Wanting to run 35" tires????
Discussion in 'Suspension' started by Caljr02, Jun 18, 2017.
  1. Jun 18, 2017 at 9:44 PM
    Caljr02
    Caljr02 [OP] New Member
    Cal
    Bay Area, CA
    2017 Super White SR5 CM 4x4
    5" Zone Off-road Lift, 18x9 Moto Metal Shifts, 35x12.5 Falken Wildpeak
    So I have a 2017 CM 4x4 and I am looking to lift it but would like honest opinions outside of a shop that may be trying to screw me. So I am looking to run 35" tires on 18" wheels, very interested in a lift that will give it a decent look, would consider 33" as well just depends on a lift. Some ppl say I need a 6" to run 35's while others are saying a 4" can clear 35's. Overall I just want it to have a nice stance and look, it's my daily driver so not looking to go crazy with it, so just looking for advice and recommendations. I live in Northern California if anyone can point me in the right direction. Thank you
    Wakekid686 and Mountun Goat like this.
  2. Jun 18, 2017 at 10:00 PM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    FWIW, I'm running 34.6 (285/65/R20) on a 3.5" lift. Those tires fit fine when I had a 3" spacer lift as well. No rubbing, or cutting using factory wheels, although its about a pinky-width from my UCAs.
    TexMedic and Caljr02[OP] like this.
  3. Jun 18, 2017 at 10:03 PM
    computeruser6
    computeruser6 Gott Mit Uns
    Dirk
    Escondido
    2008 Regular Cab Tundra
    You do not need a 6" or 4" lift to fit 35" tires. You can fit a LT285/75R18 (35") tire on OE 18x8" wheels if you raise the front about two inches. I'm currently running LT285/70R18 Nitto Exo Grapplers on OE 18x8" wheels with some King 2.5 coilovers set for about 2" of lift and SPC Light Racing upper control arms (you don't actually "need" these but it helps with alignment a lot and has more travel).
    Fernan6892, Gman16Pro, equin and 2 others like this.
  4. Jun 18, 2017 at 10:09 PM
    Caljr02
    Cal
    Bay Area, CA
    Thank you both I appreciate it. I actually do want to run just a 18" wheel as well. Just want it to have a nice look and stance but still be able for my wife n kids to get in comfortably
  5. Jun 18, 2017 at 10:24 PM
    Eclipsed & Floating
    I’m right where I need to be
    Voluptuous Whitey
    It'll be fine with 35s on a 3+ lift. Offset, brand of tire, and brand of wheel will determine what kind of rubbing you'll have. I didn't have to cut any metal, just a littLe plastic from the bumper.
  6. Jun 18, 2017 at 10:24 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    If you get the right tire width and offset you can fit them with a 3" lift. Where in NorCal are you?
    Law323 and Caljr02[OP] like this.
  7. Jun 18, 2017 at 10:30 PM
    Caljr02
    Cal
    Bay Area, CA
    I am in the Bay Area
  8. Jun 18, 2017 at 10:34 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Cool. There's quite a few of us in the Bay Area. Keep an eye out for this thread. https://www.tundras.com/posts/246252/
    We should be having a meet soon.
    Caljr02[QUOTED][OP] likes this.
  9. Jun 18, 2017 at 10:43 PM
    Caljr02
    Cal
    Bay Area, CA
    Will do thank you
    joonbug[QUOTED] likes this.
  10. Jun 19, 2017 at 2:45 AM
    chphilo
    chphilo Tundra addict
    Western PA
    There was a member on TT who ran 35x12.5 with Bilstein kit. His wheel offset was either 30 or 35. I have 3.5 OME lift and cannot go larger than 34.5 that I currently have without having to cut something serious. 18 mm offset makes it that much closer to the body mount. If you run 0 offset, you are limited to about 33. Of course, if you are willing to cut your truck up, then that's another story. As I recall, the Tundra Pro that won Baja 1000 had 37 inch tires.
    Caljr02[OP] likes this.
