Warn vs Smittybuilt 12K synthetic
Discussion in '2nd Gen Tundras (2007-2013)' started by jelloburger, Dec 30, 2019.
  1. Dec 30, 2019 at 4:40 PM
    jelloburger
    jelloburger [OP] New Member
    Having read a ton of reviews and watched the Tubers...I'm down to these two winches, but still can't decide. Very similar in spec, both have strong customer reviews. What do you think?
    $563.84
    Smittybilt
    (98512) X2O Waterproof Synthetic Rope Winch - 12000 lb. Load Capacity
    https://www.amazon.com/gp/product/B00K150X2E/ref=ox_sc_act_title_1?smid=ATVPDKIKX0DER&psc=1
    OR
    $823.32
    WARN
    103255 VR EVO 12-S Standard Duty Winch with Synthetic Rope - 12,000 lb. Capacity
    https://www.amazon.com/gp/product/B07SGG81RR/ref=ox_sc_act_title_3?smid=ATVPDKIKX0DER&psc=1
  2. Dec 30, 2019 at 4:58 PM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    I got the Smitty, used the 300 bucks for more mods.
  3. Dec 30, 2019 at 5:47 PM
    thetwood
    thetwood New Member
    Louisville, CO
    2017 Blazing Blue Limited CrewMax TRD
    Kings, SPC, Icon Six Speed, Falken Wildpeak AT3w
    I have a Warn, but originally ordered that Smittybilt. At that time, it was back ordered and no one knew when they would actually ship, so ended up paying more for a Warn. Have been happy so far (though not used much). Don't think you can go wrong either direction and the Smittybilt will save you some cash.
  4. Dec 30, 2019 at 6:07 PM
    Wsteven
    Wsteven New Member
    2007 White SR5 Single Cab
    Both are good products I had the Smittybilt X20 with the Synthetic rope on my FJ Cruiser and it really worked excellent and got a hell of a workout, The Only thing I did not like about it was the Relay box (Separate from the winch) it was not very water proof So if you go with it make sure to take the relay box apart seal it up well and place it as high and Dry location that you can.
  5. Dec 30, 2019 at 6:53 PM
    NR-J
    NR-J New Member
    Justin
    2015 white tundra
    I have the Warn VR12 on my FJ and love it. It’s been used and used and used. Tons of repeated winching hauling trash loads out of ravines, winching my FJ out of bad spots and pulling a lot of other stuck vehicles free.
    I’ve seen enough winches from other brands fail that we only use Warn for our crew trucks.
  6. Dec 31, 2019 at 8:50 AM
    jelloburger
    Well, it appears the Smittybilt has just gone up $50 overnight. So now that's only a $200 difference, thus leaning me towards the Warn now. $200 over a 5 year period is less than $2/month.
  7. Dec 31, 2019 at 9:28 AM
    theraven
    theraven New Member
    Central AZ
    16 DC / KI7LWX
    Icon 2.5 cdc front and rear. MCM UCA's, RXT rear leafs , wheelers bump stops, Icon hydrolic Bump stops, Icon six speed 17x8.5 w/35x12.5R17 Nitto Ridge grapplers, A.R.E. CX,, Smittybilt Gen2 12k synthetic on SSBuilt Front bumper, factor 55 fair lead, factor 55 flat link-E, SSBuilt high clearance rear with S2Pro, BD squadron pro fogs and side lights, BD 40" Onx6 behind the grill on SDHQ mount, BD XL80's on SDHQ a pillar/ hood mounts. Switch pros 9100, SDHQ panel mount and SDHQ under hood mount. Pro Grill, SDHQ ABS guards, P&P Sliders, Full RCI skids. Kenwood TM-V71a, Dual GPS antenna, Rago dash mount, WE Boost inreach
    I have the smittybilt 12k synthetic. If I had to do it again I’d go warn. As another guy mentioned the control box isn’t waterproof and you find that out at a less than ideal time usually.
    jelloburger[OP] likes this.
  8. Dec 31, 2019 at 11:38 AM
    jelloburger
    Done. Warn on the way. Should have it installed w/ new front Fab4s bumper this weekend God willing and weather cooperating. :bananadance:
    Zero One Actual and porkitt like this.
