Ways to bypass acc/windows/lights?? '21 TRD Pro
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by MrJonnb, Jul 19, 2021.
  1. Jul 19, 2021 at 3:24 PM
    MrJonnb
    MrJonnb [OP] New Member
    Northeastern ALberta, Canada
    2021 Tundra TRD Pro-Lunar Rock
    Are there ways to be able to
    1 - Use the windows with the key off but acc on?
    2 - Turn off headlights when parked and running?
    3 - Shut the door chime off????
  2. Jul 19, 2021 at 3:34 PM
    jimbrophotodotcom
    jimbrophotodotcom New Member
    Hawaii
    2021 Lunar Rock Tundra TRD Pro
    IG: @LunaTheTundra, Coachbuilder kit and 35s soon
    Carista can turn the chime off i believe. the other stuff not too sure.
  3. Jul 23, 2021 at 12:25 PM
    great.white.PRO
    great.white.PRO New Member
    Missouri
    1. Maybe I'm misunderstanding you but you can roll windows down in accessory mode.
    2. If you set it to DRL off that will turn everything off
    3. The chimes are annoying for sure but @jimbrophotodotcom is right I believe Carista can turn those off.
  4. Jul 23, 2021 at 1:21 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    I think this only works if you were previously in the "ON" position and have not opened a door yet. Just hitting ACC with the key from OFF does not let you control the windows, at least in my 2018.
    MrJonnb[OP] likes this.
  5. Jul 23, 2021 at 1:26 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    there is a timer on my 19, i believe is like 30 sec. canada cannot turn head light off,
    TRDFerguson[QUOTED] likes this.
