Warrior Products MOD BOX...anyone seen or used this?
Discussion in '2.5 Gen Tundras (2014-2021)' started by pschiller86, Mar 15, 2018.
  1. Mar 15, 2018 at 9:43 AM
    pschiller86
    pschiller86 [OP] 2017 SR5 CrewMax
    Paul
    Temecula, CA
    ColoradoTJ likes this.
  2. Mar 15, 2018 at 10:23 AM
    71_340
    71_340 The German
    Hans
    FLW, MO
    Nice storage solution but they don't show one for a Tundra, also not sure if that will work with all the bed covers. I considered one of these swing-out boxes that mount right behind the rear wheel housing inside the bed corner.
  3. Mar 15, 2018 at 10:26 AM
    pschiller86
    Paul
    Temecula, CA
    If I'm not mistaken, I believe the Tacoma deck rail and tundra bed rails are the same dimensions... but you do have a point if someone uses a tonneau.
  4. Mar 15, 2018 at 11:24 AM
    71_340
    71_340 The German
    Hans
    FLW, MO
    Yes, as much as I like the design I don't think it would work with my Mx4 cover. Right now I use a Lowes bucket to store all my small items in the bed.
  5. Mar 15, 2018 at 11:36 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    it might clear the mx4/g2 since the rail is dropped down about 4"
  6. Mar 15, 2018 at 1:36 PM
    71_340
    71_340 The German
    Hans
    FLW, MO
    I never mounted my rails because I don't like the flimsy brackets they send me. I'll probably will buy a swing case which should clear my Mx4.
  7. Mar 16, 2018 at 11:08 PM
    kb1982
    kb1982 New Member
    2014 MGM DC
    You should try contacting Wheeler’s Offroad, they sell them and may be able provide some info. Also, I’m going talk to my friend that owns a fab shop and see if he’s willing to come up with something, becuase I am looking for something similar, and these seem way overpriced.
  8. Mar 17, 2018 at 4:23 AM
    SMK Shoe
    SMK Shoe Not New Member
    Paul
    Central North Carolina
    2017 Tundra TRD DC
    Step Bars, Rear Swaybar, 2,000 Watt Amp, 2-10" Subs, new door speakers, De-Badged, Hondo vent mounts, Calipers, 6112/5100 shocks, SPC UCA's, Front bumper, Bed Bars, bed rack, Fuel Rims
    Little pricey at 135$, but love the idea. May have to bite the bullet and try one or two. Says they will fit late model tundras bed system
  9. Mar 17, 2018 at 6:27 AM
    Kwikfish
    Kwikfish Get your poop in a group!
    Tri cities,WA
    16 CM SSM
    If you have the bed rail system you can make some simple drop down brackets and put a ammo can at whatever height you want and you can lock them if you want,uae a small lock with the numbers so no key needed...just a thought for yall...
