Want Better Gas Mileage and More Power. Thoughts?
Discussion in '1st Gen Tundras (2000-2006)' started by Oregon 2006 Tundra, Oct 27, 2019.
  1. Oct 27, 2019 at 7:35 AM
    Oregon 2006 Tundra
    Oregon 2006 Tundra [OP] New Member
    2006 Tundra TRD Limited Double Cab
    Spray-in Bedliner
    As title says, looking for power and better mileage. Thinking complete exhaust system with long tube headers better breathing on top. Thoughts? Also tired of it downshifting so often when on cruise control. Thinking added power may help the shifting. Is there a transmission program to change shift points?
  2. Oct 27, 2019 at 7:39 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Lets say you spend 1100 bucks doing a full exhaust and get 1mpg. How many years do you have to drive to save 1100 bucks on fuel?
    I do agree toyota has the cruise control way too sensitive for downshifts. What size tires are you running?
  3. Oct 27, 2019 at 7:40 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    What kind of MPG are you getting currently?
  4. Oct 27, 2019 at 8:07 AM
    Oregon 2006 Tundra
    Spray-in Bedliner
    "It was my understanding there would be no math."
    265/75/16 Toyo 10 ply M/S. Recently got 10ish pulling trailer and probably 14ish general driving.
    Kerch71 and TX-TRD1stGEN like this.
  5. Oct 27, 2019 at 8:15 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    That sounds about normal. Your tire is slightly taller/heavier than factory, that’s probably the main culprit in your cruise control issues.
    Really depends on what the budget/goal is. I would do 4.56 gears before a full exhaust if it were me as the cost is similar. Would give you some more rpm’s in all gears
  6. Oct 27, 2019 at 8:30 AM
    Professional Hand Model
    Hand Protectors
    Normal as stated above.
    Good starting points below in order of cost effectiveness.
    1)Reduce weight in your truck.
    2)Keep her tuned up. Air tire pressure.
    3) Transmissions are sensitive to the exact fluid levels (effects shifting and power transfer).
    3.5) Eliminate cats.
    4) New Gears.
    5) Exhaust.
  7. Oct 27, 2019 at 9:11 AM
    because_wumbo-truck
    because_wumbo-truck TTC#036 & 1st Degenerate
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    flowmaster 40, DDI injectors, sliders, bumper
    Dirty deeds industries 270cc 12 hole fuel injectors, jba long tube headers, dirty deeds exhaust.
    You got bigger tires? Bigger rear gears.
    You still got money to burn? Uprade your intake tube with Airaid intake tube. Or uprgade the intire intake system but make sure it's a true cold air intake and not a overpriced hot air intake. Maybe add a snorkel.
    If you're not affraid of a little custom work, find a used TRD supercharger for the 2000-2004 4.7L v8 and all the parts to go with it and get to fabricating an adapter plate for it to connect to the top of the 2005-2006 4.7L v8 vvti engine. Then move a.few things around the engine bay and maybe everything fit.nice.
    Or
    Buy the Underdog Racing Development stage 3 supercharger and intercooler kit for the gx470/4runner v8 and make it fit your truck.
    Again if.youre not.afraid of custom work, you can go to any junk yard and find Eaton Generation III M90s superchargers out of old GM cars that you can fab up to work on your engine with enough skill and time.
    TX-TRD1stGEN likes this.
  8. Oct 27, 2019 at 9:49 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    The cheapest and biggest gain is driving habits. Pick up a Scangauge2, calibrate it, run real time mpg and trip average mpg, learn to drive by keeping real time higher than trip average. I would not be surprised if you pick up 2mpg doing this.
  9. Oct 27, 2019 at 10:24 AM
    because_wumbo-truck
    Jon
    Houston, Texas
    Hmm I have a sg2 and I've never run the real time. Just the avg. I'll try this. Thanks.
    Darkness[QUOTED] likes this.
  10. Oct 27, 2019 at 10:31 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    It becomes a fun game. Also watch load "LOD" and you'll get a sense for when you're straining the motor.
  11. Oct 27, 2019 at 10:33 AM
    because_wumbo-truck
    Jon
    Houston, Texas
    Yeah I've done the load before when I haul a trailer
  12. Oct 27, 2019 at 11:53 AM
    PCJ
    PCJ New Member
    State of Jefferson
    2004 DC Limited 4X4
    Lift, Rims, Bigger Tires, Nerf Bars, Black Out Emblems
    IMG_20180928_132026843.jpg It's a truck. They are what they are. It's the old saying " Speed cost,How fast do you want to go". Exhaust, cold air intakes and such are mostly hype. Very little bang for your buck.
    If you want towing power and milage get a diesel. You need to match your truck to your towing needs. I just sold this F-350 to my son because of health/medical reasons. It gets better milage and can tow circles around my Tundra. But I like my Tundra and use it within it's capabilities. Anyway that's just my . 02 cents worth about fuel mileage and power.
    because_wumbo-truck likes this.
  13. Oct 27, 2019 at 11:53 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Well, here's half of the solution:
  14. Oct 27, 2019 at 12:43 PM
    tvpierce
    tvpierce Formerly New Member
    Maine
    Welcome.
    More power and better fuel economy.:monocle: Those two performance metrix are generally at odds with each other. Pick one.
  15. Oct 27, 2019 at 1:11 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Not true at all. You can get more power and better efficiency, the cost just isn't going to balance the savings on fuel. Those saying "it's a truck", he isn't asking for 40mpg, he just wants improvement. If you can't help move on.
    bmf4069 and because_wumbo-truck like this.