  11. Jun 19, 2017 at 3:33 AM
    Spolar
    Spolar Going broke
    Zac
    Seal Beach CA
    2016 sr5
    The 17" wheels I'm selling right now fit a 315/70 (34.5") tire with no rubbing except removing the front mud flaps. They are 25mm offset and 5.75" backspacing. The new wheels I'm running are 0 offset and they rub hard without a cab mount chop and front bumper trimming. Stock wheels should be okay with a 2-3 lift and minor pastic trimming.
    equin and Caljr02[OP] like this.
  12. Jun 19, 2017 at 4:53 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Everybody else covered it well.
    You'll be fine with 3/1 and 35's depending on the offset of the wheel.
    zcarpenter92 and Caljr02[OP] like this.
  13. Jun 19, 2017 at 6:37 AM
    TRDpro619
    TRDpro619 Follow My Build on Instagram:TRDorcaTUNDRA
    San Diego
    TRD Pro CM
    I was in the same position that your in, went ahead and got the 35s. 18x8 +60 trd pro wheels on 35x11.5r18 nitto trail grapplers. I'm on pro suspension so it's around 2/1 lift. Without any fender modifications they fit fine rubs a little when fully locked reversing but I haven't even bothered moving the plastics forward, there's plenty of threads showing how to make clearance keeping the liner and Keeping it clean looking stock
    http://www.tundratalk.net/forums#/topics/88918?page=1
    But I could have easily went with the 12.5" tire and put a spacer to wide it out but I found a killer deal on the 11.5"
  14. Jun 19, 2017 at 7:15 AM
    Caljr02
    Cal
    Bay Area, CA
    Are you near the Bay Area and if so do you recommend any shops to do a lift?
  15. Jun 19, 2017 at 7:35 AM
    TTU19
    TTU19 Wreck 'Em
    Wes
    Tx
    2021 TRD Sport
    I'm still in the same boat. I want to go 35s, but I think I'm going to get 295/7018, which is a 34.3 I think and 11.6" width. So it's pretty close to 35, but give you a little bit more clearance.
  16. Jun 19, 2017 at 7:58 AM
    Caljr02
    Cal
    Bay Area, CA
    Yea I'm thinking the Rough Country 4" lift with 35's or close to it on 18's
    TTU19[QUOTED] likes this.
  17. Jun 19, 2017 at 8:00 AM
    295/70/18 is what I ran last time and was 34.5"
    When my Coopers wear out, I'll prob go back to that size just to recoupe a tad bit of more power back
  18. Jun 19, 2017 at 8:19 AM
    TTU19
    TTU19 Wreck 'Em
    Wes
    Tx
    2021 TRD Sport
    That's another good reason I'm thinking those instead of 35s. Gotta be some weight difference, so a little more power, better MPG on the 295 vs 35s, although I'm sure it's very little.
    moto metal max and Caljr02[OP] like this.
  19. Jun 19, 2017 at 8:33 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    My buddy @dcsleeper408 installed mine for a really good price. He's in this forum and he's done a few of the guys' here. I highly recommend him as you know he'll do it right. Give him a PM. And about the wheels, most 35's are 12.50" wide. That's where you'll run into problems. 295/70/18's are slightly narrower and about 34.5" and you'll have a lot less trimming to do.
  20. Jun 19, 2017 at 9:36 AM
    Vector W8
    Vector W8 Old guy with a lot of expensive habits.
    FFV, TRD Supercharger, Bullydog FFV Tune, 2014 Fit Kit, TRD Dual Exhaust, Sequoia Front Sway Bar, TRD Rear Sway Bar, TRD Skid Plate, TRD Pro Grill, 040 White Mirror Covers, 040 White Door Handles, Ready Lift 3"/2", Anzo 3rd Brake Light, Winjet LED Tail Lights, LED Fog Lights, LED Rock Lights, Axle Vent Mod, SDHQ Hidden Winch Mount, 12,000lb Winch. Storm Trooper Shift Knob. BMF BATL Wheels.
    I am running 35.4" Tires 295/65/20's I have a 3" lift front and 2" rear. I can tell you with my set up (+12mm) offset on the wheels, you will rub. I need to do the cab mount chop and I am rubbing on the inside of the front bumper which I have trimmed and removed the small mud flaps. I should have went with straight 35" tires which actually measure 34.5 and I would have almost cleared.
