voltage issue?
Discussion in 'General Tundra Discussion' started by Wwright1125, Sep 16, 2018.
  1. Sep 16, 2018 at 10:45 AM
    Wwright1125
    Wwright1125 [OP] New Member
    Wade
    2011 Tungra
    Have a 2011 Tundra, had the alternator replaced a couple days ago, was told it was bad. Battery tested ok. Today I noticed that the voltage gauge is fluctuating from 14v to 10-12v approx. dash lights also dimming the getting bright again. Any theories what to look at next?
  2. Sep 16, 2018 at 10:50 AM
    8MINT8
    8MINT8 #NotBetty
    Lost
    2018 Unicorn TRD
    I would look at the battery again. When you tested it, did you have any load on it? Run the ac and stereo to see if rpms fluctuate.
    Black Wolf and ColoradoTJ like this.
  3. Sep 16, 2018 at 11:27 AM
    Twinky
    07 double cab work horse
    Agree with having the battery checked again.
    An alternator that has failed normally has worn the battery down while it was failing.
    Do you know if the battery was load tested?
    NewImprovedRon likes this.
  4. Sep 16, 2018 at 11:39 AM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    Make sure the connections at the alternator are all solid and that the cable hasn't been compromised.
  5. Sep 16, 2018 at 3:55 PM
    InfernoTundra
    InfernoTundra New Member
    Sounds like the voltage regulator if the above is good. If it's a reman alternator, a lot of times they reuse the voltage regulator.
