Water Pump question
Discussion in '1st Gen Tundras (2000-2006)' started by AZ59apacheguy, Jan 10, 2017.
  1. Jan 10, 2017 at 1:44 PM
    AZ59apacheguy
    AZ59apacheguy [OP] New Member
    Pete
    2003 SR5 TRD Tan
    Bought my '03 from my Father in Law two months back. At the time of sale he said he recently had the timing belt changed ( @ 92,000 now has 120,000 ). When looking back at all the receipts he kept, I found the one pertaining to the timing belt replacement. On that receipt, it said nothing about changing out the water pump. I can only assume that it is the original because it was not on that invoice and I found no other invoices showing a water pump being replaced. I know that it is common thought to change the water pump out with every timing belt change. I have two questions: First, how long do the '00-'06 4.7L water pumps usually last. Second, does the timing belt need to come off to install a new one?
  2. Jan 10, 2017 at 2:02 PM
    Yes it is common, no the timing belt doesn't need to come off (to my knowledge), and they last anywhere from 20k miles to very high mileage.
  3. Jan 10, 2017 at 2:25 PM
    Mike Tread lightly.
    south carolina
    My water pump on mine lasted me till 145 xxx on the clock before I pulled it. It still didn't leak anything put since the timing belt was out out with the pump. ..
    As long as you use Toyota red antifreeze you should be fine.
  4. Jan 10, 2017 at 4:40 PM
    AZ59apacheguy
    Pete
    2003 SR5 TRD Tan
    Hi. Thanks for the replies. It does have red antifreeze in it right now and looks clean and not discolored in any way. Hopefully it last till the next timing belt swap
  5. Jan 10, 2017 at 6:30 PM
    shaw0531
    shaw0531 New Member
    Jake
    2006 Spectra Blue Mica Tundra SR5 2WD DC
    Mine went at 135k. And yes the timing belt does have to come off when you change it. That's why most change everything at once, don't have to mess with it twice and it's all in the same area. Changing them out ain't like on most vehicles where it's relatively easy to do.
    ColoradoTJ likes this.
  6. Jan 10, 2017 at 6:50 PM
    ej63090
    ej63090 New Member
    Eric
    McHenry, Illinois
    2017 White Crewmax SR5
    This is interesting to read as when I wrote service for Toyota our thought on why their water pumps went out so often was the mixture content of the pink super long life coolant. my Corolla had coolant leaking from the weep hole at about 20-25k so I changed the pump and put the long life (red) coolant back in.
  7. Jan 12, 2017 at 5:22 AM
    Mike Tread lightly.
    south carolina
    The coolant has a different type of lubricant in the antifreeze for the pumps seals and bearing.
  8. Jan 12, 2017 at 5:33 AM
    No kidding. That would suck to pull the Timing Belt for a water pump.
  9. Jan 12, 2017 at 5:26 PM
    AZ59apacheguy
    Pete
    2003 SR5 TRD Tan
    I agree :-(
    Here's to hoping it last till the next ( or close to ) timing belt change :)
  10. Mar 7, 2017 at 2:36 PM
    mtntop
    mtntop New Member
    2004 4x4 Access Cab SR5
    I had my TB changed at 90k on my 2004 tundra by a local Toyota mechanic I have used since 1996, he did not change the pump at the time and told me he rarely sees them fail. I am at 180k and no issues with the pump yet, but he did tell me that he would change the pump at the next belt change which is now. I have always used the Toyota OEM radiator fluid which is red since 2004
  11. Mar 7, 2017 at 6:26 PM
    tomsinamerica
    tomsinamerica New Member
    Tom
    Wilmington, NC
    White 2016 Tundra DC ltd
    I think people do it with the timing belt since you're in there and the part isn't that spendy. If it's not been done, I wouldn't lose sleep over it... if it craps out and you're vaguely aware of your dashboard, you should realize before any damage is done - yes - may leave you stranded but won't cost you any more to fix then than it would now.
  12. Mar 8, 2017 at 8:49 AM
    chunk
    chunk New Member
    110 miles north of Los Angeles, Ca.
    2001 SR5 Tundra, 2WD
    Bone stock, original owner
    Since you're paying labor to have it done, and on the original pump i would change it with the timing belt this time around. I did the pump and belt at around 75 000 miles. Cheers.