  21. Jun 19, 2017 at 10:05 AM
    moto metal max
    moto metal max New Member
    Derrick
    2017 crew max leveled with moto metal and toyos
    leveled tires and rims
    I have a 2017 CM with a trax Da leveling kit on mine I have nitto trail grapplers LT295/60r20 on moto metal 961s 20x9 little bit of rub I really don't take it off road much just pull my boat gas mil about 14.3 with or without boat that's highway
    Mountun Goat and Caljr02[OP] like this.
  22. Jun 21, 2017 at 10:20 AM
    Caljr02
    Cal
    Bay Area, CA
    so yours is a 18mm offset, the wheel I'm looking it has a 20 offset, do you know if that would rub?
  23. Jun 21, 2017 at 2:27 PM
    Tacotundra
    Tacotundra New Member
    Vegas
    2022 Tundra
    Check out post #811 on
    Official Tundra Wheel and Tire Setups - Pics and Info.
  24. Jun 21, 2017 at 2:36 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Tacotundra[QUOTED] likes this.
  25. Jun 21, 2017 at 2:38 PM
    Tacotundra
    Vegas
    2022 Tundra
    Thanks for fixing that joonbug
    joonbug likes this.
  26. Apr 1, 2018 at 12:16 PM
    Ericscott44
    Ericscott44 New Member
    Grey beast
    Lift. 35s. Dual exhaust.
  27. Dec 16, 2018 at 9:39 AM
    Jhayxian
    Jhayxian New Member
    X
    Did you have to drop differential for this set up? Which leveling kit?
  28. Dec 16, 2018 at 9:58 AM
    Ericscott44
    Grey beast
    Jamesp413 and r1-superstar like this.
  29. Dec 19, 2018 at 8:28 PM
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
  30. Dec 19, 2018 at 8:30 PM
    matictundra
    matictundra New Member
    Franco
    AZ
    2017 Red Tundra SR5 4x4 CM
    3"/1.5" Lift (Fox 2.5 DSC all around, JBA UCA's and Toytec Shackles at 1.5") Front and Rear TRD Sway Bars Nitto Ridge Grappler 37x12.5R18 w/ Brz 18x9 +25mm Methods MR701 Wheels AFE Dry Filter with TRD Flow Acc Dirty Deed No Muffler Exhaust Nitro 5.29 Gears RCI Engine, Trany/Trans-Case and Fuel Skid Plates Relocated Rear Diff Breather | Rear Brake Line Extension Jomax ABS Sensor Armor Colored Matched Front Bulge and TRD Pro Grill Assy Modded ADD Stealth Fighter Front Bumper Custom High Clearance Rear Bumper with Modded Tow Receiver Behind Plate and Chopped Rear Fender Custom Bed Stiffeners 2019 TRD PRO LED Headlights w/ Ihacker Harness | BD 40" ARC AMB/WHT DC OnX6 BD 10" Onx6 in the Grill (2X) Rago Low-Profile Ditch and Extended Brkt with Daul BD Squadron Pros - AMB & WHT AMB LED Chase Light (Cargo) | Dual BD Squadron Sports in Rear Bumper Prinsu Roof Rack with a Pair of BD S1 For the Sides and Rear Mictunning C2 Rock Lights, 2 per wheel, and Toyota style switch 2X 55" Quick Light Whips with Toyota style switch Switch Pros SP-9100 with Custom Switch Mount, Custom Engine and Roof Terminal Junction Boxes 12K Lbs Smittybilt Winch with wireless remote and Factor 55 FlatLink E Amp Power Step EVO-One Remote Start Limo Tint (All Around) | De-Badged LED Interior lights with Front / Rear Interior Footwell LED Blue LED Lit Lock/Window Switch Mod AJT Full Chrome Delete Kit w/ 3R3 Painted SHCS Toyota LED Bed Lights Leather Perforated Wrapped Steering Wheel Black TRD Shift Knob ESP Long Box BakFlip MX4 Bed Cover Thinkware Q800Pro Dashcam (Front & Rear) Rago Dashmount w/ Ram Phone Holder
    I’m running 37’s on 3/1.5 lift, go big.
