Vsc flashing and traction control on.
Discussion in '2nd Gen Tundras (2007-2013)' started by SalsaTheTundra, Jun 2, 2020.
  1. Jun 2, 2020 at 5:54 PM
    SalsaTheTundra
    SalsaTheTundra [OP] New Member
    jd
    Birmingham, Alabama
    2008 Salsa Tundra Double Cab SR5 5.7
    Ubar led headlights K&N filter +50HP
    this happened today and yesterday and i’m confused. read it is the #7 cylinder. just worried to put money into the truck if it is about to die.
  2. Jun 2, 2020 at 6:13 PM
    Trident
    Trident New Member
    2007 Tundra DC 4X4
    Get the codes read. Autozone, etc will do it for free.
    Report back here and someone knowledgeable will speak up.
    SalsaTheTundra[OP] likes this.
  3. Jun 2, 2020 at 7:07 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    is it a misfire?? like stated above check codes and give us a little more input.. Some questions before you go, have you changed the spark plugs?? When you identify cylinder 7 pull the coil pack and swap it with the coil next to it and restart to see if anything changes, so you may get a better answer like that coil pack is dead.
  4. Jun 2, 2020 at 7:35 PM
    How are VSC and traction related to a cylinder? Check your abs wheel speed sensors
  5. Jun 2, 2020 at 8:31 PM
    blackdemon_tt
    It seems like the ECU triggers these along with a CEL.... I had both turn on for a crankshaft position sensor, and they had no relation.... May be a scare tactic to prevent the owner from driving it and preventing further damage. I just pulled it out of my ass, but when those lights came on it did scare the ish out of me... but I still moved it anyway....
  6. Jun 2, 2020 at 8:51 PM
    SalsaTheTundra
    jd
    Birmingham, Alabama
    So trip to dealership or autozone?
  7. Jun 2, 2020 at 8:58 PM
    blackdemon_tt
    go to autozone where its free99, and take a small bag with a 12, 14, 10 (because I don't remember the coil's size but its probably a 12mm) and a ratchet so when you pull codes you can be ready to swap the coils and run a diagnostic again... if its under warranty, then let Toyota deal with it....
