Weathertechs on a 2016 Tundra...
Discussion in '2.5 Gen Tundras (2014-2021)' started by MidwestOverlanders, Oct 7, 2015.
  1. Oct 7, 2015 at 3:06 PM
    MidwestOverlanders
    MidwestOverlanders [OP] New Member
    Cody
    2016 MGM Tundra TRD Pro
    295/70R18 Cooper STT Pros, Spidertrax 1.25" spacers, Tyger bed cover
    I ordered some third gen Weathertechs liners (fronts and whole for back). I'm not super impressed with the fit of the back mat. It cutouts for the seat frames are big enough and the edges flap out and have nothing to hold them down. So now the doors just crunch them. 9aae3f5cd202d86dff8853271b77dccf_a9420ca1e128856d262f1e3af21c3c2d2c056fb6.jpg8c4b23ec2f8a8edd8679080d27cb68af_26805e072d2fddfcf1ebed255da9fe86d00794ad.jpg
    Anyone run into this or have a fix?
    Thanks
    Cody
  2. Oct 7, 2015 at 3:32 PM
    Paulskie
    Paulskie New Member
    Paul
    2014 Attitude Black 1794
    SABM, TRD sway bar, interior LED swap, Husky's in front and WeatherTech in the back, TRD Pro Grill, Rigid Fod lights, Rigid 40" E-series, Rigid 32" hood light, BLHM with RX350/STI projectors, 4% tint, 50% windshield.
    I've had same thing happening in the beginning and what worked for me is to leave it out in the sun for couple hours and then install it in the truck. Worked like a charm.
  3. Oct 7, 2015 at 3:34 PM
    MidwestOverlanders
    Cody
    Thanks! I'll give that a try and report back.
  4. Oct 10, 2015 at 11:02 PM
    Tacogrande
    Tacogrande New Member
    Jeremy
    2016 SR5 dbl. cab long bed gray
    Husky weatherbeaters,short antenna,window deflectors
    Weathertech does not list floor mats for 2016 Tundra...could this be the fit problem? Toyota changed the floor a little bit and Weathertech does not have the 2016 product ready yet?
    I would never be happy with the fit in your pictures.
  5. Oct 11, 2015 at 4:15 AM
    AMRE2ME2
    AMRE2ME2 New Member
    2016 DC 4x4 Limited TRD
    2014-2016 are all exactly the same. Toyota didn't change anything to the floors.
  6. Oct 11, 2015 at 5:28 AM
    MotoTundra
    MotoTundra The Ocho
    Don
    Gravity will help them lay like they should. It's just from the way they are packaged.
  7. Oct 11, 2015 at 7:23 AM
    15whtrd
    15whtrd Mr. Blonde
    I went with the weathertech over the Husky because rear floor coverage. So if I take out my storage compartment under the rear seat everything is covered for the most part. They do fit kind of lame because the edge is so thin, and the door will crush it if it's not totally flush with the doorsill. The fronts are another story, if your foot is next to the door when you close it, it will grab the lip of the mat and lift it up. The passenger-side slides all around. If I were to do it again I would've got husky for the fronts WT rear. Although I'm not real satisfied with the wt in general. I wish the Husky would offer full coverage for the rear seat floor.
    Quik likes this.
  8. Oct 11, 2015 at 5:47 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    They do now. At first I bought Husky's front and back (crewmax). Then WT came out with theirs, which have a much nicer rear, so I started looking into it and noticed Husky updated their rear design to match WT's coverage so I called them to see if they could cut me any break since I bought from them direct and they improved their design shortly after my order. They offered nothing, weren't even nice about it. I ordered a WT rear and I love it.
    15whtrd[QUOTED] likes this.
  9. Oct 20, 2015 at 6:18 PM
    Ttprodr
    Ttprodr New Member
    15 CM 4X4 Tundra
    18x9 level 8 Guardian wheels 275/65/18 Coopers ATP Weathertech Mats (black)
    It will settle down,mines were like that too,i did put a little piece of two sided tape at the doorsill for few days then stays in place but it will settle down on its own regardless, no biggie
  10. Oct 22, 2015 at 5:14 AM
    PlatinumPro
    PlatinumPro New Member
    2015 PlatinumPro Crewmax
    Bilstein 6112+5100s, Rigid Lighting, Fuel 20x9 Bronze Blitz
    after having both weathertec and husky liners now i would go with husky every time. the material is far superior, the channels are deeper in the mats and the x-act contour fit spot on in my fronts. i have however heard they don't sit as nice on the floor in the back.
  11. Oct 22, 2015 at 8:12 AM
    Love mine!
  12. Oct 22, 2015 at 7:52 PM
    PlatinumPro
    hard to argue with that! they look like they lay as flat and perfect as the fronts do
  13. Feb 17, 2016 at 6:43 AM
    sstoddard
    sstoddard New Member
    Shawn
    2019 Crewmax Sport
    Alarm/start (Compustar Ft7000,Rf2wl1b 2-way remotes and Drone Mobile) Tailgate inserts NSV Lightbar Tailgate actuator Blacked out decals
    I've had both. The weathertechs last longer and are more durable. I have found that the ribs for the channels wear down or tear after after a while. What I have done in the past is installed the hook part of velcro to the mats. Holds them in place really well. There are no fasteners in the passenger floor so this keeps it in place.
  14. Feb 17, 2016 at 8:58 AM
    racervx54
    racervx54 New Member
    2015 trd pro inferno
    Well it was in a box so yea
  15. Feb 17, 2016 at 12:36 PM
    DBL TAP
    DBL TAP Light 'em up
    USA
    Take them out, turn them inside out and leave them that way for 24 hours in a warm place. The plastic has memory and this procedure will bring them back and help with a loose fit. If you called Weathertech customer service they would tell you to do this. Been there, done that. Good luck.
  16. Feb 17, 2016 at 1:27 PM
    CHESSIEMAN
    CHESSIEMAN New Member
    STEVE
    PA
    2025 ICE CAP RALLY CREWMAX
    HEATED MY FRONT MAT WITH A HAIR DRYER TO GET IT TO LAY DOWN, BACK MATS WERE FINE!!!!
  17. Feb 18, 2016 at 5:27 PM
    MGL
    MGL New Member
    2016 limited cm trd
    none for now
    Front was nice fit but back didn't. So i returned it and ordered Husky weather beather. much better
  18. Mar 13, 2016 at 2:13 PM
    mjvr2c
    mjvr2c Going Places!
    Elizabethtown PA
    2016 SR5 Dbl Cab 4x4 TRD 4.6
    Accessorized NOT Modified: Raptor Running Boards, Extang EnCore Tonneau Cover, LineX Spray-In Bed Liner, EGR Hood/Bug Deflector & Window Vents, Husky Rubber All-Weather Floor Matts.
    Have any of you used the WeatherTech TechLiner (Bed Liner) & Tailgate Cover?
  19. Mar 13, 2016 at 2:16 PM
    MGL
    MGL New Member
    2016 limited cm trd
    none for now
    I returned it and ordered Husky weather beather. much better
    T-Rex266 likes this.
  20. Mar 13, 2016 at 2:26 PM
    mjvr2c
    Elizabethtown PA
    ??? I could not find a Husky Bed Liner?
