Volume When Listening to Satelite Radio Is Much Lower
Discussion in 'Audio & Video' started by onsafari, Sep 20, 2016.
  1. Sep 20, 2016 at 1:13 PM
    onsafari
    onsafari [OP] New Member
    Mark
    Castle Rock, CO
    2016 Tundra CM TRD
    Anyone else have this issue when listening to satellite radio is that the volume is a lot lower than regular radio? I have to have my volume set to at least 40 before it's loud enough to hear it and well over 50 when the windows are down. Is there a setting I'm missing or something that can be done to fix this issue?
    Thanks
  2. Sep 20, 2016 at 1:15 PM
    Same thing iTunes vs Pandora. Streaming is usually lower...however, I found with Amazon music it isn't the case like it was with Pandora.
    SouthBoundSteve likes this.
  3. Sep 20, 2016 at 1:19 PM
    TheBeast The Beach
    my xm is actually louder than my iphone bluetooth
  4. Sep 20, 2016 at 4:32 PM
    vidman
    vidman New Member
    Rick
    Massachusetts
    I noticed that my xm is not as loud as my I-pod but My xm antenna really sucks. anyone know where the xm tuner is located in our trucks. might swap out the antenna like i did in my taco
  5. Sep 20, 2016 at 5:04 PM
    TundraTex
    TundraTex FRAC On!
    Lou
    DFW Texas
    '16 TSS CM 4x4
    My XM actually comes in stronger than FM which comes in stronger than AM. One thing to check is your Fader and EQ settings. They can be different for each Audio Source depending on how you adjust them.
    TheBeast likes this.
  6. Sep 21, 2016 at 7:51 AM
    onsafari
    Mark
    Castle Rock, CO
    2016 Tundra CM TRD
    Yeah I have them all set differently based on what my source is. I had the same issue in my 4Runner but it wasn't as bad as this is. My wife's Lexus when set to XM has no difference between sources but it could be because of the ML system that it has. May have to make a stop to an audio shop and see what can be done to get more volume out of it.
  7. Sep 21, 2016 at 10:07 AM
    Berkdawg
    Berkdawg New Member
    2013 Rock Warrior
    Clazzio Seat Covers, Eibach/Toytec Coil Overs (3"), Toytec Boss Rear Shocks, Firestone Airbags
    I also find the XM does not have the same tone as the other sources. Not that any of them are stellar but XM is like a tin can and it keeps me from ever buying the service.
