[Wanted] Pro Comp 6-7" spacer
Discussion in '2.5 Gen Tundra Parts Marketplace (2014-2021)' started by Spvrtan, Jun 13, 2018.
Thread Status:
Not open for further replies.
  1. Jun 13, 2018 at 11:56 PM
    Spvrtan
    Spvrtan [OP] Amateur fabricator
    Kris
    San Diego, CA
    For those that have a PC bracket lift but are running the larger coilovers that eliminate the top spacer, can I buy the spacer off of you since it's just sitting around (ie. if you still have it)?
    It looks like the black spacer bolted to the top of the OEM coilover in the photo below..
  2. Jun 16, 2018 at 10:00 PM
    airosey
    airosey 2009 CrewMax Limited 4x4
    East TN
    Slightly modified 2009 CrewMax Limited 4x4
    09 Tundra CrewMax Limited TRD Supercharger with URD pulley Tuned by OrangeVirus tuning (OV Tune) TRD Big Brake Kit with SS lines and titanium backing plates StopTech rear sport axle pack (rotors, pads, and SS lines) 7” Pro Comp lift 3” Performance Products Body Lift Coachbuilder 1” coilover shims Coachbuilder +3 shackles Coachbuilder Tie-rod ends 22x14 -70 Fuel Lethal’s - 2 piece 38x15.5 Mickey Thompson Baja Boss M/T’s King Shocks with remote reservoirs front and rear Nitro 5.29 gears front and rear Auburn LSD SPC adjustable UCA’s BAM 8” exhaust Pro Comp Traction Bars Enve Grille Smittybilt M1 front bumper Rough Country 12k lbs winch Demon Hook shackles front and rear Baja Designs Squadron Sport Amber and clear fog lights ADD HoneyBadger Rear Bumper with Rigid SR-Q reverse lights Sequoia Headlight conversion Switch-Pros SP-9100 mounted in overhead console SD Off-road MT under-hood tray AEM boost and afr gauges Hypertech Speedometer calibrator Bed and rear bumper are Bulletlined American Flag Headliner Mammoth Guards patriot edition Alpha and Omega Fabrication Patriot Hood shield 3rd gen door panels and steering wheel ProSpeed Catchcan Hornblasters Outlaw train horns Tufskinz real carbon fiber overlays Tufskinz carbon fiber B panels vLEDs footwell lighting front and rear vLED puddle lamps Lighting Trendz flow series wheel rings 16 RGB rock lights Toyota Bedmat Bestop Power folding steps Undercover bed cover Undercover SwingCase 4 gallon Rotopax fuel can Here’s a rundown of the audio setup. -Active front stage using a JL Audio TwK88 DSP, Focal 165KRX2 component speakers, powered by a JL Audio HD900/5 -Passive rear setup with Focal 165KRX2 component speakers -2 JL Audio Stealthboxes (13TW5’s) powered by a JL Audio HD1200/1 -Sony XAV-9500ES float mount display with a PAC Radio Pro 4 -Odyssey battery -JL 0 gauge power and ground cables -AudioQuest X-2 speaker cables and Golden Gate RCA interconnects -Entire cab has been lined with Dynamat Extreme and 1/4 CCF Amps and dsp are mounted under the passenger seat with a SoundsGoodStereo mounting plate.
    I’ve got a set. Brand new as well. I have the 1”pre load spacer as well.
  3. Jun 16, 2018 at 10:09 PM
    Spvrtan
    Kris
    San Diego, CA
    How much you want for it shipped to 92128? I don't need the pre-load spacers. I think the top spacers might fit in a USPS flat rate priority box.
  4. Jun 17, 2018 at 12:52 AM
    airosey
    East TN
    Does $100 plus the actual shipping price sound fair?
  5. Jun 17, 2018 at 1:00 AM
    airosey
    East TN
    I just open them up and snapped a pic. Has the hardware as well.
  6. Jun 18, 2018 at 5:57 PM
    Spvrtan
    Kris
    San Diego, CA
    Damn.. was hoping to spend $100 tops, haha. Could you do $100 shipped!? I think it would only be like $10-15 in a USPS flat rate box.
  7. Jun 18, 2018 at 10:11 PM
    airosey
    East TN
    I can do that. I hit you up on Facebook messenger yesterday. You can send me your info there if that’s ok.
Thread Status:
