Water-cooled Intercooler?
Discussion in '3rd Gen Tundras (2022+)' started by 21CGtundra, Jan 10, 2022.
  1. Jan 10, 2022 at 1:50 PM
    21CGtundra
    21CGtundra [OP] New Member
    Robbie
    SLC, UT
    2022 Midnight Black Tundra SR5
    2" front level, 1" Cornfed rear spacer, Rally Armor flaps, Method Con-6 wheels, 285/75 Duratrac
    Does anybody have any info on the water-cooled intercoolers? Are they fed with coolant or is it a separate system? My build sheet calls out water-cooled intercoolers which I thought was different in the OEM market as air-cooled is so much cheaper and seemingly easier. Just curious where they are located and what cooling media feeds them. Thanks.
  2. Jan 10, 2022 at 3:14 PM
    1SikhTRDPRO
    1SikhTRDPRO New Member
    its located on top of the motor, just above the V, fed with coolant.
    DexterL likes this.
  3. Jan 10, 2022 at 3:51 PM
    stevj
    stevj New Member
    On a clear day, I can see Seattle from my house.
    Current RAM 1500 owner waiting for the new Tundra "hybrid."
    No point trying to cool the air charge with 200°F+ engine coolant. That would defeat the purpose.
    Likely a separate system.
    EDIT: Pages 538 and 539 in the owner's manual. Separate reservoirs for engine and for intercooler.
  4. Jan 10, 2022 at 3:55 PM
    tech1208
    tech1208 Old Salt, New truck
    Orlando, FL
    2023 Tundra Platinum 4X4 Blueprint Blue
    The engine is equipped with two parallel turbochargers (one by each side) with electronically controlled wastegate valves. Each turbocharger sends compressed air through its own air-to-water intercooler integrated inside a polymer intake air surge tank mounted on top of the engine. Intercoolers and turbochargers use a separate cooling system with an additional radiator and electric pump.
    https://www.motorreviewer.com/engine.php?engine_id=192
    Randy B
    raylo and Gunship Guy like this.
  5. Jan 10, 2022 at 4:11 PM
    mass-hole
    mass-hole New Member
    Its a separate system with its own two heat exchangers. The blue exchangers to the right and left of the radiator:
    Toyota was not messing around when they designed the cooling system for this engine.
  6. Jan 11, 2022 at 7:00 AM
    21CGtundra
    Robbie
    SLC, UT
    This is exactly what I was looking for. Thanks guys.
  7. Jan 12, 2022 at 8:17 AM
    raylo
    raylo not so new member
    Frederick, MD
    DashCam, amp/sub, rear seat del, cat shield, AMP power boards
    That article said one thing I hope comes true, but I am not holding my breath for: that the engine will find its way into the Tacoma. That would be a hoot!
  8. Jan 12, 2022 at 9:27 AM
    mass-hole
    I bet the Tacoma gets a 2.xL Inline 4 turbo like the ranger unless its like some TRD Ultra edition to compete with a Ranger Raptor.
    Word on the street is the next gen Colorado/Canyon will be getting the GM 2.7L Turbo from the Silverado with 315hp/350 torque @ 1600 rpm. That will be a game changer in the mid-size truck world. You would actually be able to tow a decent trailer without it completely sucking.
    BMP and raylo[QUOTED] like this.
  9. Jan 12, 2022 at 9:31 AM
    raylo
    Frederick, MD
    Yup, that is more likely. Although the turbo V-6 would make a compelling choice. Being that a Tacoma weighs 1500 pounds less than a Tundra It would be a blast to drive and get better MPG, too. But I suspect packaging in the smaller body and frame might be problematic without a lot of re-engineering.
  10. Jan 12, 2022 at 10:04 AM
    mass-hole
    The good news is the next gen Taco is based on the same TNGA platform as the 2022 Tundra, so maybe it will already have the provisions built in. Who knows.
    raylo[QUOTED] likes this.
  11. Jan 12, 2022 at 10:17 AM
    raylo
    Frederick, MD
    I hope they get working on this stuff and that the chips start flowing. My 2009 Tacoma won't last forever. A mini raptor with good MPG would be fantastic. But knowing Toyota and their weird way of making options available they would probably offer it only with a short bed which would be a non-starter for me. And I could probably never go back to Chevy having had an S10 back in the day before my Tacoma. So many issues, such low quality. The only positive thing about it as compared to the Tacoma was the frame didn't rust nearly as bad or as quickly. I don't know where Toyota gets their cheap steel. Maybe it is just very highly engineered and selected to make the frames disappear at about the same time as the rest of the vehicle wears out with normal mileage. ;-)
  12. Jan 13, 2022 at 9:35 AM
    SLVR6
    SLVR6 New Member
    Almost, the Tundra has a single large intercooler on top of the surge tank (and how you know that name makes me curious...). The original version of the engine in the LS500 uses separate intercoolers. Spot on with rest.
