Water Spots on paint
Discussion in 'Military' started by pat357, Jul 9, 2020.
  1. Jul 9, 2020 at 11:39 AM
    pat357
    pat357 [OP] New Member
    Patrick
    I have a 1794 in Magnetic gray. The water sucks where I live and it leaves water spots on the paint. I was wanting to know what you folks use to get the water spots off?
  2. Jul 9, 2020 at 11:51 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    a quality polish...then wax and maybe topcoat with bead maker or some similar product. Keeping the truck well waxed and protected will reduce or eliminate water spots going forward.
    BravoDeltaRomeo and ToyoMafia like this.
  3. Jul 9, 2020 at 12:23 PM
    Sunfish
    Sunfish New Member
    17 4X4 CM Limited
    Spray a 50/50 mixture of distilled white vinegar and water on it in the shade. It will remove them but it needs to set a couple minutes before wiping dry
  4. Jul 10, 2020 at 9:11 AM
    pat357
    Patrick
    Thanks I will try both options. Both you guys are Awesome
  5. Jul 10, 2020 at 9:22 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Would the vinegar eat into the clearcoat? Ceramic coating?
