WANTED : Fender flare MOUNTING piece only 2015 Tundra
Discussion in '2.5 Gen Tundra Parts Marketplace (2014-2021)' started by mzim, Oct 24, 2024.
  1. Oct 24, 2024 at 7:03 PM
    mzim
    mzim [OP] New Member
    Max
    Waterloo, Iowa
    2015 Tundra DC Silver Sky
    275/65/20 Goodyear Wrangler Duratracs (May2024) Full ARH long tube system Bilstein 6112 Front +2.7" Bilstein 5160 Rear & Icon 1.5 AAL & +2.0 Shackles Fender Flares 1D6 White Knuckle sliders TRD Grille Morimoto LED Headlights with LED DRL/sequential amber switchback turns Rigid Fogs with Square TRD Bezel 4x LED bed lamps wired in OV Tune base load with iterations coming Tech12Volt remote with 2 way fobs and range extender antenna 4.88s with Auburn TRD skid plate Koyo radiator - FAILED REINSTALLED OEM Tyger tri-fold bed cover Bed mat from Boss 4x4 Front bumper spacers 0.5 inch by Boss 4x4 Pop n Lock tailgate wired in Black badging all around Classico Faux Leather Seat Covers Rough Country Floormats Halo 9 HU Underseat kicker sub JRT upgraded speakers
    Hello, I broke my right (passenger side) fender flare mount. The small plastic piece that bolts to your upper inner fender well enabling you to mount flares to . Here is a link
    https://static.thiecommerce.com/assets/production/bushwacker-oe-tundra-install/890fcb08f786abafc464ffc59052b714.pdf
    that shows flare installation on a 2015 tundra. Scroll down and you'll see where it says 2X BRACKETS. I only need the right hand one. Unsure if they're swap-able side to side. They may be.
    Let me know if you have one lying around please. Thanks.
  2. Oct 24, 2024 at 7:17 PM
    Give Bushwacker a call, they will probably send you one for free, the are a decent company.
    1-800-241-7219
    mzim[OP] likes this.
  3. Oct 24, 2024 at 7:22 PM
    mzim
    Max
    Waterloo, Iowa
    TThank you...... I sent an email to REALTRUCK three days ago. No reply.
    I'll give BW a call. These brackets come with the 4 fender flares as a kit. Im unsure
    if they'll tear open a box just to send me one bracket.
    But we'll see what they say. Thanks again.
  4. Oct 24, 2024 at 8:41 PM
    :hattip:
    :fingerscrossed:
  5. Oct 25, 2024 at 2:53 AM
    Let us know what you find out. I don't think i installed those with mine and I have never had an issue. If I didn't install them, I'm positive that I still have them. I will look through my garage this afternoon.
  6. Oct 25, 2024 at 7:49 AM
    AZTundra
    Paul
    Phoenix, AZ
    I’ve got a set of these brackets in my garage. Not sure which brand of flares I had since I got them second hand, but I recently took them off because the paint was beginning to chip. I tossed the flares, but for some reason I held onto the brackets. I just went to check and I do still have them. They look identical to the ones from the instructions you linked above. They do appear contoured differently for each side so you will need the correct side bracket to install it. Send me a PM and I’ll ship them out to you.
  7. Oct 25, 2024 at 8:04 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    They wont do that.
    I have a set of color matched bushwackers that are missing the same brackets from a member here. His were missing the brackets from his order and after a bunch of back and forth with bushwacker, the ended up sending him a complete new set.
    After i picked them up i tried to call bushwacker to see how to get a set of brackets, they told me that the flares and brackets are all "shot" from the same piece of plastic, so it all comes as a set, and thats why they wont split them up. They said the best thing to do would be buy the cheapest set of flares (i guess they all use the same bracket) and try to sell the flares and keep the bracket....i think it would cost around $200ish when i checked.
    I've been on the hunt for brackets like you are, but came up empty. Pretty cool that @AZTundra might have some.
    If anyone else on here has a set, hit me up!
    AZTundra likes this.
  8. Oct 25, 2024 at 8:08 AM
    AZTundra
    Paul
    Phoenix, AZ
    If @mzim only needs one of the brackets you’re welcome to the other. I’m not sure which is which so I might have to send him both and have him forward the other to you unless there is a way tell.
    Danimal86[QUOTED] likes this.
  9. Oct 25, 2024 at 5:08 PM
    I'll see if I can come across mine.
  10. Oct 25, 2024 at 5:18 PM
    I looked at the installation sheet online. They are supposed to be marked with LF and RF somewhere on them.
  11. Oct 25, 2024 at 6:31 PM
    AZTundra
    Paul
    Phoenix, AZ
    You're right. I just went and looked at them again. There is an "L" and an "R" underneath the dirt. They were stamped on the backside (not shown on the above picture I took).
    Tundra234[QUOTED] likes this.
  12. Oct 27, 2024 at 11:32 AM
    Danimal86
    Daniel
    Sacramento, CA
    lemme know if you find em!
  13. Oct 27, 2024 at 11:32 AM
    Danimal86
    Daniel
    Sacramento, CA
    sounds good!
    AZTundra[QUOTED] likes this.
  14. Dec 30, 2024 at 6:39 PM
    mzim
    Max
    Waterloo, Iowa
    SORRY I JUST NOW SAW THIS. Do you still have these? I'll take them if so. Let me know please.
    THANKS. I currently have cobbled a piece of metal for the time being but its not holding the flare snug.
  15. Dec 30, 2024 at 6:51 PM
    AZTundra
    Paul
    Phoenix, AZ
    Hey Max.
    Sorry, but after not hearing back for a while I had shipped them out to the next person in line that was in need of them. :anonymous:
  16. Dec 30, 2024 at 7:14 PM
    mzim
    Max
    Waterloo, Iowa
    OK thanks. I wonder why I missed getting notified last Oct? I currently have a short piece of metal cobbled in but its not holding the flare snug enough. Thanks for your initial consideration. --- MAx
