Weatherstripping
Discussion in '1st Gen Tundras (2000-2006)' started by NWTundra06, Aug 12, 2020.
  1. Aug 12, 2020 at 1:42 PM
    NWTundra06
    NWTundra06 [OP] New Member
    06 Tundra AC TRD
    Replaced the driver's side weather stripping. Was pleased to notice reduced road noise.received_771695313593605.jpg received_773460680112478.jpg
  2. Aug 12, 2020 at 1:45 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Nice! I wish these parts were not so expensive. I'd like to do mine and the window trim.
    Tundra2 and Darkness like this.
  3. Aug 12, 2020 at 1:47 PM
    NWTundra06
    06 Tundra AC TRD
    You aren't kidding about the $$. I'm going to be careful with how I step on the door plate when loading items up top...
    Tundra2 likes this.
  4. Aug 12, 2020 at 2:15 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    The cost is justified. To extrude a "wire carrier" (metal thing inside the weatherstrip) inside a rubber cavity is a tedious, and tricky job to get everything to set correctly.
    Not to mention needing to cut the extrusion to length, and then mold the ends together.
    All these processes are 20 years old for our trucks, and in my eyes will only get more expensive as the equipment used to create these are used less, and less.
  5. Aug 12, 2020 at 2:58 PM
    Professional Hand Model
    Hand Protectors
    Good on ya! Put some Aerospace 303 on them to keep them fresh and new looking. Has UV protection and even fluffs/restores up old weatherstripping even though its not sold as such.
    Anyone else reading, it helps to pull these back and clean behind them on occasion to get the dirt/crud build up out.
  6. Nov 29, 2020 at 10:45 AM
    CarterBO
    CarterBO New Member
    2001 Tundra SR5 Access Cab 2WD
    Does anyone have the part numbers for the Drivers and Passenger side weather stripping? For some reason all I can find is door-specific. Mine is all torn about the same way yours is.
    2001 Access Cab SR5 4.7L-V8
  7. Nov 29, 2020 at 12:20 PM
    HBTundra
    HBTundra New Member
    2006 DC 2wd
    Nice work! I bet that wasn't easy.
    Yeah, as the 'Hand Man' mentioned above, I frequently put some 303 protectant on a small rag and go over and inside all of my weatherstripping. I don't look forward to tackling that project. Good on ya!
