Water in rear under back seats
Discussion in '2nd Gen Tundras (2007-2013)' started by Benstoy, May 14, 2019.
  1. May 14, 2019 at 2:47 PM
    Benstoy
    Benstoy [OP] New Member
    2008 Tundra Crew Max 4x4
    3/1 ready lift, added step bars, blue tooth, back up camera, assault roll up tonneau cover...has spray in liner, fender flares, leather
    The truck started smelling bad, but i thought that the kids had spilled something. I finally had time to investigate and found the floor was molding in places because of moisture. The metal legs of the seats were wet like it was condensation, and there was moisture in the Jack area. I'm assuming some kind of leak. It couldn't be condensation, could it? I saw where someone mentioned the cargo light leaking. I also saw something about a rear window drain plug getting clogged. Either of those sound plausible? If it's a drain plug, how do I find it?
  2. May 14, 2019 at 3:00 PM
    Blueknights75
    Ron
    Clayton, NC
    Do you have a sunroof?
  3. May 14, 2019 at 3:39 PM
    15whtrd
    15whtrd Mr. Blonde
    Besides what was suggested also there should be some drains in the window pocket behind the seat just like the drains in the doors. Make sure they’re not clogged up.
  4. May 14, 2019 at 3:41 PM
    MtMan6698
    MtMan6698 New Member
    Wayne
    Florida Panhandle
    2003 Tundra Limited TRD
    It can be condensation if you live in a wet area. Happened to me in another truck. Also had noticed a small amount of moisture getting through the rear window slider. Carpet gets wet and the water seems to go to the seat bolt area. Your seepage may be from somewhere else but the end result is the same. Ended up having to remove the seat, wire brushing the rust and repainting the bolt-down areas.
  5. May 14, 2019 at 4:24 PM
    Benstoy
    No sunroof. How do I identify the drains?
    Mountun Goat likes this.
  6. May 25, 2019 at 9:56 AM
    Benstoy
    It's definitely leaking in from somewhere, as opposed to being simply condensation. Had a good rain last night and the floors are soaked.
    How do I troubleshoot this? Where are the drains I should be checking?
  7. May 25, 2019 at 1:23 PM
    Benstoy
    Ok, so I pulled all of the back plastic liner out from behind the back seat and then performed the hose test. Turns out it's coming in through the third tail light, as others have suggested.
    TheBeast and 15whtrd like this.
  8. May 25, 2019 at 3:14 PM
    Benstoy
    Interestingly, I also just discovered that the cargo light wont work either. I replaced the bulbs while I was caulking it and it still didnt come on. Wondering if the two are related.
  9. May 27, 2019 at 6:59 PM
    Benstoy
    Ok, so I have caulked the heck out of that back light and it is still leaking in. The water only leaks when I apply it to that area...and when I do, it leaks down both back pillars onto the floor. Any other ideas?
  10. May 27, 2019 at 7:11 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    I believe there is a gasket for the lense, chalking may be hard to get right, especially if just chalking around perimeter. You may need a new gasket.
    Water may be getting thru the screw holes too. Aslo make sure the lense isn't cracked.
  11. May 27, 2019 at 7:14 PM
    Benstoy
    Yeah, there is a gasket in there. I caulked that too.....and around the perimeter. The rubber washers on the screws looked good, so I didnt caulk them, however.
  12. May 27, 2019 at 7:19 PM
    TheBeast The Beach
    3rd brake light water leak somewhat common on Toyotas..I see it on Tacomas as well..
  13. May 27, 2019 at 7:20 PM
    Trooper2
    JR
    Sounds like its going to be something odd. My gasket was kinked somewhat but wasn't leaking, thankfully.
    If not already, remove lense/fixture and inspect both surfaces, roof and fixture. Something is not right. Maybe call a local body shop and inquire
  14. May 27, 2019 at 7:29 PM
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    My truck leaked through the third brake light at one point.
  15. May 27, 2019 at 7:37 PM
    Blueknights75
    Ron
    Clayton, NC
    Noticed last time I was washing my truck that water was easily getting into my third brake light...wondering if this is normal for a 3rd gen???
  16. May 27, 2019 at 8:07 PM
    escuzi_me
    escuzi_me Shut up baby, I know it!
    William
    Nashville, TN
    2019 Super White TRD Pro
    This exact thing happened to me on my Tacoma. It’s how I ended up in a tundra. Exact same scenario too. I was mad as hell at my wife thinking she wasn’t cleaning the kids spilled drinks in the back. My bad.
  17. May 28, 2019 at 1:02 PM
    Rons66
    Rons66 New Member
    Me too. Couldn't find a replacement for the light to cab, so made one from weatherstripping.
  18. Jun 13, 2019 at 11:24 AM
    Benstoy
    Ok, so it may or may not have been the cargo light. I caulked that like crazy and still had a leak. I found that the trim around the rear window had a seal starting to go bad that could have contributed, so I caulked that really good. Im not talking about the rubber window seal, but the actual track seal. See photo. Had a good storm roll through last night, and the truck was dry. So, it passed the first test. We will see.
    Trooper2 likes this.
  19. Oct 3, 2023 at 9:38 AM
    Albinator
    Albinator SAINTRIOT
    Utah
    2008 Tundra Crew Cab 5.7 4x4
    RC 3.5” M1 Lift 18X9 5-150.00 12 Offset Vision Turbine
    I’m having the same issue in the same places of my 2008 Tundra. Was it the rear window seal then so I’ll need to replace that?
  20. Oct 14, 2023 at 6:37 AM
    Benstoy
    Sorry for the delay. I didn't get a notification that you had posted. I think I failed to update the post because I was watching to see what it would do. I haven't had any problems with it, so I assume Caulking around that window worked. I remember tearing into it, but can't recall the exact final solution.