  9. Dec 31, 2019 at 11:50 AM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    I have the smittybilt 12k w synthetic rope. I put some longer cables on it and mounted it up under the hood. 0E4FBEE2-C287-4D59-8636-09BD9E78613F.jpg
  10. Dec 31, 2019 at 12:34 PM
    BOBONTUESDAY
    BOBONTUESDAY Grocery Getter
    2016 Limited Trd
    I've got the smitty built x20 been on the truck for over a year now about 50 to 60 thousand miles and I've used it quite a bit even broke the winch cable once. Been a really great winch. My control box sits in my sso bumper and gets packed with snow and covered in rain all the time with no issues. I use it all the time. Sometimes its pulling myself and a trailer out sometimes pulling others out or other things out of the way. I liked the x20 so much I bought the steel cable version for my car trailer.
  11. Jan 1, 2020 at 1:38 PM
    DesertRoads
    DesertRoads Telecom Guy
    Utah's West Desert
    2005 DC SR5 V8 4WD LSD & TOW PKG
    LED Lights Galore. Mostly Stock
    I have a Warn VR Evo 12S. I got it out of my buddy's truck after he was rear ended. I've only used it a few times, but it works very well for my needs.
  12. Jan 7, 2020 at 10:14 AM
    jelloburger
    2 questions:
    1) Has anyone done a relocation modification of their winch controller and if so, did you have to fabricate your own custom wires/brackets? Any suggestions or things to consider here, and why NOT to do it? I'm wanting to put mine under the hood.
    2) Has anyone any experience with mounting their winch horizontally vs vertically? Warn suggests to mount vertically, I called and asked and they said it's because of how it operates. I was confused as, isn't this a cylindrical application where the load would be the same regardless?
  13. Jan 7, 2020 at 4:15 PM
    thetwood
    thetwood New Member
    Louisville, CO
    I have a Warn VR-12S that I mounted with the controller relocated into the engine bay. I needed to do it because of how the winch is built, but also wanted to do it for better protection of the controller from the elements and easier access. See link below to see my build write-up of this. I ordered 6' battery cables and swapped these in between the winch and controller. I then mounted the controller on top of the fuse box. To mount the controller, I cut a piece of plastic to the same size, used the mounting screws to attach and then used Velcro to secure so I could remove if I wanted.
    Not sure if it's the same as you're referring to by horizontal/vertical, but my winch is mounted to the bumper so that if the controller was still on, it would be behind the winch, not on top (rotated 90 degrees back). Works fine.
    https://www.tundras.com/threads/col...-pro-headlight-swap.19306/page-3#post-1247350
  14. Jan 8, 2020 at 9:16 AM
    jelloburger
    Thanks Thetwood, good stuff here you shared, much appreciated. :thumbsup:
    The good news is that sounds like the relo of the controller isn't a big deal and like the placement you chose. Bad news is I have to remove the monster bumper again to rotate the winch and remove the controller, as there's not as much room between the oil cooler and the winch as I had hoped. Oh well, at least I know what's involved and should be much faster to re-install it than the first time.
    Here's the super high tech modification I made to my floor jack to balance the bumper on so that it can easily move that bumper around with just someone spotting. It worked so much better than I anticipated; it's simply a piece of rough cut lumber I had that I drill/tapped into the jack plate. A piece of foam on top of the wood to protect the bumper and of course, no good project is complete with out some duct tape. Redneck ingenuity wins again. :D
  15. Jan 8, 2020 at 9:18 AM
    thetwood
    thetwood New Member
    Louisville, CO
    Anytime. Glad it helped.
  16. Jan 8, 2020 at 10:04 AM
    TG705
    TG705 Braaaap
    Tony
    San Jose, CA
    2011 super white Tundra double cab
    King 2.5 coilovers, King 3.0 rear bypasses, Camburg uniball UCAs, RCI skid plates, Camburg front bumper, warn zeon 10s platinum winch, monster hook reaper shackles, Rigid Industries lights, SDHQ sliders, SDHQ A-pillar brackets, SPOD, 17" Method standard wheels, 315/70/17 Cooper STT tires, Morimoto XB LED headlights, Boon dock steel rear bumper, Durobumps front bumpstops, Deaver U748 with MCM shackles
    not sure what winch you have there might be a relocation kit for it. I have a warn Zeon and I had to buy a relocation kit from them because the winch controller box was too tall for the bumper. super easy to install and came with all cables, brackets, hardware, and easy to follow instructions. wasn't too expensive either
  17. Jan 8, 2020 at 1:03 PM
    jelloburger
  18. Jan 8, 2020 at 1:51 PM
    timsp8
    NY
  19. Jan 8, 2020 at 4:23 PM
    thetwood
    thetwood New Member
    Louisville, CO
    I obviously don't think you're missing something as that's the route I went. Battery cables worked just fine and was easy enough to fab a mount for the control unit.
