Water tank options
Discussion in '2.5 Gen Tundras (2014-2021)' started by PaulROahu, Sep 24, 2021.
  1. Sep 24, 2021 at 10:13 PM
    PaulROahu
    PaulROahu [OP] New Member
    Paul
    Kaneohe, Hawaii
    2017 5.7 Tundra Platinum 4x4 MGM
    I’ve been researching for a while for a good water tank unit. This one is an (8) gallon that is self pressurized using the provided water hose attachment at 40 psi. I used my Yakima HD over haul truck rack, then used the side mount rail that holds 100# each bar and custom mounted (2) on one side to property secure the tank. Came out pretty good and utilized the extra space on my rack. Already ordered another set side bars and thinking of mounting other accessories later. What do you guys think I should mount and any feedback on other water tank mounts?
  2. Sep 25, 2021 at 9:05 AM
    2mchfun
    I use recycled drums from food products. 12 volt rv pumps give pressure on demand.
    PaulROahu[OP] likes this.
  3. Sep 25, 2021 at 9:11 AM
    timsp8
    NY
    There was another brand that I can’t remember now. Waterport maybe. It had a hand pump to pressurize it but I remember it being ridiculously expensive.
  4. Sep 25, 2021 at 9:37 AM
  5. Sep 25, 2021 at 9:40 AM
  6. Nov 7, 2021 at 8:37 AM
    Damie Street
    Damie Street New Member
    Edsel
    South Carolina
    2016 MGM CrewMax SR5 TRD OffRoad
    Yakima Road Shower. They have a 7 and 10 gallon option.
  7. Nov 7, 2021 at 8:54 AM
    mgxsequioa
    mgxsequioa New Member
    The water port is sometimes available with more accessories at a lower price through Costco. I have it mounted under the Diamondback cover at the front and have found it to be perfect for rinsing off everything after a day on the beach. You can use either an air compressor or bike pump to add pressure.
    15whtrd, Mater and PaulROahu[OP] like this.
  8. Nov 9, 2021 at 7:32 AM
    3jet3
    3jet3 New Member
    FL
    2021 Tundra TRD
    ----Suspension---- 6112 Bilstein Front 5160 Bilstein Back 3 CB .5" Shims(2 driver side, 1 passenger) CB 3+ Shackles Differential Drop kit Carrier Drop kit ----Wheels---- Tires - Falken WildPeak A/T- 295 70 18 Wheels - Raceline Gauge 18" ----Accessories---- GoRhino RB20 Running Boards
    Thats sweet!
  9. Nov 9, 2021 at 7:49 AM
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    Saw an outfit last weekend. He used 8 inch plastic pipe with a fill, a place to pressurize it and an outlet (sprinkler head), painted it black and has a hot shower at the end of the day provided it is sunny out! Looked like a nice home made unit that gives you a shower when wanted. Hooked it up with big hose clamps and some rubber on the side of a rack on the bed under the pop up tent. He had all sorts of nice gadgets!! Saw lots of off-road vehicles, all Toyotas!!! The only Tundras that were there was mine and the daughter. It was at HTX Toyotas gathering at a dealership just South of Houston 15 minutes or so.
  10. Nov 9, 2021 at 9:31 AM
    Damie Street
    Edsel
    South Carolina
    There are a ton of YouTube videos on this. It’s a cool little project, if you have a roof rack to secure it to.
    Black@Blue19[QUOTED] likes this.
  11. Nov 9, 2021 at 10:46 AM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    Can I see what that looks like? Just curious cuz my head keeps thinking drum set that had food in it :rofl:
  12. Nov 9, 2021 at 10:50 AM
    2mchfun
    Plastic barrel with a 12v rv pump turns on when pressure drops then turns off when the valve is closed. Simple pressure switch operation. Don't have access right now for photos.
  13. Nov 9, 2021 at 11:11 AM
    Damie Street
    Edsel
    South Carolina
    Would love to see pics when your able to post
  14. Nov 9, 2021 at 11:18 AM
    Jhon
    Jhon New Member
    On the Oregon Trail
    2021 SR5 TRD OR
    I built a system using a pump I ordered from the United Kingdom designed for a camper van. I used a Scepter MWC and bought a spare cap to install the pump and wiring to. I used a cheap camper van faucet with a 12v switch installed in the knob. You cracked the faucet open and it turned on the pump, pretty slick. I never really used it for anything but if I were I would have added a toggle switch and a simple quick connect on the cap to run a shower hose.
  15. Nov 9, 2021 at 11:35 AM
    Damie Street
    Edsel
    South Carolina
    :worthless::worthless:
    Jhon[QUOTED] likes this.
  16. Nov 9, 2021 at 11:38 AM
    Jhon
    Jhon New Member
    On the Oregon Trail
    2021 SR5 TRD OR
    I'll need to try and find the pump and faucet in the attic. I keep meaning to find a 10ish gallon water tank to play with. I think the pump installed into the tank with a remote switch and a quick connect similar to an RV outdoor shower would be pretty awesome for rinsing the sweat off in the summer or doing dishes at camp.
  17. Apr 10, 2022 at 8:16 PM
    ccdawnpatrol
    ccdawnpatrol New Member
    Salt Lake City, UT
    2017 SR5 MGM CM 4x4 5.7L
    I like your set up. I am headed to Moab in a couple of weeks for a mtb trip with some guys and wanted to look into some water tanks. Never bit the bullet on the Waterport and it is $250 through Costco at the moment. But what brand/model is yours? Thanks for any info.
    Mater likes this.
  18. Apr 10, 2022 at 8:43 PM
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    I was waiting for the waterport to drop in price. I saw it once at 179 and thought about jumping on it and didn’t. Waited for it to go from 199 back down. Guess I was hoping it’d hit the $130/140 mark like in years past. :frusty: Kicking myself pretty hard right now. Waterport is right up the road from me, so I’ll just keep calling and hopefully catch someone on a good day :playball:
  19. Apr 10, 2022 at 8:49 PM
    PaulROahu
    Paul
    Kaneohe, Hawaii
    Yes mines is the 8 gallon pressurized water tank. Love this brand was debating between waterport and Yakima. Picked waterport due to custom mounting on my side bars using custom mollie rig brackets. Came out how I envisioned it. The other side has a large fire extinguisher and flexible 54” tire tracks. Plus I have a low profile mini truck box for my items needing better security
