Want tuner for 4.6
Discussion in 'Performance and Tuning' started by cquilichini, Jan 21, 2019.
  1. Jan 21, 2019 at 5:45 AM
    cquilichini
    cquilichini [OP] New Member
    Hey Guys, can anyone suggest a tuner for the Tundra with a 4.6L engine?
    Thanks in advance.
  2. Jan 21, 2019 at 5:52 AM
    Adriver71x
    Adriver71x New Member
    Gerald
    2015 Tundra SR5
    Tow Mirrors
    Welcome from Northeast Connecticut. Someone will ring in on a tuner
  3. Jan 21, 2019 at 8:01 AM
    dirtydeeds
    Keith
    USA
    more than I can list here
    Only thing available for a 4.6 is Hypertech. But if your truck is 14+ it’ll likely throw a check engine light.
    To optimize a stock truck:
    Stock air box mod
    Throttle body coolant bypass
    Bamufflers catback
    15whtrd likes this.
  4. May 30, 2019 at 8:02 AM
    vhicks
    vhicks New Member
    vince
    13 tundra 4.6
    lift 3 inch 33 tires
    dirty deeds can you maybe explain what the coolant by pass does. I've seen a lot of back and forth but no exact answer.
    dirtydeeds likes this.
  5. May 30, 2019 at 8:10 AM
    cquilichini
    Can someone explain in what consists the Stock air box mod?
    Thanks.
  6. May 30, 2019 at 8:29 AM
    dirtydeeds
    Keith
    USA
    By lowering intake temps you reduce pre ignition
    Our ecu constantly pushes for more timing. It’ll add a degree here degree there little by little until it hears preignition, then pull a block of 4 degrees!!
    Then later try to add it back. And the cycle continues.
    By suppressing pre ignition by lowering intake temps you get to keep more of the timing your ecu is trying to give you.
    To sum it up, initially there is zero difference. But in the long run there is slightly better performance. Being a totally free mod what do ya have to lose??
    15whtrd likes this.
  7. May 30, 2019 at 9:08 AM
    vhicks
    vhicks New Member
    vince
    13 tundra 4.6
    im putting on the trd intake this weekend! what does the tuner do in regards to performance? is the trd intake worth putting on? my issues is I fill like I've lost some low end pull. I want to make sure I put on the right stuff for more bang for the buck.
  8. May 30, 2019 at 10:48 AM
    vhicks
    vhicks New Member
    vince
    13 tundra 4.6
    what is the best tuner hypertech has 2 but im not sure which one to go with
    they have one that plugs into the truck under the hood looks like plug and play
    the other one looks like it pugs in and you can adjust the performance
  9. Jun 14, 2019 at 11:38 AM
    rodneysworld
    rodneysworld New Member
    rodney
    2011 charcoal gray tundra
    series 77 K n D intake, rims and tires, KYB shocks, leveling kit, drilled slotted rotors, carbon fiber pads, interceptor tuner, flomaster catback dual exhaust, Spider halo projector headlights, Pioneer head unit, JL Audio Amps, JL Audio allaroundSpeakers
    I have hypertech and pedal Optimizer very noticeable difference
  10. Jun 14, 2019 at 11:52 AM
    Trooper2
    JR
    Houston, TX (Suburban South)
    search youtube for Tundra SABM, it adds an additional coduit for air flow to the box.
  11. Jun 19, 2019 at 7:50 AM
    dirtydeeds
    Keith
    USA
    Try it without the pedal module. Just the Underwood module. It really wakes up:)
  12. Jan 30, 2020 at 7:01 PM
    Soda722
    Soda722 New Member
    Louisiana
    2015 Tundra
    Underwood module????
  13. Feb 1, 2020 at 10:14 PM
    Soda722
    Soda722 New Member
    Louisiana
    2015 Tundra
    Anybody know anything about this?????
  14. Mar 29, 2020 at 9:26 AM
    dirtydeeds
    Keith
    USA
    Underhood