  20. Jan 8, 2020 at 5:42 PM
    jelloburger
    Something (probably very obvious and a stupid question) but how do you secure your winch line? As in; what keeps someone from flipping the freespool and doing any number of nefarious things with the line either to cut, steal or other shenanigan's?
  21. Jan 8, 2020 at 5:45 PM
    lawfarm
    lawfarm New Member
    2018 Tundra SR5 Premium TRD Crewmax
    Reel it in and keep some tension on it. I use a winch hook that can pull up tight on the fairlead. If you leave some tension on it, the freespool lever won’t release.
  22. Jan 8, 2020 at 8:15 PM
    jelloburger
  23. Jan 9, 2020 at 3:30 AM
    timsp8
    NY
    I’ve also never heard of anyone messing with or trying to steal a winch line. Might happen but probably too much work for little payoff. They’ll take your tailgate instead.
    jelloburger[OP] and thetwood like this.
  24. Jan 12, 2020 at 12:21 PM
    jelloburger
    Need some help here: So I got the bumper back off to install longer controller cables (tomorrow hopefully if they arrive) and also to reposition the winch according to bumper instructions for a 12K. Question: does it matter if you flip the winch around one way or the other? In the picture below, I have it temporarily mounted on the front of the bumper, you can see this makes it easier to reach the cables and puts them on the top of the winch versus underneath. This does put the winch handle on the opposite side, but otherwise, I don't see this as a problem. What am I missing here? Only thing that occurred to me was would this configuration cause the "in/out" to be reversed and if so, does it matter?
  25. Jan 12, 2020 at 7:18 PM
    TG705
    TG705 Braaaap
    Tony
    San Jose, CA
    I believe it does matter, I don't think the winch is designed to spool in the winch out setting and vise versa. I could be wrong tho. your best bet would be to call warn and ask.
  26. Jan 13, 2020 at 5:22 AM
    jelloburger
    @TG705 - Thank you sir. I was just sitting here having coffee thinking that very thing. Guess it took some caffeine to stimulate the grey matter. :)
  27. Jan 13, 2020 at 8:22 AM
    TG705
    TG705 Braaaap
    Tony
    San Jose, CA
    No problem buddy! good luck
  28. Jan 13, 2020 at 8:39 AM
    jelloburger
    UPDATE: Spoke to Warn, they stated the winch can be mounted foot down or forward, but MUST be mounted such that the cables are on passenger side and handle is on driver side. However, the FabFours installation states "if you are installing a winch with a pulling capacity of 12Klbs, the front face mounting holes must be used." (is this because at this load, 12k could sheer off the bolts in a foot down position?) Foot down position is not ideal so, I then called and spoke with FabFours, to see if I could mount this foot down because it would make accessing the handle and running the cables much easier. Their words were "we recommend that anything larger than a 12K be mounted foot forward and under 12K can be mounted either foot down or forward". This apparently was not clear in their installation guide (I was kind enough to mention to them :)) but now thankfully I can mount in much more ideal way, foot down. Whew. Thanks for hanging in here with me folks!
  29. Jan 13, 2020 at 8:58 AM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    I read this entire advertisement. It’s clearly just a thinly veiled add for Smitybuilt. I’m not advocating for any brand, just saying that this is not really a “comparison review”
    Also, of premium winches, a high priority issue is water resistance. If you are partly submerged and need to use your winch, it’s a poor time to realize your winch has died.
    theraven likes this.
  30. Jan 13, 2020 at 9:26 AM
    kenomouth64
    kenomouth64 New Member
    Tetrus
    2007 Toyota Tundra Sr5 4x4 (TRD Off Road) Crewmax 5.7L
    Hold the Line! If you are not holding the line, abandon your ship. Destruction is inevitable without more to hold the line!
