Warm Up and then drive or just Key in and go
Discussion in '1st Gen Tundras (2000-2006)' started by bassman417, Oct 3, 2020.
How long do you warm up for before driving
  1. 1 minute
    48.1%
  2. 5 minutes
    16.5%
  3. more than that.....
    6.3%
  4. I don't warm up
    29.1%
  1. Oct 3, 2020 at 1:59 PM
    bassman417
    bassman417 [OP] "Tundra Time". My favorite time of day...
    Paul
    Las Vegas
    2004 DC 2wd Imperial Jade
    This is probably a silly question but its in the back of my head now everyday before I throw it in drive and go.
    Since I have gotten the dongle and Torque Pro app, I see the actual temps when I start.
    There is a setting that will sound an alarm if your RPM's increase too much before your engine is at operating temp. not even sure what the thresholds are but i have not heard that alarm yet.
    Question is what is a good temp to let it warm to before driving?
    I live in the desert, ( las Vegas ) so I'm certain warm up time is much shorter than a cold state, but how long do I really need to wait to get to operational temp. I though operating temp was 185-195.
    Below are some screen shots of the data.
    Lastly all Gens are welcome to Reply since this is relevant on a 5.7 also I assume.
    First one is right after startup
    Second one is where I let it go to before taking off this morning.
    Last one is upon arrival at destination.
  2. Oct 3, 2020 at 2:06 PM
    lamboboy732
    lamboboy732 New Member
    I don't bother. Start get phone and everything set then go. Less than a minute. I don't hammer on it until it's up to temp but I'm not going to let it run all day in the driveway to get it warm, warms up much quicker by driving.
    Schcoman and GeezePlease like this.
  3. Oct 3, 2020 at 2:08 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    It depends... I let the whine stop before I go, so 30 seconds??, but sometimes I idle for a few minutes and others I just go, depends on the situation....
    Tundyfundy and FlyingWolfe like this.
  4. Oct 3, 2020 at 2:14 PM
    Pucks18
    Pucks18 Fleabit peanut monkey
    2001 Tundra 4x4 Limited trd
    If its summer I let it idle for 2 mins or so, then drive around nice and easy for a little. When its winter time I like to drive around my neighborhood for a couple mins only so I can get my transmission fluid heated up, that's the main thing to be worried about once your engine is good
  5. Oct 3, 2020 at 2:18 PM
    Asimov2025
    Asimov2025 Not Sure
    Trent Woods, NC
    2019 TRD 4x4 Sport
    Non-stop mods
    I wait for the oil pressure to come then go.
    jamess28, Hoff and lamboboy732 like this.
  6. Oct 3, 2020 at 2:44 PM
    RPR
    RPR New Member
    2005 Tundra SR5 2WD Silver
    This is from the automotive repair shop I’ve used for many years website’s FAQ
    My mechanic says I should let my engine warm up before driving. Is this right and for how long?
    Yes, but long warm up periods are unnecessary, because of the viscosity and computer control of the engine. Cold engines will idle at a speed, much higher than an engine that is fully warmed up. Within a few seconds, engine idle will return to normal, and then it is safe to put the vehicle into gear. Pulling a vehicle into gear, with it racing at high idle can cause damage. Normally, 10 to 30 seconds is sufficient or when idle drops below 800 RPM.”
    http://www.agcoauto.com/odfaq/index.php?p=default&cat=5#a1083
  7. Oct 3, 2020 at 3:21 PM
    Pucks18
    In my 01 it takes a good minute and a half or 2 for the engine idle and oil pressure to go down
  8. Oct 3, 2020 at 4:16 PM
    Professional Hand Model
    Hand Protectors
    Summer start and go, but keep RPM’s low until she warms fully in a few minutes.
    Winter she gets warmed up for a few minutes. Driving RPM is kept low until full warm up.
    bassman417[OP] likes this.
  9. Oct 3, 2020 at 5:23 PM
    ezdog
    ezdog New Member
    Gateway To The West
    I try to let the engine coolant temp come up to 100 degrees before launch.
    Can not really say why?
  10. Oct 3, 2020 at 5:43 PM
    tmac58star
    tmac58star New Member
    Black 1st generation Tundra SR5 Access Cab
    Let it build oil pressure, then go...maybe wait until the fast idle kicks down, esp. in winter. Saves wear and tear on your U-joints, which I hate to change, and my bendy joints getting under and out from under the truck if I have to change U joints.
  11. Oct 3, 2020 at 5:51 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    I let it idle long enough to find a song on the radio. I drive gently until its up to temps. I don't live in a climate that gets very cold so I don't see a reason to mess around burning gas to heat the motor up.
  12. Oct 3, 2020 at 5:55 PM
    “J”
    “J” New Member
    NC
    2021 Tundra SR Barcelona Red
    My driveway is 3/4 of a mile long, idle out and then let her rippp.....
    bassman417[OP] and GODZILLA like this.
  13. Oct 3, 2020 at 7:09 PM
    shifty` In South Dakota Trouble ain't hard to find
    I typically fire it up, then wait for idle to kick down. Seems to be a 30-60 second affair most days. My truck is garage-kept and the garage stays pretty consistently around 55-70° between cold and warm months because it's partially underground.
    bassman417[OP], YardBird and GODZILLA like this.
  14. Oct 3, 2020 at 7:30 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    I usually let mine run till it come off high idle, old habits die hard. Remember when you couldn't get the carburetor on your truck to kick down till the spring on the manifold warmed up, and then you had to give it a good kick to the floor?, i do. :eek2: :)
    shifty`, 270Fan, ezdog and 1 other person like this.
  15. Oct 3, 2020 at 7:48 PM
    Baja Mike
    Baja Mike Baja Aficionado
    South Bay, Ca.
