras (2014-2021)' started by Nebz, May 3, 2015.
  1. May 3, 2015 at 4:04 PM
    Nebz
    Nebz [OP] New Member
    Orlando
    2014 Magnetic grey SR5
    Front Mesh Grille upper and Lower, Factory Steps, Flipbak cover, Spray in liner, Ballistic Sythe wheels, weather tech liners with tundra badges
    I had my weathertechs come in this weekend. I ordered the tundra badges on eBay that replace the weathertech stickers. I had to drill four small holes for each badge and then they use screws and lock nuts to keep the badges in place.
    khunk, N8Dizzle, 2TONYJ and 6 others like this.
  2. May 3, 2015 at 8:58 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
  3. May 3, 2015 at 9:05 PM
    Very cool. I haven't seen this before.
  4. May 3, 2015 at 9:43 PM
    csuviper
    Broomfield, CO
    Better than this
    Don't have to take them off. They fall off themselves
    MotoTundra likes this.
  5. May 4, 2015 at 3:21 AM
    pmedic048
    pmedic048 Pull away from the herd, drive a Tundra!
    SC
    2008 SR5 Dbl Cad, 2015 SR5 CrewMax 4x4 and 2016 TRD Limited 4x4
    3" front spacer lift and 2" rear spring lift. 20" Fuel rims with BF Goodrich G2 33.5s and Volant cold air intake.
    Very cool, does the head of the screws rub against the carpet at all? You said you found the plates on ebay, can you share the link or the name of the seller. ;)
  6. May 4, 2015 at 4:35 AM
    Nebz
    Orlando
    It looks like the seller changed them to "off road" in the new listing.
    http://www.ebay.com/itm/181703360449?_trksid=p2057872.m2749.l2648&ssPageName=STRK:MEBIDX:IT
    I agree 30 bucks was steep but I received the mats as a gift so I could justify it. The lock nuts are really small so I don't think they will damage the carpet in anyway.
    I found these TRD badges after I puchased mine and they are only 12.23, I did not check to see if they fit the weather tech mats though.
    http://www.ebay.com/itm/NEW-2PCS-TR...fits=Model:Tundra&hash=item2c91ef02a0&vxp=mtr
    pmedic048 and scratchex like this.
  7. May 4, 2015 at 6:26 AM
    FunkinTundra
    FunkinTundra New Member
    Cody
    2012 Tundra 5.7 CM
    OME614 full suspension\ Ekstrom design 3" shackles and poly bushing kit\ 295/70r18 Toyo MTs/ +20 offset Fuel Anzas\ 8" BAmuffler....etc...
    Wow thats pretty cool!!
  8. May 4, 2015 at 5:32 PM
    Virgils12
    Virgils12 New Member
    Camburg Fox factory 2.5" lift Xd monsters with 295/70/18 nitto terra graplerrs Corsa cat back Weather tech liners Wet okole covers
    The trd ones look to be a lil big by my math. The tundra ones show 4.6" where the trd ones show 110mm= 5.3".
  9. Jan 14, 2016 at 10:37 AM
    Tracker
    Tracker New Member
    Shane
    Colorado, Denver Burbs
    2016 Silver Tundra SR5 Lifted
    So after this time has gone by are the badges worn from use or scratched up?
  10. Jan 14, 2016 at 1:29 PM
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
