VSC and Track
Discussion in '1st Gen Tundras (2000-2006)' started by jskeyes2, Jan 29, 2021.
  1. Jan 29, 2021 at 6:17 PM
    jskeyes2
    jskeyes2 [OP] New Member
    Jeff
    Carlsbad, CA
    2005 Limited AC
    ADS Shocks 35” Yokahama M/T
    Can someone explain these lights to me? Should both of them be off when I’m in four-wheel-drive? I have looked at various post by get confused every time I read them.
    i’m trying to determine what is normal in four-wheel-drive and what is not. I believe I cannot turn off limited slip differential when I’ve been non-four-wheel-drive but not sure.
  2. Jan 30, 2021 at 7:46 AM
    Tundras have a mechanical LSD. It is not a selectable locker like on the Tacoma. I'm not sure about the VSC and Trac lights. Being in 4hi vs 4lo may change the function of these systems. Someone with more knowledge on this can chime in, or search the forums for more info.
  3. Jan 30, 2021 at 12:41 PM
    NetGnome
    NetGnome New Member
    NJ
    2003 RC V8 4wd, 2007 Sequoia V8 4wd
    Removed lots of rust.
    Mechanical LSD only lock when one rear wheel is spinning at a much different speed then the other rear wheel.
  4. Jan 31, 2021 at 11:09 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    In 4hi only the vsc light should be off if everything is working property.
    Recap:
    Green 4hi and orange vsc lights on.