    2016 Tundra TRD 4x4 SR5 white
    LED interior lights, Baja Designs foglights, Baja Designs S8 hood bulge light bar, LED bed lights, Baja Designs S8 amber bar in bumper on Rago Fab mounts, AMP Research bedstep, Switch Pros sp-9100, tinted door windows
    Turn the key and floor it immediately.
    :D
    I let it warm up for more than a minute and less than 5. Open door, turn the key, get in it, seatbelt, take down sun visor, plug in phone, set up Pandora on phone, turn on lights if needed, adjust climate control/defogger, put in gear, slowly cruise down the street until the electric choke turns off/idle returns to normal.
    There's a lot of oil and a big block of metal to heat up.
  16. Oct 3, 2020 at 8:45 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    As long as you don't romp on it when it's really really cold right after starting it, key in and go should be fine.
  17. Oct 3, 2020 at 11:02 PM
    SouthPaw
    SouthPaw The headlight guy
    2000 Limited 4x4 AC
    Sounds like I’m the opposite of most. My day starts at 4:00am with me getting in the truck and driving at 4:30am. I wake up, get dressed and remote start my truck while I finish getting ready. By the time I finish everything, it has had 10-20min of warm up time. The shop ‘messed up’ with the remote start timer as I requested it have 15min increments but it will staying running until I turn it off. I don’t like getting into a cold truck so this gives it time to nice and toasty.
    I’ve been this way as long as I can remember. I like to give it at least five minutes to get the juices flowing before I start driving it. The first start of the day is always the longest and after that, I only remote start it when I’m walking up to it or trying to signal the old lady it’s time to go... lol.
    I’m probably more excessive than most especially comparing my tundra to my Duramax. My Chevy came factory with remote start with only (2) 10 min remote start cycles. After that, you have to start with the key. GM only saw the need for a big diesel engine only being warmed up for 20min at most, so maybe I’m OCD.
  18. Oct 3, 2020 at 11:54 PM
    jwatt
    jwatt I heart men
    Jack
    Oregon
    I try to wait until the loud ass fan in my 07 stops spinning; about a minute, though I ve had several complaints from a few of my neighbors about how loud my truck is. It kind of funny, because it s stock. It s the noise from the fan they are complaining about, so if I have to take off when it s sleeping time for most folks in my apt building I just start it and drive. That being said; any cold engine should be handled with care.
    YardBird and bassman417[OP] like this.
  19. Oct 3, 2020 at 11:58 PM
    jwatt
    jwatt I heart men
    Jack
    Oregon
    Did it look like this?
  20. Oct 4, 2020 at 6:02 AM
    Schcoman
    Schcoman From behind the Redwood Curtain
    Humboldt Co. CA
    2000 Access Cab 4.7L V8 4x4 SR5
    None
    I was taught it's always better to bring the engine up to temp while driving because the engine wears differently under load vs. idle and the wear is more even. I start, let the OP build a little before putting the truck in gear and go. Just don't hammer on it until the temp is up to normal.
  21. Oct 4, 2020 at 11:09 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    eh.. unless its like -20 outside i usually just give it a minute and go. don't beat on it until that coolant temps reading 186 on the scan gauge though.
    bassman417[OP] and YardBird like this.
  22. Oct 5, 2020 at 3:58 AM
    0.S.T.
    0.S.T. New Member
    EAST COAST
    2007 BLACK TUNDRA 4X4 CREWMAX LIMITED 5.7 LITER
    IN ALL my rides, I wait till high idle drops. Then drive slow out of hood. By the Time I am at the entrance of hood, I am ready to go.
    But I still drive slow till I need to go fast.
    7.3 Liter Diesel Ford Super Duty E350 Van- whole different story.
    O.S.T.
  23. Oct 5, 2020 at 4:23 AM
    Pucks18
    For example, this morning is 37 degrees out, warmup time 5 mins plus easy driving for the first 5 mins
  24. Oct 5, 2020 at 5:34 AM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    I have autostart, so I let it idle for a good couple minutes before I drive. Usually like to see coolant up to 130 or so, but I always like to wait until the idle goes down.
  25. Oct 5, 2020 at 5:53 AM
    Piney
    Piney New Member
    South Jersey Pine Barrens
    2020 MGM TRD Pro
    I'll start, and it usually takes me a minute to get settled in before I'm ready to drive. When it gets cold, I'll let it warm up a few minutes and drop out of high idle before I drive.
  26. Oct 5, 2020 at 5:58 AM
    drowhawk
    drowhawk New Member
    '19 Tundra SR5
    40F and higher: Start engine, wait for AIR pump to shut off, drive vehicle and keep RPMS below 3000 until ECT is up to temp.
    20F-40F: Start engine, warm up for 5 mins, drive vehicle and keep RPMS below 3000 until ECT is up to temp.
    20F and below: Start engine, warm up for 10 mins, drive vehicle and keep RPMS below 3000 until ECT is up to temp.
    Also: If I am towing, I always give a minimum 5 min. warm up, regardless of ambient temperature.
  27. Oct 5, 2020 at 6:02 AM
    I'd love to live in a lower-density area where I could do this w/o my vehicle eventually getting stolen. :D
    High density of humans = high probability of opportunistic crime.
  28. Oct 5, 2020 at 6:16 AM
    ezdog
    ezdog New Member
    Gateway To The West
    It is strange but as I get older I am somehow much more tolerant of sitting there waiting in the cold?
    I pretty much wait until 100 degrees or when I start getting good heat which used to Kill me but now is just not a big deal?
    And same here,there is no letting the car sit running unattended anywhere EVER if you want to see the car again!