  16. Oct 27, 2019 at 3:32 PM
    Aerindel
    Aerindel New Member
    Montana
    As a great engineer once said
    Darkness, GODZILLA, bmf4069 and 2 others like this.
  17. Oct 27, 2019 at 4:29 PM
    Oregon 2006 Tundra
    Spray-in Bedliner
    Good info and good humor too.
    I appreciate both.
    May go with long-tube headers, more open exhaust/dual, and a K&N air-cleaner. I'll research the gearing a bit more as I don't understand that as well as I should. I like the "sleeper" look more than the "Look at me" kinda lifestyle. To each their own and all that. Any ideas on remapping the shift points on the transmission? My car doesn't need to downshift when climbing a hill and I think that is simply the difference in torgue. If I can get a few more ponies/torgue out of it, it may solve the shifting issue. At least that's my idea.
  18. Oct 27, 2019 at 4:53 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    You need over tune or some other tuning device. That’s how Toyota tune the tundra transmission, downshifts for no reason.
    And my old Tacoma, can’t shift fast enough To higher gear.
  19. Oct 27, 2019 at 8:33 PM
    because_wumbo-truck
    Jon
    Houston, Texas
    What size tire you running? Gears and headers and fuel injectors will likely be the best bang for your buck. I gained about 20-30 miles to a tank with the injectors and I'm on 295/75r16 (33.5"x11.5")
  20. Oct 28, 2019 at 12:07 PM
    the_white_shadow
    the_white_shadow New Member
    Slow down. Problem solved. Toyota trucks have never gotten good mileage. Not even the 4 bangers.
  21. Oct 28, 2019 at 12:19 PM
    JohnLakeman
    True that. My 22RE 4Runner consistently got 23 mpg.
  22. Dec 13, 2019 at 7:37 AM
    tglyder
    tglyder Wise & Heimer
    NW Oregon
    Silver 2010
    I'd expect like on all my past vehicles... K&N air filter and freer flowing exhaust. I got better mileage and power. Same on my Harleys. On my Harleys, I also camed up a notch to a 302 and got even better mileage and power.
  23. Dec 13, 2019 at 8:06 AM
    revtune
    revtune New Member
    Dane
    Houston Texas
    2006 Tundra 4.7 AC 2wd
    2006 Tundra: Stock air intake 3 inch catback Magnaflow 13742 2.5 inch front lift 1.5 inch rear blocks 2014 sr5 4Runner wheels (17x7) 1.5 inch hub centric wheel spacers p285/70/17 Nitto Terra Grappler G2 Weathertech floor liners
    Even changing the air filter won’t do much on these trucks. stick with the stock air filter or equivalent. The only aftermarket intake I would even consider is AFE. free flowing exhaust would get expensive; headers, mid pipes, x pipe, bam mufflers plus labor. I would love to do it, but I’m eyeing a regear instead for 33” tires.
    Darkness likes this.
  24. Dec 13, 2019 at 8:12 AM
    Nailgun
    Nailgun New Member
    2016 black Tundra TRD
    TRD sway bars “3 lift, rear air bags, bumpers/winch, TRD exhaust- air intake
    My mpg went up after 2 speeding tickets, amazingly simple trick
  25. Dec 13, 2019 at 8:45 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    My 4.7 2002 has a Kazume/TRD LSD and JBA short tube headers. The LSD applies the slight gain in power the JBA's produce and this improves drive-ability. I turn the Over Drive off whenever the transmission has trouble finding a gear to match my needs, and I roll on standard size 16" Michelins. The only way I have been able to achieve better than average MPGs is to remain below 66 MPH.
    I could gain a little more power with a BAMuffler system, and I may do this in the future.
    If you really want a power boost, find yourself a nice used 2007 to 2010 5.7 Tundra, my 2007 is a beast and they are tune-able for more power, better shift point, speed governor removal, etc....
  26. Dec 13, 2019 at 8:51 AM
    Ajkkane
    Ajkkane Old fart.
    Nj
    2014 CM SR5
    6) BUY A PRIUS!:)
    glowblue likes this.
  27. Dec 13, 2019 at 9:29 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Just buy the Torque Pro App. It tells me I'm getting 21mpg. Problem solved.:burnrubber:
    lsaami and speedtre like this.
  28. Dec 13, 2019 at 10:43 AM
    Deuxlatch
    Deuxlatch AirBus
    Chris (Latch)
    Tomball, Tx./Lafayette, La.
    2010 Super White Tundra CM
    TRD Supercharger, TRD Big Brake kit, MotoMetal wheels, Undercover Tonneau with dual swing out saddle bag tool boxes.
    Supercharge it. I have over 500hp and still get 17-18mpg on the highway. But boy it lets me know when I put my foot in it, both in power and gas mileage.
  29. Dec 13, 2019 at 10:58 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
  30. Dec 13, 2019 at 11:03 AM
    Tiamat
    Tiamat New Member
    2015 tundra crewmax xp
    Keep it under 65 or better yet 55 and use sport mode and run 6th gear always use express way.
    I average 17.5 -18mpg on hwy running 65 on six gear.
    As far as more power good luck. Every mod you do exhaust, CAI headers what ever will usually show up at WOT in the 5600-6000 rpm range. now if you spend 8+ thousand dollars for super charger then that is different.
