Warranty question
Discussion in '2nd Gen Tundras (2007-2013)' started by Adam61484, Jul 17, 2017.
  1. Jul 17, 2017 at 4:58 PM
    Adam61484
    Adam61484 [OP] New Member
    2012 Toyota Tundra Rock Warrior
    Westin bull bar, readylift 3in. lift/leveling kit, 33in. tires on factory rock warrior rims
    Have quick warranty question for anyone that can answer. I was going to buy a couple new uca so I could get a proper alignment. It's still slightly out about 4 degrees on the camber since the lift/leveling kit. The local Toyota dealership told me they couldn't do a complete alignment due to the fact that my alignment cams are seized up. Is this a warranty repair or not.
  2. Jul 17, 2017 at 5:23 PM
    15whtrd
    15whtrd Mr. Blonde
    Doubtful unless you have an extended warranty for there is some TSB I don't know about. I have heard this is a common occurrence as they rust out and seize up. I was advised to coat them in anti-seize so that they'll never do that or in your case never do that again.
  3. Jul 17, 2017 at 7:11 PM
    Adam61484
    Well I do know that I am under some kind of manufacturer warranty untill either 100k or 2019, guess I will just have to talk to the dealership I bought the truck from. To bad it's about 200 miles from where I live.
  4. Jul 17, 2017 at 7:27 PM
    Do you live in a place that uses salt? My 12' cams where good to go.
    I highly doubt warranty will cover that.
