Water on the front passengers floor
Discussion in '1st Gen Tundras (2000-2006)' started by Tundra Tommy, Jan 26, 2023.
  1. Jan 26, 2023 at 5:58 AM
    Tundra Tommy
    Tundra Tommy [OP] New Member
    During heavy rains and periodically at the carwash I'll notice water on the floor of the passengers side. Any suggestions will be appreciated.
  2. Jan 26, 2023 at 6:07 AM
    NCrunner2012
    NCrunner2012 New Member
    Steven
    2007 Tundra Limited 4x4
    If you have a sunroof, make sure the drain lines are not clogged.
  3. Jan 26, 2023 at 6:14 AM
    Mustanley
    Mustanley Two time totaler
    Hendersonville, NC
    2004 Limited TRD 4x4 DC
    Eibach Shocks/Coils|Doug Thorley Headers|Spintech 3000XL Muffler
  4. Jan 26, 2023 at 7:05 AM
    GXPaycheck
    GXPaycheck New Member
    Central NC
  5. Jan 26, 2023 at 9:00 AM
    shifty` All my rowdy friends have settled down
    Yeah, that guy puts out crazy content. :rofl:
    But seriously, @Tundra Tommy, if you look at the video posted on that 1st reply in the thread, it shows the exact cause. It's a well-known problem for these trucks. Search the thread for the word "cowl" for part numbers, instructions, etc.
  6. Jan 27, 2023 at 7:30 AM
    Schcoman
    Schcoman From behind the Redwood Curtain
    Humboldt Co. CA
    2000 Access Cab 4.7L V8 4x4 SR5
    None
    Mine does that only when it really rains hard, just a few drops. It's rained really big time here lately and I only get a few drops. I was aware of the cowl/scupper issue, this thread helps shifty. Thought I was in for a heater core. Not really concerned about it at this time, hope the OP gets it fixed.
    Funny aside: A year ago I had lots of water on the carpet/floorboards after driving with the defroster on during a big downpour. Next day, no rain, no wet floorboards. Took a trip down south and used the AC, floorboards soaked! Found the little drain tube at the bottom of the HVAC box that goes through the firewall had disintegrated. Dealer part two weeks back order. Solution (I had a 750 mile drive ahead of me) was some stock heater hose and a zip tie, worked like a dream.
    shifty` likes this.
  7. Jan 27, 2023 at 8:01 AM
    Yup, this is the main reason for the 2nd paragraph in that definitive leak thread, gotta make sure condensate isn't the issue :rofl:
    And while I hear you on the "it's just a couple of drops", but here's the thing... at least down here in the SE USA, a few drops lead to foggy interior windows in the winter, and in the summer, it'll lead to a mildew outbreak in your vehicle.
    Once mildew gets rooted in your interior fabric, vinyl, rubber, and plastics, you CANNOT get rid of it. All it takes is one spot you've missed, and that spot will spore your entire truck again once any humidity is in the air, and re-seed itself. It's virtually impossible to kill down to the depth of the roots, and mildew can remain dormant for years without appropriate humidity, then wake up when the conditions are right. It's especially bad with seat belt straps, because of all the dead skin "food" that's in them.
    tl;dr - if you have water leaking into your cab, just fix it now and be done. The consequences of inaction are high. If it's into the passenger floorboard and not coming from EVAP backup, it's likely the cowl. Parts are cheap and I'm pretty sure the part numbers are linked up in that leak thread.
    Schcoman[QUOTED] likes this.
  8. Jan 27, 2023 at 1:30 PM
    Schcoman
    Humboldt Co. CA
    None
    Thanks shifty, I've had my share of leaky trucks in the past! Appreciate the advice and will add this to the To-Do list!
