Water leaking into Cab floor from rear window drain that is plugged
Discussion in '2.5 Gen Tundras (2014-2021)' started by 2015SeattleTundra, Feb 9, 2016.
  1. Feb 9, 2016 at 5:53 PM
    2015SeattleTundra
    2015SeattleTundra [OP] New Member
    2015 Tundra SR5 Crew Cab
    Apparenlty, I have debris that has built up between the bed and the cab of the truck on my 2015 SR5 Crewmax. I was told the debris plugged the drain from the rear window casuing a substantial build up of water underneath the body of the truck. The carpets and padding are soaked, mold is starting to grow, and I did not notice early on as I have floor mats covering most all ofthe the carpets. Because of the water buildup, the rear window regualtor is rusting and I am told it needs to be replaced soon, and none of this is under warranty. This will cost me $1000 plus $250 for detailing to clean the carpeting. This truck is 1 year old and a lease.
    Is this really something that I should be paying for on a new vehicle? Have you ever heard of this before? Isn't this a design flaw? Any thoughts?
    -Dave
  2. Feb 9, 2016 at 5:59 PM
    Nor7
    Nor7 Chilton Manual Guy
    2007 Tundra Limited CM, 5.7L
    Seems like this should be covered under warranty. Check your owner's manual, they usually spell out the warranty details.
    Dealers will often deny coverage until you can prove them wrong in writing, drives me crazy.
  3. Feb 9, 2016 at 6:37 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    Holy crap. Ask them where "cleaning window drain" is in the maintainence schedule. If it's not in there, how would you know to clean it? Toyota should be able to do something for you.
    Any pictures of where the drain is?
  4. Feb 9, 2016 at 6:40 PM
    Get a 2nd opinion from another dealer.
  5. Feb 26, 2016 at 6:06 PM
    sstoddard
    sstoddard New Member
    Shawn
    2019 Crewmax Sport
    Alarm/start (Compustar Ft7000,Rf2wl1b 2-way remotes and Drone Mobile) Tailgate inserts NSV Lightbar Tailgate actuator Blacked out decals
    It should be under your warranty. Same principle for the drain tube by the blower motor they have so many problems with.
