Water dripping steadily from my truck
Discussion in '2.5 Gen Tundras (2014-2021)' started by Spolar, May 3, 2017.
  1. May 3, 2017 at 7:14 PM
    Spolar
    Spolar [OP] Going broke
    Zac
    Seal Beach CA
    2016 sr5
    I keep getting what has to be water dripping steadily from my truck. Is it just condensation from the ac (which I haven't been running)? I don't even know where that usually drips.
  2. May 3, 2017 at 7:24 PM
    :notsure: ...majority of time i dont run my A/C...i dont see anything like that under my truck...maybe someone else chime in
    GNTundra likes this.
  3. May 3, 2017 at 7:26 PM
    Spolar
    Zac
    Seal Beach CA
    2016 sr5
    Even if I'm not running it though? Noticed it the last two days
  4. May 3, 2017 at 7:27 PM
    I run all windows down i can hang the humidity n heat some days ill use AC
  5. May 3, 2017 at 7:29 PM
    Im not sure which button it is... if its ac or recirculate it stops air coming thru even if ac knob is off???
  6. May 3, 2017 at 7:30 PM
    Is your climate controls all off?
    Makes me wonder if you have the Climate Controls in an auto function or if it is cycling on and off.
    Bear likes this.
  7. May 3, 2017 at 7:33 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    It's not coming out the exhaust anywhere is it? Doubt it's the same thing but my F150's exhaust rusted and water would drop out of a tiny hole right around that area.
  8. May 3, 2017 at 7:37 PM
    Spolar
    Zac
    Seal Beach CA
    2016 sr5
    I'll have to check that
  9. May 3, 2017 at 7:38 PM
    Spolar
    Zac
    Seal Beach CA
    2016 sr5
    Nothing coming from exhaust
    joonbug[QUOTED] likes this.
  10. May 4, 2017 at 3:36 AM
    TTund16
    TTund16 New Member
    ac compressor can run (without you pressing a/c) even when you have fan or heating especially in window defrost position ...
    if the water is from a/c system, you should find a burp valve or a similar drain line above where the water is dripping. I am not familiar with the specific location in Tundra. Its typically towards the passenger area. When hot or humid you may notice more water.
    Spolar[OP] likes this.
  11. May 4, 2017 at 4:18 AM
    CM-LENNY
    CM-LENNY No Complaints
    San Diego, CA
    2015 4x4 CrewMax SR5
    PRO shocks, 37's Nitto G2's 4:88 diffs, few other mods
    That was my thought. Have you run the defrost ? In defrost mode the A/C will cycle too.
  12. May 4, 2017 at 6:37 AM
    Spolar
    Zac
    Seal Beach CA
    2016 sr5
    Yup. That must be it. I drive around with the knob on the defrost setting but don't have the "a/c" button on.
    JC303 and BlueFalconActual like this.
  13. May 4, 2017 at 6:43 AM
    BlueFalconActual
    Kevin
    29 Palms, CA
    Tundra-less
    My little car in Japan was a Toyota did the same thing. If the defrost was on, it automatically kicked on the AC compressor regardless if the AC was on or not.
