Want to tow more weight with Tundra / payload
Discussion in 'Suspension' started by Spotcw119, May 5, 2020.
  1. May 5, 2020 at 6:07 PM
    Spotcw119
    Spotcw119 [OP] New Member
    William
    2012 Tundra
    Hello fellow Tundra fans. I have a 2012 Tundra with 5.7 motor. I want to tow a 9000lb trailer and put 4 dirt bikes in bed (I have 8’ bed). I currently tow a 6k lb trailer with bikes in bed with no problems. Can anybody stear me in the right direction to upgrade suspension, etc to handle the heavier trailer. I love this truck and don’t want to buy a 3/4 ton or bigger Thanks!
  2. May 5, 2020 at 6:48 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    9,200 lbs is about the max towing on these trucks. 8500lbs plus the weight of 4 bikes will certainly be over 10,000 lbs. Sorry, but to do this safely, you’re in 3/4 ton territory.
    zcarpenter92 and Lake.Life24 like this.
  3. May 5, 2020 at 6:55 PM
    Redcon41318
    Redcon41318 New Member
    True^, i always hear it could tow this, i could tow this. Bottom line if you are over weight it’s unsafe and illegal. If the law catches you, you will learn the hard way.
    3/4 ton gas powered rigs are dam reasonably priced nowadays and no i am not knocking on tundras,
    But every man needs to know their limits. I love my Tundra, but when I borrow the families 6,000 dry weight toy hauler with a tongue weight of 900lbs, i use the
    Families 3/4 duramax. Safety first!
    zcarpenter92 likes this.
  4. May 5, 2020 at 6:58 PM
    zombie
    zombie Master at Something
    paul
    Rhode Island
    2007 Black DC 4x4
    My Gen 1 with the 4.7 could do that.
    CodyP and Y0TA PR0 like this.
  5. May 5, 2020 at 7:01 PM
    Redcon41318
    No chit it could do that, my grandmas honda ridgeline could haul it but will it be safe and practical? Doubt it.
  6. May 5, 2020 at 7:25 PM
    specter208
    specter208 New Member
    2017 Tacoma and 2005 Tundra RGCAB
    Put the dirt bikes in the trailer. 6OO LB tongue weight with 1OOOlb motos is over payload, with no passengers. extra 1000lbs in the trailer only adds about 100lbs to the trailer tongue. You will have payload left over for your passengers.
  7. May 7, 2020 at 12:36 PM
    Spotcw119
    William
    2012 Tundra
    Did some looking around (first time I ever read owners manual for truck) and discovered the max tow weight for my truck is 9800lb. Max weight of truck/trailer is 16000lbs. Truck itself is rated at 4000lbs front axel and 4100lbs rear axel. My plan is to load up the Mx bikes and family and go to weight station to see where I’m at. That’ll indicate where I’m at with the max weight of 16000lbs and the weight on each axel. Then, I can shop for trailer that is safe weight. Any thoughts on sumo bags to assist with bed weight?
  8. May 7, 2020 at 1:05 PM
    specter208
    Use a weight distribution hitch. Best choice for suspension sag and improves braking in one shot.
