VSC kicks on and loss of power
Discussion in '2nd Gen Tundras (2007-2013)' started by Cle_Easy_Kill, Mar 31, 2023.
  1. Mar 31, 2023 at 3:26 PM
    Cle_Easy_Kill
    Cle_Easy_Kill [OP] New Member
    I have a 2008 SR5 Double Cab
    I recently had slightly larger tires put on with an alignment and zero point calibration done. Shortly there after the VSC light would kick on and a loss of power would happen. At times there is loss of power without the VSC lights. It helps to turn off the VSC or put it into 4wd but doesn’t always fix it. I just took it into the dealer and they did a ZPC again and felt confident it would fix the issue. It didn’t. Any ideas?
    The following items have been replaced:
    New wheel bearings (all 4)
    New brakes (rotors, pads, calipers)
    New CV shafts
    New upper and lower control arms
    New leveling shocks (all 4)
    New rear leaf springs
    New inner and outer tie rods
  2. Mar 31, 2023 at 3:33 PM
    Cle_Easy_Kill
    At one point I had an error code of U0126 lost communication with steering angle sensor.
  3. Mar 31, 2023 at 11:38 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    This would probably be an electrical issue, as no other code is coming with the U0126. Best way is to check fuses first, then look for the can bus and check for loose grounds.
  4. Apr 2, 2023 at 7:45 AM
    Cle_Easy_Kill
    I’ve checked the fuses and they are all intact. How do I check the can bus and grounds?
