Want to level truck
Discussion in 'Suspension' started by fingers1126, May 4, 2018.
  1. May 4, 2018 at 5:52 AM
    fingers1126
    fingers1126 [OP] New Member
    Im looking to level out my 2017 Tundra i do only on road driving just want to get rid of front end rake ... looking at different ways and means of doing this . im thinking of just doing the space design but different opinions on on top spacer or in mount spacer ...... What is the consensus say ??? just looking to ad 2.5 inches , any help greatly appreciated just dont want to make a mistake and have problems down the road.
  2. May 4, 2018 at 6:00 AM
    Before going spacer lift, I would seriously consider the Bilstein 5100, 6112, OME....
    Check out the vendors section.
  3. May 4, 2018 at 6:04 AM
    Netmonkey
    Netmonkey Don't be a Dumbass
    Georgetown, TX
    2016 Texas Edition, 5.7, CM, MGM
    Icon stage 2 lift, 295 60 20 nitto ridge grapplers, fuel kranks, TRD dual exhaust, TRD rear sway bar
    5100's at the middle setting (1.57")
  4. May 4, 2018 at 6:06 AM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    This ^
    SouthBoundSteve and JDL17CM4x4 like this.
  5. May 4, 2018 at 6:08 AM
    Rica25
    Ricardo
    Tulare
    5100s or 6112 BILLSTEIN
    SouthBoundSteve likes this.
  6. May 4, 2018 at 6:10 AM
    Steve6
    Steve6 New Member
    Tucson
    The general consensus here is that spacer lifts should be avoided. ColoradoTJ's advice is solid. The 5100's would be an upgrade and they don't cost a whole lot more than spacers.
  7. May 4, 2018 at 6:13 AM
    See OP, sexy isn’t it?
    Rides a hell of a lot better as well.
    Netmonkey[QUOTED] likes this.
  8. May 4, 2018 at 6:20 AM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    I have 6112/5160 in rear at 1.9 setting. If you go 2.5 in front you will be nose highly slightly. I’m happy with the setup.
    Gatorbisquit and ColoradoTJ like this.
  9. May 4, 2018 at 6:21 AM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    Breathtaking!
  10. May 4, 2018 at 6:21 AM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    Net monkey, you look pretty damn level at 1.57.
  11. May 4, 2018 at 6:25 AM
    fingers1126
    What are you running for springs ??
  12. May 4, 2018 at 6:25 AM
    Rica25
    Ricardo
    Tulare
    I did 5100s all around and 1 inch block on rear and rides great front is at highest setting
  13. May 4, 2018 at 6:25 AM
    Erichudgins
    Erichudgins New Member
    Eric
    Murfreesboro, TN
    2017 Super white Limited DC
    https://www.tundras.com/threads/the-un-limited-build.25949/
    Man one thing you will learn is that in "most" cases spend the extra cash and get better quality. That being said, I have a rough country 3/1 leveling kit and I notice zero loss in drive or ride quality. I do only on road driving as well and mostly interstate. I'm completely happy with it.
    mattyd170 and BTBAKER like this.
  14. May 4, 2018 at 6:26 AM
    Netmonkey
    Georgetown, TX
    yup.... it is about as level as you can get. here is the before and after
    Black Wolf and WarEagle Tundra like this.
  15. May 4, 2018 at 6:27 AM
    Netmonkey
    Georgetown, TX
    stock coils
  16. May 4, 2018 at 6:27 AM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    Looks good!
  17. May 4, 2018 at 6:29 AM
    fingers1126
    I really would like to go the suspension route esp bilstiens can yoiu use factory springs ??? Also how is the ride. Keep in mind keeping stock tires and wheels ,
    Stock coils on highest setting and dont ride rough ????
  18. May 4, 2018 at 6:29 AM
    phonyteachr
    phonyteachr New Member
    2018 SR5 TRD off-road CM
    With the Bilstein 5100 adjustable struts do you need to add a differential drop kit??
  19. May 4, 2018 at 6:33 AM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    If you are just leveling you don’t need a dif drop.
  20. May 4, 2018 at 6:35 AM
    Wutachampion
    Wutachampion New Member
    DFW
    used to own - 2016 MGM SR5 CM Texas Edition
    Whoa this is like an exact replica of my truck!
  21. May 4, 2018 at 6:37 AM
    Netmonkey
    Georgetown, TX
    hah! yup, we have the exact same trucks... even the same year :)
    Wutachampion[QUOTED] likes this.
  22. May 4, 2018 at 6:40 AM
    fingers1126
    Ok so everyone using the bilsteins your using stock coils on middle or highest setting ?? and not over compressing coil resulting in stiff hard ride ????
  23. May 4, 2018 at 6:47 AM
    The higher the lift the more pre-load essentially.
    JDL17CM4x4 and Stroke250 like this.
  24. May 4, 2018 at 6:48 AM
    Stroke250
    Stroke250 New Member
    Todd
    Idaho
    2023 Ford F-350
    I may push this hard(ok I push it very hard), but only because the quality of parts and service I received were top notch. Get with David @Toytec Lifts and look into the Eibach 3/1. Ride quality is better than stock and its an easy swap to do.
    T-Rex266 and Black Wolf like this.
  25. May 4, 2018 at 6:50 AM
    Netmonkey
    Georgetown, TX
    On the middle setting, the ride is firmer, but not jarring. Actually, the 5100's are a better shock than the stock shocks on the SR5, so I think the ride is better. Also, the choice in tires can change the ride quality. I went from the stock 275/55/20's to the 295/55/20 ridge grapplers. The ridge grapplers have a stiffer sidewall than the stock tires so that could contribute to the additional ride stiffness.
    I can't speak to the 5100's on the top setting. Someone else will have to chime in.
  26. May 4, 2018 at 7:01 AM
    The Eibach's are a great deal too.!!
    Stroke250[QUOTED] and T-Rex266 like this.
  27. May 4, 2018 at 7:04 AM
    Here is the link.
    BTBAKER and Stroke250[QUOTED] like this.
  28. May 4, 2018 at 7:06 AM
    Stroke250
    Todd
    Idaho
    2023 Ford F-350
    Heck yeah, they are priced very well for the quality of parts!
  29. May 4, 2018 at 7:09 AM
    fingers1126
    Yes they are .. im just looking to level off not really interested in lifting rear also ......... so thinking billy's maybe way to go just using stock spring has me worried about too much preload ...
    TexMedic likes this.
  30. May 4, 2018 at 7:21 AM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    I don’t think you are really preloading the spring like a spacer. That’s the advantage. Someone correct me if I am wrong.
    The 6112/5160 I have come with beefier springs and the shock itself is much more beefy than the 5100. It’s most definitely an upgrade if you want to spend a few hundred more. I am at the 1.9 setting up front, nothing in back except the 5160 and I am perfectly level. I didn’t change the UCA and I have no diff drop and I have zero issues.
