Warn Semi Hidden bumper with a badlands 12k apex winch in it?!
Discussion in 'Towing & Hauling' started by RaZaRacOdVas, May 6, 2021.
  1. May 6, 2021 at 2:51 AM
    RaZaRacOdVas
    RaZaRacOdVas [OP] New Member
    2015 Black Tundra SR5
    TRD Pro trim kit (Grille and Hood bulge/Badge Blackout) EcooLogical Color matched bumpershellz Amp Research Steps Toyota Wireless charging tray Anytime Forward facing camera VLAND Pro headlights (Sequential turn signals) LED interior/Exterior lighting
    As the title says, will the new Badlands Apex winch fit in the Warn Slimline bumper?
    Dimension wise the bolt pattern is the same and the actual size of the winch appears to be a little smaller in Depth/Height/Width. The Apex winch has killer reviews and is a 3rd of the cost of the 12S anndddd comes with a forged hook/fairlead. Soooo has anyone done this combo?
    For Clarity Im Talkin about this Bumper
    https://www.warn.com/semi-hidden-kit-for-toyota-tundra-103209
    and this winch Now.... I know there may be some peoplethat will hate on this idea... Purists that say well why not just get the Warn winch blah blah blah.... lets keep all that to a minimum.
    Thanks!
  2. May 6, 2021 at 3:29 AM
    Black
    Black Raised Hands Surround Us. 3 Nails To Protect Us
    2014 Tundra Limited CrewMax
    Falcon Leveling System, Coachbuilder +1s, RCI Skid Plates
    Pretty sure the Apex control pack is capable of being relocated so it should not be an issue.
    Also considering it is pretty much a knock off of the Warn Zeon anyway.
    May want to look at the Souther Style Off-road slimline bumper as well.
    I think it is a little more pleasing to the lines of the Tundra also has a light bar mount option and does not loose access to the winch.
  3. May 6, 2021 at 4:33 AM
    RaZaRacOdVas
    Thanks a bunch I'll take a look!
  4. May 7, 2021 at 2:30 PM
    pearlpower
    pearlpower New Member
    2014 CrewMax in Radiant Red
    I have my Warn bumper inbound and will then know if the Badlands 12k winch will fit, I believe it will. I did explore other bumper options which were similar but did not care with how they go over the front bumper top vs inside of it. And their lead time is 6-10 weeks.
    BLONGTX likes this.
  5. May 7, 2021 at 2:58 PM
    RaZaRacOdVas
    Awesome I look forward to seeing what ya find out!
  6. May 19, 2021 at 8:15 AM
    pearlpower
    I did receive my bumper, but of course it arrived damaged. Seller provided me with a credit, and I can easily repair it with a heat gun, block of wood and lead hammer. Install in about 2-3 weeks, depending on if I decide the spray the black bumper surround to match my new bumper caps. I also have a Hookeroad rear step bumper incoming - curious what condition that will arrive in.
    RaZaRacOdVas[OP] likes this.
  7. May 19, 2021 at 8:47 AM
    RaZaRacOdVas
    Awesome man! Can't wait to see it installed! Lemme know how that badlands apex 12k fits too!
  8. May 29, 2021 at 5:04 PM
    RaZaRacOdVas
    Any updates with the install and badlands winch? Would love to see.
  9. May 29, 2021 at 8:42 PM
    pearlpower
    I sorted out the damage with the seller, and since repaired the damage. I am Raptor lining it along with the chrome end caps tomorrow.
  10. May 29, 2021 at 8:56 PM
    RaZaRacOdVas
    Nice! I went with the ecoological bumpershellz on mine and the look frikin great.
    Can't wait to see your finished product.
  11. May 29, 2021 at 9:16 PM
    GAknight
    GAknight New Member
    Shade of a Pine, GA
    '14 TSS 4x4
    Too many…scratch that…not done yet.
    To OPs original question. It should fit.
    I fit a new 12K Apex in an SSO slimline bumper.
    I had to relocate the control box, which i suspect you will need to also.
    The Apex comes with relocation studs/hardware.
    Just FYI... be mindful of your torque on the studs. I broke one of my extensions, but was able to work one of the power lines terminals to still fit.
  12. May 29, 2021 at 9:22 PM
    RaZaRacOdVas
    Interesting that you had to relocate it! I've seen this bumper installed with an intact warn 12s so figured I'd be good since the 12s is a bit taller than the badlands. Thanks for your input! Would love a pic.
    GAknight[QUOTED] likes this.
  13. May 29, 2021 at 9:42 PM
    GAknight
    GAknight New Member
    Shade of a Pine, GA
    '14 TSS 4x4
    I’ll take a few pics for you tomorrow.
    I mounted mine on top of the fuse box cover. I used some aluminum bar stock to make a mounting bracket for it, and the master power switch.
    I also bought some extra 6 ft cables, wire loom and several roles of electrical tape.
  14. Jun 4, 2021 at 12:04 PM
    pearlpower
    Installing today. :)
    bulldog93 and TomC843 like this.
  15. Jun 4, 2021 at 12:06 PM
    jsteph89
    jsteph89 The wish list continues to grow
    Joseph
    South Texas
    2019 Limited 4x4
    Blacked out emblems, Leer 100XL camper shell, Magnaflow exhaust, ProComp 3/1 level kit, 285/55R20 Falken Wildpeaks AT3, WeatherTech mats, full led interior swap,
    Update is with pics please. Good luck!
