Warn EVO 10
Discussion in 'Recovery & Gear' started by Blue By U, Sep 10, 2023.
  1. Sep 10, 2023 at 1:07 AM
    Blue By U
    Blue By U [OP] New Member
    I have had this in my 2020 for 3 years without problems. Recently I was hearing a noise from the frontend with the truck parked in the driveway. Come to find out the winch was turning off and on, by itself and cycling the cable out. Battery in the remote is good but wont work it wirelessly only with the cable. Disconnected the positive from the battery and all is quite now. Any suggestions on the problem.
  2. Sep 27, 2023 at 6:55 PM
    KiloOps
    KiloOps New Member
    Dustin
    2023 Army Green Tundra Limited TRD Off Road
    Purchased the truck on Jun 10, 2023, modifications will be made!
    When you reconnected the battery did it stay quiet or are you saying it's only quiet when there is not possible way it can operate? lol
  3. Sep 27, 2023 at 7:05 PM
    Blue By U
    I contacted Warn and they said it was the remote sending random signals. They are in the process of replacing the remote.
    RCONL-22E101-7014.pdf (nhtsa.gov)
    equin likes this.
  4. Sep 27, 2023 at 7:06 PM
    KiloOps
    KiloOps New Member
    Dustin
    Good to know, I'm looking at getting an EVO 12 so doing a little research.
  5. Oct 28, 2023 at 9:43 AM
    Fieldnstreamer
    Fieldnstreamer Cold Researcher
    Sam
    East Tn
    2006 DC Limited 4x4 Phantom Gray Pearl, 2000 AC Limited 4x4 (R.I.P.)
    Brute force bumpers/sliders, OME 3" lift, SCS ray 10 wheels, ARB onboard air compressor, GX460 big brake upgrade, JBA UCA's, siberian Bushings, RCV high clearance axles, 333 Billet steering rack clamp, TMR customs 10" front limit straps, 1" diff drop, agility customs dual battery setup/battery isolater with heavy duty wiring/ grounding cable upgrade, F-er battery tray, HFW spindle gussets, remote oil catch can,
    After doing some research and reading reviews I think I'm going with a zeon 10. Made in usa plus people have mentioned in reviews about the line snapping for zero reason under minimal load on the evo.
  6. Oct 28, 2023 at 11:07 AM
    AZBoatHauler
    So.Arizona
    I battle tested my SuperWinch under severe conditions and it held up perfectly. No issues.
