Water filtration while hunting/camping?
Discussion in 'Outdoors' started by kevine0001, Nov 5, 2019.
  1. Nov 5, 2019 at 3:47 PM
    kevine0001
    kevine0001 [OP] New Member
    Kevin
    considering the MSR mini pump style. just wondering what others are using, pros and cons. thx
  2. Nov 5, 2019 at 4:41 PM
    Uhhhh....
    Uhhhh.... New Member
    Dave
    2016 Silver Limited DC
    7” BDS, 37s
    I've heard good things about Katadyn Base Camp, though jeez, you wouldn't know it by some of the Amazon reviews (just looked at them). I may eventually pick one up with further research. I know Randy Newberg uses it.
  3. Nov 5, 2019 at 4:47 PM
    Flyinryank
    Flyinryank New Member
    Ryan
    Las Vegas, NV
    White 2015 CM 4x4
    I’ve been looking at the sawyer squeeze
  4. Nov 5, 2019 at 6:01 PM
    trailrnr
    trailrnr New Member
    2013 Rock Warrior CM
    I have used the Katadyn Be Free Filters for trail running and hiking for over two years now. Probably have filtered 1000 liters and it works very well. They make a 3 liter version of the same filter for a base camp application. Pump style filters are gonna be better for very low flow or shallow water sources, but if you have decent streams, creeks, or lakes the Be Free will work well.
    Flow rate on the Be Free is far superior to the Sawyer Squeeze in my experience.
    With filters a lot comes down to usage. The Be Free is great for traveling light and fast but other filters may be better for other applications.
  5. Nov 5, 2019 at 8:15 PM
    kevine0001
    Kevin
    Thanks for the info, this will be for late Oct/early Nov hunting in the sierras, cold but there are streams in the back country. yes...next season. My friend had a tag in that zone this season and used the MSR pump (mini?). Says it worked fine. I'll probably go with that one, but may eventually also get the large gravity fed bladder
  6. Nov 29, 2019 at 1:51 AM
    Jpneely
    Jpneely New Member
    White SR5 5.7
    little late to the game, but ive used the katadyn and still do when we go camping. its done fine for what we need, but I also found a platypus bladder filter on sale and we started using it and now we cant live without it. it can filter a bunch of water without pumping and you can basically have a reserve of water in the upper bladder that you can filter later. one thing to pay attention to is the weather. it really sucks waking up and trying to filter water and end up locking up your filter because all the water froze in it haha. I know sleep with mine in my sleeping bag to prevent this. we primarily use the bladder, but I take the manual pump katadyn too just in case we get to our spot and the stream or water source wont allow you to scoop up water v
  7. Nov 29, 2019 at 7:06 AM
    myt1
    myt1 New Member
    Richard
    Scottsdale, AZ
    2010 Tundra DC TRD SR5 Desert Sand Mica
    OME Lift, 275/70R 18
    Personally, I hate using a filter.
    I’ve had good success using a UV Steri-Pen.
    It is lightweight and very easy to use.
    kevine0001[OP] likes this.
  8. Nov 29, 2019 at 8:02 AM
    duece292
    duece292 Appalachian American
    Greg
    Green Bay, WI
    If you're looking for something small for the back country I've used the Sawyer mini with great success. It comes with a collapsible bottle but fits on a platypus bottle as well.84719.jpg