  16. Jun 4, 2021 at 12:14 PM
    Bikeric
    Bikeric New Member
    Eric
    2007 DC 5.7
    Blown Engine.....
    That Warn bumper looks pretty tall, so you might be able to fit the winch in there without relocating the APEW control box. I went with the Hooke Road bumper and had to use the ZXR Badlands winch and STILL relocate the controls off to the side (but I am a short nose 2011). I've used the winch to pull and it's plenty strong and so far reliable.
    pearlpower likes this.
  17. Jun 4, 2021 at 12:18 PM
    pearlpower
    It does bolt in, albeit a very tight fit.. The supplied bolts are a tad short if you use both the regular and lock washer, as the Warn steel is thick.
    Deciding whether I want to relocate the control box or trim the plastic bumper cover a little and make this fit.
    Also, in case anyone is wondering. Total weight of winch and Warn bumper is 134lbs. Crash bar removed is 27 lbs, so a net addition of 107lbs on the front of the truck. Not exactly the best thing for carving corners…. :)
    Hint: Install fairlead before winch.
    RudeDog396 and 300BLK like this.
  18. Jun 4, 2021 at 1:37 PM
    RaZaRacOdVas
    This is awesome and exactly what I needed, so ya need to trim a bit off the top of the control box cover for it to clear?
  19. Jun 4, 2021 at 6:03 PM
    pearlpower
    Had to trim a bit of the bumper trim steel bar, but it is in.
    Now adjusting the bumper caps and finish the wiring. I placed the switch on the fuse cover.
    Test fitted the light bar and no dice. The mounting holes on the bumper only allow for a skinnier light bar. The larger diameter light bar hits the plastic OEM trim piece behind it.
    RudeDog396, TomC843 and jsteph89 like this.
  20. Jun 4, 2021 at 10:28 PM
    RaZaRacOdVas
    Awesome man just Awesome
  21. Jun 5, 2021 at 10:31 AM
    300BLK
    300BLK New Member
    2014 Tundra SR5 - Black
    Looks great. I like this bumper a lot. I'm still between something like a full C4 bumper or going with something along these lines.
    pearlpower[QUOTED] likes this.
  22. Jun 5, 2021 at 10:49 AM
    Joro43
    Joro43 New Member
    2018 TRD Sport 4x4 quicksand crewmax
    1st tundra nautical blue 4x4 5.7l DC TRD had oracle custom color shift halo projector headlights, Fab4 bumper with 12k winch. RBP RX3 Grill Pro Comp stage 1 with bilstein 6112 coil overs SPC UCAs BFG KM3 35x12.5x20 with Moto metal 959s NFab running boards TRD LED DRL pioneer avh 4200nex with Polk speakers and JL 600w amp with JL audio stealth box 196k miles and running strong ready for another 200k until I wrecked it on 2/26/21 Just bought 2018 CM 4x4 5.7l quicksand TRD package upgraded headlights and adaptive CC Trifold bed cover, blacked out badges, KMC wheels BFG KO2 tires, 3/1 pro Comp lift FAB4 front bumper with rigid lights and fab4rear bumper.
    Nice modification. I will say my steel badlands winch I had in my Fab4 bumper worked great for the 8 years I had it. Badland for value is the best.
    300BLK and pearlpower like this.
  23. Jun 9, 2021 at 7:28 PM
    pearlpower
    Got around to installing the Factor 55 Ultra Hook.
  24. May 24, 2023 at 5:31 PM
    ffdawson
    ffdawson #DBB
    NorCal
    Sandra, Sandy for short
    Rad ass parts, big tires.
    Stoked on this post... I just picked up one of the Warn bumpers for cheap. I'm going to remove the bull bar and mount a winch. Happy to hear the Badlands fits in there.
  25. May 24, 2023 at 5:41 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Pretty damn easy to mount the APEX in just about any bumper once you pull the control box off.
  26. May 25, 2023 at 2:30 PM
    ffdawson
    ffdawson #DBB
    NorCal
    Gave mine a little chop chop on the bull bar. A9444BCD-C75F-4E7C-A0FC-A1EB7005849F.jpg 49D8A60D-A6DB-4EE3-9EFB-B937565BA3C4.jpg 830E6368-DBD3-442F-8077-2F66AF60DD1F.jpg
    texasrho83 and bulldog93 like this.
  27. Jul 27, 2023 at 11:22 PM
    ffdawson
    ffdawson #DBB
    NorCal
    Got her mounted up, with the apex 1200 in there. 9E3D7E77-0463-499A-B652-4CFF2E406468.jpgA30505AB-2376-40D2-9F76-25F82FE7896D.jpg
    MI17PRO and ZappBrannigan like this.
  28. Jul 27, 2023 at 11:52 PM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    That’s a nice looking truck. I really like the look if these partial front bumpers.
    ffdawson[QUOTED] likes this.
  29. Jul 28, 2023 at 6:18 PM
    ffdawson
    ffdawson #DBB
    NorCal
    Thanks! Yeah I'm digging it. I had a big plate steel bumper on my Tacoma with a big hoop and light bar, and I'm enjoying the more subtle look of this, especially after I chopped the bull bar off...
    ZappBrannigan[QUOTED] likes this.
