VSC blinking, CHECK ENGINE LIGHT on, traction control light on
Discussion in '2nd Gen Tundras (2007-2013)' started by Pompano guy, Sep 4, 2024.
  1. Sep 4, 2024 at 3:42 AM
    Pompano guy
    Pompano guy [OP] New Member
    Robert
    2008 Toyota Tundra 2WD 5.7
    When I start my 2008 Tundra 2WD 5.7, the VSC light stays on ( blinking ) , the "traction control" symbol comes on, and the "check engine" light comes on. After a short distance and braking for the first or second time, the transmission will not advance into top gear. After shutting the engine off, this stops. The lights still stay on. After 4 starts, the lights go away. Upon the 5th or 6th start, the process starts over. Is this the knock sensor?
  2. Sep 12, 2024 at 3:54 AM
    tmac58star
    tmac58star New Member
    Black 1st generation Tundra SR5 Access Cab
    Check/clean/rehab/renew all your batt connections, etc. And read/run the codes just for grins...
  3. Sep 12, 2024 at 12:00 PM
    Pompano guy
    Robert
    Yea, this started when I replaced the positive cable. Ty
  4. Sep 12, 2024 at 12:24 PM
    tmac58star
    Revisit that, make sure all connections are clean/tight...check other cables for corrosion.
